รีวิวพ์ ESI Juli@ sound card: Professional
  • #61
    คอยพบกับลูกพี่ลูกน้อง จูลี่ ครับ
    maya44 mkII pci
    • #62
      เพิ่งอ่านหลังกล่อง อุปกรณ์คัดเกรดทั้งนั้น
      The Prodigy 7.1 HiFi is based on the powerful VIA Envy24HT (ICE 1724) audio controller and the Wolfson WM8776 / 8766 codecs, providing 2, 4, 6 (5.1) and 8 (7.1) channel support as well as optical digital I/O with 24-bit/196kHz support.
      To provide stable high level output signals, Prodigy 7.1 HiFi uses a fine selection of high quality capacitors from Sanyo (SP series) and from Nichicon (up to 2200uF RU series / Nichicon ES series) to optimize the power supply of the analog and digital components on the card and to optimize the audio output quality. The special design of Prodigy 7.1 HiFi with its 4 layer PCB cuts off electromagnetic waves from the internals of the PC – there won't be problems with an unstable power supply caused by the systems CPU or the HDD.
      A separation between the analog and the digital part using an aluminium cover that shields the sound against electromagnetic waves is a major part of the Prodigy 7.1 HiFi design. Even better, the OpAmps on the card are installed on sockets, providing the possibility to change them to the users preference.
      The Prodigy 7.1 HiFi driver software is based on the EWDM standard from pro audio manufacturer ESI providing perfect compatibility with Windows 2000 / XP / 2003 and even Windows XP x64 as well as Windows Vista 32-bit and 64-bit, offering high performance and low latency operation with all important famous audio applications. The DirectWIRE 3.0 and Advanced NSP (Native Sound Processing) support in the driver allows you to virtually patch all your digital audio sources internally between various different software applications running at the same time and use effect plugins simultaneously. Audio streams can be transferred between different audio applications, which is especially great when using software effects, synthesizers or virtual instruments. The driver also includes support for the 3D technologies from QSound Labs in Canada: Q3D/QEM, QMSS, QRumble, QSizzle, QExpaner, QEQ and QNormalize.
      • #63
        ใครต้องการบ้างครับ จูลี่ งบ 3500.-
        • #64
          X-fi 5.1 ขาวสวยเนียนมากกกก
          • #65
            กำ เผลอหลับแปปเดียว ของเทพมาเยือนอีกละ
            ท่านบอล ช่วยเกรงใจเงินในกระเป๋าผมหน่อยท่าน ทำแบบนี้ค่านมลูกผมจะเหลือป่าวเนี่ย
            • #66
              มันมาเองครับพี่
              • #67
                เดี๋ยวผมรีวิวให้ละกัน
                ควรปิดSoundEffectของWindowsให้หมด ไอ้สียงคลิกเมส์ เปิดโฟลเดอร์
                เอาวิธีการฟังเพลงเพื่อให้แสดงPreformaceของมันละกันคร่าวๆก่อนละกัน
