ใครอยากได้ AudioTrak MAYA 44 MK2 บ้าง สภาพดีใช้งานปกติ ผมอยากฟังแต่ไม่อยากได้ ราคารวมส่งถึงหน้าบ้าน 2600.-ขอมัดจำ 1000.-ผมซื้อได้เลย มิได้เอากำไรแต่อย่างใดเช็คอินวอยซ์ได้
ESI MAYA44 Sound Card
MAYA44 is a high quality 24-bit 96/192kHz 4-in / 4-out audio interface providing a number of powerful and amazing features optimized for home recording and for DJ applications.
The card can easily be used by home users making their first steps in computer audio as well as by professionals producing music on a budget.
MAYA44 provides 2 stereo analog line inputs, 2 stereo line outputs, a microphone input with +48V phantom power as well as an optical and coaxial S/PDIF output that can be used to pass through AC3/DTS signals. There is also a headphone output, perfectly for monitoring.
The optional MI/ODI/O extension provides a full MIDI interface (16 channels, 1 input & 1 output) as well as a digital input (optical and coaxial).
ESI MAYA44 Sound Card Features
Supports up to 24-bit / 192kHz output and 96kHz input
4 analog input and 4 analog output channels
4-in / 4-out full duplex recording and playback
balanced microphone input with +48V phantom power
headphone output with gain control
unbalanced stereo line input (1~2) can be switched to balanced mono microphone input
optical and coaxial (S/PDIF) digital output
optional MIDI I/O via MI/ODI/O extension
optional S/PDIF digital input via MI/ODI/O ext.
3.3V / 5V compatible PCI card
EWDM driver: MME, DirectSound, ASIO 2.0 and GSIF 2.0 support
Windows Vista/XP/2000 and Mac OS X compatible
ราคาที่โปรปลั๊กอิน http://www.proplugin.com/product.det...2873&id=195747
เอาพาเนลไปดูก่อน iXBT ของรัสเซียเป็นคนทำไว้
