Audio Performance
Output Signal-to-Noise Ratio (A-Weighted): 100 dB
Output THD+N at 1kHz (A-Weighted): 0.0045% (87 dB)
(-60dB, A-Weighted) 96 dB
Dynamic Range: 96 dB
Analog Playback Sample Rate and Resolution: 48 KHz
Cross-talk (10Kohms, 1KHz) -104 dB
Headphone Amp
THD+N< 0.005% @ 47 mW x2/ 32ohms
THD+N< 0.006% @88 mW x2/16ohms
96 dB SNR >1.1Vrms full-scale output voltage for >8 ohms load
Frequency response (-3dB/48KHz): 20~20 KHz for 32 ohms
(headphones with 8~150 ohm @ >10mWx2 recommended)
Audio Processor
U100
I/O Ports
Bus Compatibility: USB
Analog Output Jack & Digital S/PDIF Output Combo: Analog 2CH/Digital 5.1
Analog Input Jack: Yes, stereo recording
Driver features
Operation System: Windows Vista (32 & 64 bit), Windows XP (32 & 64 bit)
Dolby® Technologies: Dolby® Headphone, Dolby® Virtual Speaker, Dolby® Pro-Logic IIx, Dolby® Digital Live
DirectSound3D Game Extensions 1.0/DirectX: DS3D GX 1.0 supports EAX gaming sound effects and DirectSound 3D hardware enhanced functions on Windows Vista. (DirectX/DirectSound 3D compatible)
Smart Volume Normalizer™ : Normalizes the volume of all audio sources into a constant level and also enhances your 3D sound listening range and advantages in gaming
Magic Voice™: Modifies the sound of your voice, for VOIP and online chat applications
Karaoke Functions: Music Key-Shifting and Microphone Echo effects
Xear 3DTM Virtual Speaker Shifter: Virtual 7.1 speaker positioning
Array Microphone: Reducing environmental background sounds and noises; keeping your front side voice input as clean as possible
Other Effects: 10-band Equalizer/27 Environment Effects
The capacitors used inside the Asus Xonar U1 are manufactured by United Chemicon KMG; much to our surprise it retains traditional electrolyte capacitors rather than following the popular trend of using solid state capacitors.
Operational amplifier (OPAmp) used on the Asus Xonar U1 is National's LM358 OPAmp.
The Asus audio processor used on the Asus Xonar U1, as far as I know, is a rebranded C-Media Nitrogen D2 USB audio chip.
A single NEC UC2 low profile relay is located on the Asus Xonar U1. This is the same relay used on the Asus Xonar D2
อันนี้ รายละเอียด Chip Nitrogen D2
http://www.cmedia.com.tw/files/doc/U...eet%201.02.pdf
มาถึงคำถามแล้ว
1. คาปาซิเตอร์ที่ใช้อยู่ในตัวนี้ ถือว่าอยู่ในเกรดไหนหรอครับ เพราะเห็นเป็นแบบ electrolyte capacitors ผมให้จัดเรท 1 2 3 4 5
2. National's LM358 OPAmp. ตัวนี้เนี่ย อยู่ในเกรดไหนหรอครับ แล้ว เคยมีการ์ดใบไหนเอาไปใช้ก่อนหรือไม่
3. ตัวนี้สามารถ ถอด DTS ได้หรือไม่ (สามารถ เข้าไปดูได้ที่ลิ้ง pdf) ถ้าได้ต้องทำยังงัย
4. ต่อ 5.1 ยังงัย ในเมื่อ มันเป็นแจ๊คเสียบอันเล้กมาแค่ช่องเดียว
5. ตัวนี้สามารถ mod driver ได้หรือไม่ ถ้าได้ทำยังงัย
ขอขอบคุณทุกท่านที่มาตอบ
http://aphnetworks.com/reviews/asus_xonar_u1/2
