ช่วยชี้แนะ oc สำหรับ i5 760+ p55a-ud7+ kingston hyperx2000 cl9 ด้วยเถิดครับ
  • ช่วยชี้แนะ oc สำหรับ i5 760+ p55a-ud7+ kingston hyperx2000 cl9 ด้วยเถิดครับ
    ขอรบกวนผู้รู้ช่วยชี้แนะด้วยเถิดครับ
    ว่าจะสามารถตั้งค่าอย่างไรให้ดีขึ้น
    เพื่อให้ใช้ไฟ vcore ลดลงได้อีก
    ผมเคยลองลดไฟแล้ว
    เช่น 1.325,1.360 แล้ว
    แต่ทดสอบ linx 20 รอบ mem all ไม่ผ่านน่ะครับ
    ช่วยหน่อยนะครับ
    จะขอบคุณมากครับ..อิๆ
    ปัจจุบันผมตั้งค่า ดังนี้
    CPU Clock Ratio [20X]
    CPU Frequency 4000MHz
    Spread Spectrum [Disabled]
    BLCK Frequency [200]
    QPI Clock Ratio [auto]
    System Memory Multiplier [10.0]
    Memory Frequency (MHz) 200
    PCI Express Frequency [auto]
    CPU Clock Drive [900mV]
    PCI Express Clock Drive [900mV]
    CPU Clock Skew [0ps]
    Intel Turbo Boost Tech. [Disabled]
    CPU Cores Enabled [All]
    CPU Multi-Threading [Enabled]
    CPU Enhanced Halt (C1E) [Disabled]
    C3/C6/C7 State Support [enabled]
    CPU Thermal Monitor [Enabled]
    CPU EIST Function [Disabled]
    Bi-Directional PROCHOT [Enabled]
    Extreme Memory Profile (X.M.P.) [Disabled]
    System Memory Multiplier (SPD) [10.0]
    Memory Frequency (MHz) 2000
    Performance Enhance (SPD) [Turbo]
    DRAM Timing Selectable (SPD) [quick]
    Channel Interleaving 6 [Auto]
    Rank Interleaving 4 [Auto]
    Channel A Timing Settings:
    Cas Latency Time [9]
    tRCD [10]
    tRP [9]
    tRAS [27]
    tRC [Auto]
    tRRD [Auto]
    tWTR [Auto]
    tWR [Auto]
    tWTP [Auto]
    tWL [Auto]
    tRFC [74]
    tRTP [Auto]
    tFAW [Auto]
    Command Rate (CMD) [1]
    B2B Cas Delay [Auto]
    Round Trip Latency [Auto]
    Channel B Timing Settings:
    tRCD [10]
    tRP [9]
    tRAS [27]
    tRC [Auto]
    tRRD [Auto]
    tWTR [Auto]
    tWR [Auto]
    tWTP [Auto]
    tWL [Auto]
    tRFC [74]
    tRTP [Auto]
    tFAW [Auto]
    Load-Line Calibration [level 1]
    CPU Vcore [1.37500v]
    QPI/Vtt Voltage [1.40000v]
    PCH Core [1.05000]
    CPU PLL [normal]
    DRAM Voltage [1.64000]
    DRAM Termination [Normal]
    Ch-A Data VRef [Normal]
    Ch-B Data VRef [Normal]
    Ch-A Address VRef [Normal]
    Ch-B Address VRef [Normal]
    Isochronous Support [Enabled]
    Virtualization Technology [enabled]
    i5 760 ( L020B242 )
    PROLIMATECH AMAGEDDON
    +ARCTIC COOLING MX-2+
    TT SMART FAN CASE II 120MM. 1 ตัว เป่าเข้าซิ้งค์
    GIGABYTE P55A-UD7
    KINGSTON HYPERX 2000 CL 9-10-9-27 2X2GB
    MAXTOR IDE 160 GB
    WD SATA III 2X1 TB
    ASUS GTX 460 DIRECTCU TOP 1 GB
    AUDIGY 4 PRO
    ASUS DVD/CD WRITER
    ENERMAX LIBERTY 620W
    SILVERSTON TJ07 SILVER
    (fan 120mm 2 ตัว เป่าฮาร์ดดิสก์
    tt smart fan case ii 120mm 2 ตัว ดูดออกด้านบนเคส
    fan 92mm 2 ตัว ดูดออกด้านหลังเคส)
    CPU Vcore [1.32500v]
    QPI/Vtt Voltage [1.30000v]
    DRAM Voltage [1.7000v]
      ขอบคุณครับที่กรุณาชี้แนะ
      แต่...แหะๆ...