                เดี๋ยววิธีใช้Directwireมาที่หลัง + เดี๋ยวคำอธิบายอื่นๆตามมาที่หลัง
                ให้ท่านหาPlugins AISO มาใช้แล้วตั้งค่าตามรูป
                เราจะResamplingไปที่192Khzเพื่อกลบเสียงความถี่สูงที่ไม่สมบูรณ์ที่ของเพลงที่Samplingที่44.1Khz
                (ถ้าท่านไม่ชอบก็ไม่ต้องResampling)
                ทีนี้ท่านก็ไปลองฟังใหม่ละกัน
                อ้อที่MasterVolumn ควรเปิดให้สุด
                • #68
                  เรื่องสายสัญญาณ
                  RCA ใช้ทั่วๆไป เชื่อมต่อระยะทางไม่ยาวนัก สัญญาณไม่แรงมาก ไม่เกิน 6dB
                  แต่ในระบบDigitalเสียงดังสุดได้ที่ 0dB เท่านั้น
                  UnBalance/Balance ตัวนี้ต่อได้ 2 แบบเลย แล้วแต่ชนิดหัว
                  UnBalance ส่วนมากใช้เชื่อต่อจากอุปกรณ์หรือเครื่องดนตรี ที่ใช้ระยะทางไม่ยาวนัก
                  เพราะเสียงAnalogบางทีอาจpeakเกิน +20dB
                  ไฟเลี้ยงOpampในระบบUn+/-Balanceจะสูงกว่า ทำให้จุดClipอาจอยู่สูงถึง 64dB เลยก็ได้
                  Balance
                  - ใช้ในการส่งสัญญาณระยะทางไกล เพราะจะมีตัวเปรียบเทียบNoiseที่มารบกวนสายจากสาย
                  - ใช้ในการส่งสัญญาณของMicที่เป็นแบบCondensorเพราะว่าสัญญาณ
                  ที่ออกมาจะเบามากกกก่อนที่จะส่งไปที่Ampเพื่อขยายสัญญาณ (48V Phantom Power)
                  (ส่วนแบบDynamicMicถึงเป็นหัวXLRแต่ส่วนมากต่อแบบUnbalanceจ้า)
                  คุณภาพ
                  แบบBalanceดีที่สุด ประหยัดสุด เปรียบเทียบง่ายๆ
                  ถ้าคุณจะส่งสัญญาณในระยะทาง 20 เมตร
                  ถ้าเป็นแบบ RCA ใช้สายคุณภาพสูงเพื่อShildNoiseไม่ให้มารบกวน เมตรละ 1000
                  ถ้าเป็นแบบBalanceใช้สายแค่คุณภาพปานกลาง เมตรละ 200 ก็เพียงพอแล้ว
                  แนะนำ ให้ใช้แบบ Balance ประหยัดเงิน คุณภาพดี
                  สัญญาณรบกวนน้อย (ไม่ต้องไปซื้อสายเส้นละห้าพันแบบคนบางพวกหรอก)
                  แค่เดินไปที่นัฐพงษ์ ซื้อ สายคาเนรัล หัว นูทริก มาจิ้มเองที่บ้านก็เทพแล้ว
                  AMP คุณภาพดี ยี่ห้อไหนก็มีรูให้หัว XLR ให้เสียบทั้งนั้น
                  แถมวิธีแปลงหัวให้ด้วย
                  เอกสารเพิ่มเติม
                  DirectWire
                  ใช้เป็นVisualCable ในการOutputสัญญาณจากที่หนึ่งไปอีกที่หนึ่ง
                  ต่างกับโปรแกรมVisualAudioCableอื่นๆ คือSampleRate เป็นอิสระต่อกัน
                  เช่น โปรแกรมนี้ 44.1 วิ่งไปเข้าโปรแกรมที่ใช้ 192Khz
                  ทีนี้จะใช้ยังไงดีละ.............
                  ก็เอาเป็นว่า SoundCard รุ่นนี้ มันไม่มีระบบอะไรให้เล่นเลย
                  ผมก็จะสาธิต Add เสียง3D ที่เป็นระบบ HRTF ที่ยี่ห้ออื่นมันมี
                  ที่นี้ผมก็จะตั้งค่าในWinamp ออกไปที่Output34ที่เป็นDirectsound
                  ซึ่งเป็นOut Digital แล้วผมก็ไม่ได้ใช้
                  แล้วผมก็โยงสายDirectWire จากOut MME 34 ไปที่ IN ASIO 12
                  ไม่จำเป็นแต่ Winamp โปรแกรมอะไรก็ทำได้ เช่นดูดีวีดี ...
