[ LinX Premiere League 2011 ] แข่ง LinX 4.0Ghz ฤดูกาล 2554
ขเยิบตำแหน่งซักหน่อยไม่ได้เขยิบซะนาน
i5-2500k
Asus P8P67 B3
ThermalTake Toughpower XT 875W
G.SKILL DDR3 8GB XL 1600(4GBx2)
GIGABYTE GTX460 1GB OC
WD10EALX
Zalman CNPS10X Quiet
Thanks: ฝากรูป ประกันรถยนต์
Thanks: ฝากรูป ประกันรถยนต์Last edited by birtbirt_p; 7 Jun 2011, 04:30:46.
ช่วยดูให้หน่อยครับ
Intel(R) LINPACK 64-bit data - LinX 0.6.4
Current date/time: Tue Jun 07 15
08 2011
CPU frequency: 4.000 GHz
Number of CPUs: 4
Number of threads: 4
Parameters are set to:
Number of tests : 1
Number of equations to solve (problem size) : 19514
Leading dimension of array : 19528
Number of trials to run : 25
Data alignment value (in Kbytes) : 4
Maximum memory requested that can be used = 3048949792, at the size = 19514
============= Timing linear equation system solver =================
Size LDA Align. Time(s) GFlops Residual Residual(norm)
19514 19528 4 86.692 57.1523 3.852232e-010 3.589750e-002
19514 19528 4 86.164 57.5031 3.852232e-010 3.589750e-002
19514 19528 4 88.632 55.9018 3.852232e-010 3.589750e-002
19514 19528 4 85.995 57.6158 3.852232e-010 3.589750e-002
19514 19528 4 85.925 57.6625 3.852232e-010 3.589750e-002
19514 19528 4 85.929 57.6602 3.852232e-010 3.589750e-002
19514 19528 4 86.039 57.5861 3.852232e-010 3.589750e-002
19514 19528 4 85.997 57.6146 3.852232e-010 3.589750e-002
19514 19528 4 88.416 56.0383 3.852232e-010 3.589750e-002
19514 19528 4 85.963 57.6372 3.852232e-010 3.589750e-002
19514 19528 4 85.930 57.6596 3.852232e-010 3.589750e-002
19514 19528 4 85.975 57.6289 3.852232e-010 3.589750e-002
19514 19528 4 88.524 55.9699 3.852232e-010 3.589750e-002
19514 19528 4 85.914 57.6701 3.852232e-010 3.589750e-002
19514 19528 4 86.085 57.5552 3.852232e-010 3.589750e-002
19514 19528 4 88.492 55.9897 3.852232e-010 3.589750e-002
19514 19528 4 86.063 57.5700 3.852232e-010 3.589750e-002
19514 19528 4 85.980 57.6257 3.852232e-010 3.589750e-002
19514 19528 4 85.968 57.6338 3.852232e-010 3.589750e-002
19514 19528 4 85.966 57.6353 3.852232e-010 3.589750e-002
19514 19528 4 88.356 56.0763 3.852232e-010 3.589750e-002
แบบนี้ถือว่า สเถียนไหมครับ
CPU CORE i5 760 LGA1156 2.80 GHz 2.5 GT/s L3 8MBOriginally posted by mazaki01 View Postสเปคเครื่องอะไรคับ
Main boards GIGABYTE P55A-UD3P LGA1156 P55 DDR3 CF USB3 SATA3
GRAPHIC CARD GIGABYTE GTX460 1GB GDDR5 256BIT
RAM G-SKILL RIPJAWS RM 4GB(2X2) 1600 MHz CL 7-8-7-24
HARDDISK WD 1002 FAEX 1 TB,SATA III,64 MB,NCQ,BLACK
POWER SUPPLY POWEREX GREEN80+ 750W
CPU COOLER Tuniq 120 ex
ลองเพิ่มไฟ QPI/VTT เข้าไปอีกหน่อย แล้วเทสดูว่าหายไหมOriginally posted by skmbz View PostCPU CORE i5 760 LGA1156 2.80 GHz 2.5 GT/s L3 8MB
จำไม่ได้ว่าเคยเล่นที่ค่าเท่าไร ยังไงไปไล่ดูกระทู้ LinX ของ 2553 ด้วยคับ
QPI/VTT 1.230vOriginally posted by mazaki01 View Postลองเพิ่มไฟ QPI/VTT เข้าไปอีกหน่อย แล้วเทสดูว่าหายไหม
QPI/VTT 1.250v
QPI/VTT 1.270v
QPI/VTT 1.290v
QPI/VTT 1.310v
QPI/VTT 1.330v
QPI/VTT 1.350v
ลองเลือกให้หน่อยครับ ว่า ตัวไหนนิ่ง
ขอคำแนะนำหน่อยจ้าาา