      ไม่ได้ผลครับ...อย่าว่าแต่ผ่าน linx เลยครับ
      แค่บู๊ตเข้าหน้าจอไบออส...ยังไม่ได้เลยครับ
      ผมเลยต้องกดปุ่ม clear cmos ที่เมนบอร์ด
      T.T
        ผมเคยลองลดไฟแล้ว
        ช่วยหน่อยนะครับ
        PCI Express Frequency [auto] น่าจะ fix ที่ 100 - 101 ตามสังคมนิยม
        CPU Enhanced Halt (C1E) [Disabled] ผมชอบ [Enable] เพราะ LinX มันจะมีช่วงให้ CPU พัก...ช่วงต้น-และท้ายลูป
        Performance Enhance (SPD) [Turbo] ถ้าไม่ OC ใช่...แต่ถ้า OC ให้ตั้ง [Standard] ตามคำแนะนำของ bios
        tRCD [10]
        tRP [9]
        tRAS [27]
        tRC [Auto]
        tRRD [Auto]
        tWTR [Auto]
        tWR [Auto]
        tWTP [Auto]
        tWL [Auto]
        tRFC [74]
        tRTP [Auto]
        tFAW [Auto]
        tRCD [10]
        tRP [9]
        tRAS [27]
        tRC [Auto]
        tRRD [Auto]
        tWTR [Auto]
        tWR [Auto]
        tWTP [Auto]
        tWL [Auto]
        tRFC [74]
        tRTP [Auto]
        tFAW [Auto]
        Load-Line Calibration [level 1] น่าจะตั้ง [Level 2] ไฟจะนิ่งกว่า 1
        PCH Core [1.05000]
        CPU PLL [normal] น่าจะลองเปลี่ยนเป็น [Auto] หรือไม่ก็ 1.8 - 1.82
        DRAM Voltage [1.64000] ผมเองจะตั้งมากกว่า 1.65 - 1.72 เมื่อต้องกดค่า CL ให้ต่ำ
        DRAM Termination [Normal] ลองตั้งเป็น [Auto] หรือไม่ก็มากกว่าค่าทางด้านซ้ายมือนิดหน่อย (เผื่อไว้)
        Ch-A Data VRef [Normal] ลองตั้งเป็น [Auto] หรือไม่ก็มากกว่าค่าทางด้านซ้ายมือนิดหน่อย (เผื่อไว้)
        Ch-B Data VRef [Normal] ลองตั้งเป็น [Auto] หรือไม่ก็มากกว่าค่าทางด้านซ้ายมือนิดหน่อย (เผื่อไว้)
        Ch-A Address VRef [Normal] ลองตั้งเป็น [Auto] หรือไม่ก็มากกว่าค่าทางด้านซ้ายมือนิดหน่อย (เผื่อไว้)
        Ch-B Address VRef [Normal] ลองตั้งเป็น [Auto] หรือไม่ก็มากกว่าค่าทางด้านซ้ายมือนิดหน่อย (เผื่อไว้)
        i5 760 ( L020B242 )
        GIGABYTE P55A-UD7
        MAXTOR IDE 160 GB
        WD SATA III 2X1 TB
        AUDIGY 4 PRO
        ASUS DVD/CD WRITER
        CPU แต่ละตัวมันตั้งค่าไฟต่าง ๆ ไม่เท่ากัน...ผมว่าท่านคงต้องลองเองครับ...
        ไม่มีใครสามารถบอกค่าไฟต่าง ๆ ได้....นอกจากท่านจะค่อย ๆ ลองเอง...
        ผมว่าท่านก็เก่งแล้วครับ...แต่ขอให้ใจเย็น ๆ ....หมั่นกด Del แล้วท่านจะประจักษ์ด้วยตัวเอง
        ต้องบอกก่อนว่าผมเองยังงงๆ กับ GA P55A-UD7 อยู่เลย ตอนที่ได้ 4.4 ผมใช้ GA P55-UD6
        พอเปลี่ยนมาเป็น GA P55A-UD7 ไปได้ 4.2 เอง (ยังไม่ได้จับกดน้ำ)
        อย่าเชื่อผม....ท่านต้องลองเอาเองครับ
          มหัศจรรย์ 1156 ครับ เปลี่ยนบอร์ด เปลี่ยนRam ไฟเดิมก็ใช้ไม่ได้แล้ว 55+
            ทำตามแล้ว และลองลดไฟ vcore
            ปรากฏว่า บางครั้ง ก็บู๊ตไม่เข้า bios
            หรือไม่ก็ ทดสอบ linx ไม่ผ่านครับ
              อย่างนี้น่าจะแสดงว่า....ท่านต้องกลับไปใช้ค่าเดิมที่ดีที่สุด...เพราะเป็นค่าไฟที่ต่ำที่สุดที่ทำให้ระบบเสถียรในระดับหนึ่ง
              ต่อจากนี้ท่านคงต้องดูจากการใช้งานจริง....ถ้าเกิดความไม่เสถียรคงต้องดูเรื่องความร้อนของระบบเป็นอันดับแรก
              หรือท่านอาจจะต้องเพิ่มไฟบางตัวขึ้นอีกเล็กน้อย....หลักๆ ก็ไฟ CPU ; PQI ; DRam ตามลำดับ