                  แล้วผมก็ใช้ Plogue_Bidule ซึ่งเป็น Host VST ที่ใช้เป็นคลัง Effect
                  ระบบ HRTF เป็นของ Wavearts ซึ่งเค้าจะมี Plugins ระบบนี้โดยเฉพาะ
                  ก็AddPluginsนี้ลงไปชื่อ Panorama อยู่ใน Powersuit
                  (ปลั๊กอินนี้ส่วนมากแล้วจะใช้ขยายมิติของเสียงที่ออกจากลำโพงเพื่อที่จะให้ง่ายต่อการวางตำแหน่งของเสียงในขั้นตอนการMix)
                  (ถ้าไม่รู้หรือรู้แบบมั่วๆว่ามิติของเสียงคืออะไร ให้หาหนังสือ The art of Mix ของ David Gibson มาอ่านซะ)
                  จากนั้นที่ตัวโปรแกรม ก็โยง Input AISO 12 มาเข้าที่ Plugins Panorama
                  แล้วก็ให้ไปออกที่ output AISO 12
                  อธิบายคร่าวๆถึงหน้าตาของมัน
                  1. ใช้กำหนดการวางลำโพงที่เรามี เลือกได้เป็นองศาการวางลำโพง กะ Headphone (รูปลำโพงเข้มๆ)
                  2. เป็นการจำลองตำแหน่งลำโพง เพื่อจำลองเสียงที่ออกมาจากลำโพงนั้น (รูปลำโพงจางๆ)
                  3. จำลองขนาดห้อง
                  4. ปริมาณReverb
                  อันนี้เป็นแค่ยกตัวอย่าง
                  ยังมี EQ Reverb Bassboot tube ......etc. คุณภาพเทพ ให้เล่นอีกเพียบใส่ได้ไม่ยั้ง
                  ไม่ได้มีแค่ ยี่ห้อสองยี่ห้อ แมร่งมีเป็น 100 ให้คุณเปลี่ยนเอกลักษณ์เสียงได้ไม่ยั้ง
                  ใช้เป็นEffectGuitarก็ได้ GuitarRig,Guitarrack
                  ใช้เป็นคลังเครื่องดนตรีก็ได้
                  HaveFun
                  3500 ถูกมากกกกก ทำเพลงอัดเสียง ดูหนัง เล่นเกมส์ โคตรคุ้ม
                  ขายออกไวๆนะครับ
                  (หาคนร่วมอุดมการณ์ หุหุหุ)
                  เดโม ทนลองใช้ 30 วัน
                  We make audio plug-ins for mixing, mastering, restoration, and sound design, combining innovation with thoughtful user-interface.
                  • #69
                    มีคอ สตูดิโอมาร่วมอุดมการณ์แล้ว เย๊
                    มีคำถามจะปรึกษา ทั้งเรื่องPlugin VST & VSTi
                    ขอเวลาเตรียมคำถามก่อน
                    • #70
                      มาแล้ว...ของที่ไม่เคยเห็น....ตะลึงๆๆๆๆๆๆๆตึงๆๆๆๆๆ
                      • #71
                        โอตะจัง อะซิโอ..
                        • #72
                          ว่าแต่ตอนนี้ถอดออกสงบนิ่ง.....ฟังโปรดิจี้ 7.1 ไฮไฟ อยู่อะ.
                          • #73
                            จูลี่มีสั่งเข้ามาอีกหรือเปล่าครับ
                            • #74
                              พอหาให้ได้ครับไม่เกิน 3500.-
                              • #75
                                หาpluginsมายั่ว><
                                พยายามหาตัวที่ทำงานเหมือนกับที่มีในการ์ดทั่วๆไป
                                หามาทดลองใช้ได้ 30 วัน
                                จำลองTubeParametricEQ
                                จำลองTubeEQแบบGraphicปรับค่าQได้><"
                                จำลองAPI-EQ
                                StereoImage
                                เหมือนกับ QExpander แต่ผมว่าPanoramaเข้าท่ากว่าเยอะ
                                MultiBand Comp/Expander
                                ถ้าจะเอามาเปรียบเทียบก็ใช้งานเหมือน QRumble Qsizzel คือ เอาไว้ถ่างไดนามิกส์
                                ปรับค่าได้ละเอียดปรับให้โดนใจได้สบายๆ
                                Reverb มีหลายยี่ห้อให้เลือก
                                Reverbข้างล่านนี้ เค้ายกให้เป็นที่ 1 ในโลกแบบImpulseRespond
                                จำลองเสียงReverbสถานที่ดังๆต่างๆในโลกไว้เพียบ
                                GuitarEffect
                                ถ้าท่านมีกีตาร์ที่มีปรีเอมป์ในตัว ซื้อDirectBox เพื่อแปลงZ-Impedance--->100โอม
                                เสียบตรงแล้วเสียวได้เลย
                                (สอยไปแล้วอยากได้สูตรอมตะก็.....1...0...ทิพย์ หรือหลังไมค์เดี๋ยวบอกวิธีกดสูตรให้)
