ช่วยไปส่ง @5.2 ทีคับ กับ P67A UD3 B3
  • #16
    เมพ ขิงๆ ได้ 5.2 GHz ไวไว
    แถมบลูสกรีน Code ให้นะ
    0x101 = increase vcore
    0x124 = increase/decrease QPI/VTT first, if not increase/decrease vcore...have to test to see which one it is
    on i7 45nm, usually means too little VVT/QPI for the speed of Uncore
    on i7 32nm SB, usually means too little vCore
    0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
    0x1A = Memory management error. It usually means a bad stick of Ram. Test with Memtest or whatever you prefer. Try raising your Ram voltage
    0x1E = increase vcore
    0x3B = increase vcore
    0x3D = increase vcore
    0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage
    0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
    0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
    0x109 = Not enough or too Much memory voltage
    0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
    0x7E = Corrupted OS file, possibly from overclocking. Run sfc /scannow and chkdsk /r
    อันนี้ดีมากๆครับ ^^
