ใช้ foobar + asio4all แล้วโปรแกรมมันเด้งครับ
  • ใช้ foobar + asio4all แล้วโปรแกรมมันเด้งครับ
    เพิ่งได้ onkyo se200 pci มา
    กะว่าจะลองเล่นดู
    ถ้า set output เป็น asio : asio4all v2 มันเด้งออกจากโปรแกรมเลยครับ
    แล้วมันขึ้นแบบนี้ครับ
    Illegal operation:
    Code: C0000005h, flags: 00000000h, address: 017E67BAh
    Access violation, operation: read, address: 0190E000h
    Call path not available.
    Code bytes (017E67BAh):
    017E677Ah: E0 88 7E 01 0F 84 1C 01 00 00 53 57 56 8B 9D C0
    017E678Ah: 05 00 00 8B BD C4 05 00 00 FF 34 9D 30 8C 8E 01
    017E679Ah: 43 0F B7 8D 9A 00 00 00 8B 74 24 04 55 8B AD B4
    017E67AAh: 05 00 00 8B 04 B5 00 00 00 00 03 35 E8 88 7E 01
    017E67BAh: F7 2C 9D 30 8C 8E 01 01 54 BD 00 83 C7 40 E2 E3
    017E67CAh: 5D 47 83 E7 3F 43 FF 0C 24 75 C6 58 FF 04 24 89
    017E67DAh: 9D C0 05 00 00 81 85 BC 05 00 00 A0 00 00 00 8B
    017E67EAh: 95 B8 05 00 00 8B B5 C4 05 00 00 8B 9D B4 05 00
    Registers:
    EAX: 00000000, EBX: 000094F4, ECX: 00000002, EDX: 00000000
    ESI: 00724800, EDI: 00000033, EBP: 01B80000, ESP: 01FAFF38
    Crash location: "asio4all", loaded at 017E0000h - 0190E000h
    Loaded modules:
    foobar2000 loaded at 00400000h - 0052B000h
    ntdll loaded at 7C900000h - 7C9AF000h
    kernel32 loaded at 7C800000h - 7C8F6000h
    COMCTL32 loaded at 773D0000h - 774D3000h
    msvcrt loaded at 77C10000h - 77C68000h
    ADVAPI32 loaded at 77DD0000h - 77E6B000h
    RPCRT4 loaded at 77E70000h - 77F02000h
    Secur32 loaded at 77FE0000h - 77FF1000h
    GDI32 loaded at 77F10000h - 77F59000h
    USER32 loaded at 7E410000h - 7E4A1000h
    SHLWAPI loaded at 77F60000h - 77FD6000h
    SHELL32 loaded at 7C9C0000h - 7D1D7000h
    ole32 loaded at 774E0000h - 7761D000h
    shared loaded at 10000000h - 1002A000h
    COMDLG32 loaded at 763B0000h - 763F9000h
    LPK loaded at 629C0000h - 629C9000h
    USP10 loaded at 74D90000h - 74DFB000h
    avgrsstx loaded at 003A0000h - 003A5000h
    MSCTF loaded at 74720000h - 7476C000h
    foo_albumlist loaded at 00A80000h - 00AEC000h
    foo_cdda loaded at 00B10000h - 00B50000h
    foo_converter loaded at 00B70000h - 00BD7000h
    foo_dsp_std loaded at 00C00000h - 00C49000h
    foo_input_std loaded at 00C70000h - 00D9C000h
    foo_out_asio loaded at 00DC0000h - 00DF7000h
    foo_out_ks loaded at 00E20000h - 00E4A000h
    SETUPAPI loaded at 77920000h - 77A13000h
    foo_rgscan loaded at 00E70000h - 00ECB000h
    foo_ui_std loaded at 00EF0000h - 00FC5000h
    gdiplus loaded at 4EC50000h - 4EDF6000h
    UxTheme loaded at 5AD70000h - 5ADA8000h
    MSIMG32 loaded at 76380000h - 76385000h
    DSOUND loaded at 73F10000h - 73F6C000h
    VERSION loaded at 77C00000h - 77C08000h
    WINMM loaded at 76B40000h - 76B6D000h
    WINTRUST loaded at 76C30000h - 76C5E000h
    CRYPT32 loaded at 77A80000h - 77B15000h
    MSASN1 loaded at 77B20000h - 77B32000h
    IMAGEHLP loaded at 76C90000h - 76CB8000h
    wdmaud loaded at 72D20000h - 72D29000h
    msacm32 loaded at 72D10000h - 72D18000h
    MSACM32 loaded at 77BE0000h - 77BF5000h
    midimap loaded at 77BD0000h - 77BD7000h
    CLBCATQ loaded at 76FD0000h - 7704F000h
    COMRes loaded at 77050000h - 77115000h
    OLEAUT32 loaded at 77120000h - 771AB000h
    asio4all loaded at 017E0000h - 0190E000h
    KSUSER loaded at 73EE0000h - 73EE4000h
    DBGHELP loaded at 59A60000h - 59B01000h
    Stack dump analysis:
    Address: 017E670Bh, location: "asio4all", loaded at 017E0000h - 0190E000h
    Address: 017E63ADh, location: "asio4all", loaded at 017E0000h - 0190E000h
    Address: 7C90E4F4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
    Symbol: "KiFastSystemCallRet" (+00000000h)
    Address: 7C80B713h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
    Symbol: "GetModuleFileNameA" (+000001B4h)
    Address: 7C839AC0h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
    Symbol: "ValidateLocale" (+000002B0h)
    Address: 7C80B720h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
    Symbol: "GetModuleFileNameA" (+000001C1h)
    Address: 017E5F20h, location: "asio4all", loaded at 017E0000h - 0190E000h
    Address: 00E9D000h, location: "foo_rgscan", loaded at 00E70000h - 00ECB000h
    Address: 00C80008h, location: "foo_input_std", loaded at 00C70000h - 00D9C000h
    Address: 7C800000h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
    Version info:
    foobar2000 v0.9.5.6
    UNICODE
    Windows 5.1
    Additional info:
    foobar2000 core 0.9.5.6 (Core)
    Default User Interface 0.9.5 (foo_ui_std)
    Kernel Streaming Output 1.2.2 (foo_out_ks)
    Standard Input Array 1.0 (foo_input_std)
    ASIO support 1.2.6 (foo_out_asio)
    CD Audio Decoder 2.1.3 (foo_cdda)
    ReplayGain Scanner 2.0.8 (foo_rgscan)
    Album List 4.3 (foo_albumlist)
    Converter 1.1.2 (foo_converter)
    Standard DSP Array 1.0 (foo_dsp_std)
    และถ้า set output เป็น ks : envy24 family audio (wdm)
    มันจะขึ้นแบบนี้
    Unrecoverable playback error: KS output error: error opening device
    ผมทำอะไรผิดหรือเปล่าครับ
    set แบบที่ท่านเรือรบบอกเลย
    น่าจะเจอปัญหาแล้วครับ
    ผมลองตั้ง sample rate เป็น 44.1มันก็ไม่เด้งแล้วครับ
    ลองปรับเป็น auto ก็ไม่ได้เด้งเหมือนกัน
    ถามหน่อยครับผมควรจะเตั้งค่าอะไรแบบไหนบ้างครับ
    เน้นฟังเพลง cd เป็นหลัก
      sample rate ตั้งเป็น auto
      digital out เป็น pcm only หรือไม่ก็ disable ไปเลย
      แล้วกด immoezio 3d soundeffect ด้วย
