CPU-Z version 1.38
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name Intel Celeron 320
Codename Prescott
Specification Intel(R) Celeron(R) CPU 2.40GHz
Package Socket 478 mPGA (platform ID = 2h)
CPUID F.4.1
Extended CPUID F.4
Core Stepping E0
Technology 90 nm
Core Speed 2397.4 MHz (18.0 x 133.2 MHz)
Rated Bus speed 532.8 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3
L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 256 KBytes, 4-way set associative, 64-byte line size
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001006h
Max CPUID level 00000005h
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x00000005 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F41 0x00010800 0x0000441D 0xBFEBFBFF
0x00000002 0x605B5101 0x00000000 0x00000000 0x003C7040
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000121 0x01C0003F 0x0000001F 0x00000000
0x00000004 0x00000143 0x00C0103F 0x000001FF 0x00000000
0x00000005 0x00000040 0x00000040 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x20202020
0x80000003 0x65746E49 0x2952286C 0x6C654320 0x6E6F7265
0x80000004 0x20295228 0x20555043 0x30342E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01004040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00002024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x00000017 edx = 0x000A0000 eax = 0x00000000
MSR 0x0000002C edx = 0x00000000 eax = 0x12110412
MSR 0x000001A0 edx = 0x00000000 eax = 0x208400C9
Chipset
Northbridge VIA P4M266 (VT8751) rev. 00
Southbridge VIA VT8235 rev. 00
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 4x
AGP SBA supported, enabled
Memory Type DDR
Memory Size 768 MBytes
Memory Frequency 133.2 MHz (1:1)
DRAM Interleave none
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) (0000000000000000)
Size 256 MBytes
Max bandwidth PC2700 (166 MHz)
Part number RM56D281TA-27BC
Serial number FFFFFFFF
Manufacturing date Week 23/Year 05
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 166
CAS# 2.5
RAS# to CAS# delay 3
RAS# Precharge 3
TRAS 7
DIMM #2
General
Memory type DDR
Manufacturer (ID) (7F7F7F7F7FDC0000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number HEXON
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 3 3 4
RAS# Precharge 3 3 4
TRAS 6 7 8
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0A 01 40 00 04 60 70 00 82 08 00 01
10 0E 04 08 01 02 20 00 75 70 00 00 48 30 48 2A 40
20 80 80 45 45 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C
40 00 00 00 00 00 00 00 00 00 52 4D 35 36 44 32 38
50 31 54 41 2D 32 37 42 43 FF FF FF FF FF 05 17 FF
60 FF FF FF FF 52 30 35 44 31 37 43 4D 36 38 FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00
Dump Module #2
00 80 08 07 0D 0B 01 40 00 04 50 70 00 82 08 00 01
10 0E 04 1C 01 02 20 C0 60 70 75 75 48 28 48 28 80
20 60 60 40 40 00 00 00 00 00 3C 46 20 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 CC
40 7F 7F 7F 7F 7F DC 00 00 00 48 45 58 4F 4E 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 20 11 06 02 11 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Sensor Chip Winbond W83697HF
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3148
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x08
Header 0x00
PCI header
Address 0 (memory) 0xE0000000
Subvendor ID 0x1849
Subsystem ID 0x3148
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Version 2.0
Status enabled
Transfer rate 4x (max 4x)
Queue lenght 173 (max 32)
Dump
00 01 02 03 04 05 06 07 08 09 0A 0B
02 C0 20 00 07 02 00 1F 04 03 00 00
Power Management Capability
Version 1.1
Dump
01 00 02 00 00 00 00 00
Dump
00 06 11 48 31 06 00 30 22 00 00 00 06 00 08 00 00
10 08 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 48 31
30 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00
40 00 18 88 80 82 44 00 00 99 99 88 10 82 44 00 00
50 E8 BF 6C 88 E6 05 30 30 EE 00 10 10 30 30 30 30
60 0A AA 00 20 E4 99 40 28 44 0D 43 10 40 04 00 00
70 82 C8 00 01 40 01 10 00 01 00 00 00 00 00 00 07
80 0F E4 00 00 80 78 00 00 03 00 06 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 02 C0 20 00 07 02 00 1F 04 03 00 00 2D 02 04 00
B0 78 AC 10 9B 40 00 00 00 88 00 00 04 00 00 00 80
C0 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 08 00 00 00 00 70 38 02 00
E0 00 00 42 1A 00 00 89 00 40 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 83 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0xB091
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Capabilities
Version 1.1
Dump
01 00 02 02 00 00 00 00
Dump
00 06 11 91 B0 07 01 30 22 00 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 00
20 E0 DD E0 DF D0 CD C0 DD 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 0C 00
40 83 47 00 44 24 72 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Communication Device
bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x14F1
Model ID 0x2F00
Revision ID 0x01
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xDFFF0000
Address 1 (port) 0x0000EC00
Subvendor ID 0x14F1
Subsystem ID 0x2005
Int. Line 0x12
Int. Pin 0x01
Capabilities
Version 1.1
Dump
01 00 22 C0 00 00 00 00
Dump
00 F1 14 00 2F 07 00 90 02 01 00 80 07 00 20 00 00
10 00 00 FF DF 01 EC 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 F1 14 05 20
30 00 00 00 00 40 00 00 00 00 00 00 00 12 01 00 00
40 01 00 22 C0 00 00 00 00 52 12 01 00 01 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 4 (port) 0x0000E000
Subvendor ID 0x1849
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x01
Capabilities
Version 1.1
Dump
01 00 C2 FF 00 00 00 00
Dump
00 06 11 38 30 17 00 10 02 80 00 03 0C 08 20 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 E0 00 00 00 00 00 00 00 00 00 00 49 18 38 30
30 00 00 00 00 80 00 00 00 00 00 00 00 15 01 00 00
40 40 12 03 00 00 00 00 00 00 0B 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 C2 FF 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00
bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 4 (port) 0x0000E400
Subvendor ID 0x1849
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x02
Capabilities
Version 1.1
Dump
Dump
20 01 E4 00 00 00 00 00 00 00 00 00 00 49 18 38 30
30 00 00 00 00 80 00 00 00 00 00 00 00 15 02 00 00
bus 0 (0x00), device 16 (0x10), function 2 (0x02)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 4 (port) 0x0000E800
Subvendor ID 0x1849
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x03
Capabilities
Version 1.1
Dump
Dump
20 01 E8 00 00 00 00 00 00 00 00 00 00 49 18 38 30
30 00 00 00 00 80 00 00 00 00 00 00 00 15 03 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 16 (0x10), function 3 (0x03)
Common header
Vendor ID 0x1106
Model ID 0x3104
Revision ID 0x82
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xDFFEFF00
Subvendor ID 0x1849
Subsystem ID 0x3104
Int. Line 0x15
Int. Pin 0x04
Capabilities
Version 1.1
Dump
Dump
00 06 11 04 31 17 00 10 02 82 20 03 0C 08 20 00 00
10 00 FF FE DF 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 04 31
30 00 00 00 00 80 00 00 00 00 00 00 00 15 04 00 00
40 00 00 03 00 00 00 00 00 80 10 00 09 00 00 00 00
50 00 5A 04 80 00 00 00 00 04 0B 88 88 53 88 00 00
60 20 20 01 00 00 00 00 00 01 00 00 00 00 00 00 C0
F0 00 00 00 00 00 00 88 00 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3177
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3177
Int. Line 0x00
Int. Pin 0x00
Capabilities
Version 1.1
Dump
Dump
00 06 11 77 31 87 00 10 02 00 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 77 31
30 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
40 44 00 F8 00 00 00 00 00 8C 20 00 00 44 00 08 08
50 81 1D 09 00 00 00 00 00 43 00 FF 01 00 00 04 08
60 00 00 00 00 10 00 02 04 00 00 00 00 00 00 00 00
70 49 18 77 31 00 00 00 00 00 00 00 00 20 00 00 00
80 20 84 59 00 9A 00 00 00 01 08 00 00 04 18 00 00
90 00 39 80 00 B0 C5 0F 00 10 16 00 00 00 00 00 00
D0 01 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 04 01 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 19 00 00 00 00 00 01 00 00 00
IDE Controller
bus 0 (0x00), device 17 (0x11), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x0571
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x0000FC00
Subvendor ID 0x1849
Subsystem ID 0x0571
Int. Line 0xFF
Int. Pin 0x01
Capabilities
Version 1.1
Dump
Dump
00 06 11 71 05 07 00 90 02 06 8A 01 01 00 20 00 00
20 01 FC 00 00 00 00 00 00 00 00 00 00 49 18 71 05
30 00 00 00 00 C0 00 00 00 00 00 00 00 FF 01 00 00
40 1B F2 09 05 18 1C C0 00 20 20 20 20 FF 00 B6 B6
50 E6 E6 F0 F1 0C 00 00 00 A8 A8 A8 A8 00 00 00 00
60 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00
70 02 01 00 00 00 00 00 00 02 01 00 00 00 00 00 00
80 F8 6E F4 02 00 00 00 00 C8 C9 F2 02 00 00 00 00
D0 06 00 71 05 49 18 71 05 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 00
Audio device
bus 0 (0x00), device 17 (0x11), function 5 (0x05)
Common header
Vendor ID 0x1106
Model ID 0x3059
Revision ID 0x50
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000DC00
Subvendor ID 0x1849
Subsystem ID 0x3059
Int. Line 0x16
Int. Pin 0x03
Capabilities
Version 1.1
Dump
01 00 02 06 00 00 00 00
Dump
00 06 11 59 30 01 00 10 02 50 00 01 04 00 00 00 00
10 01 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 59 30
30 00 00 00 00 C0 00 00 00 00 00 00 00 16 03 00 00
40 01 CD 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 01 00 02 06 00 00 00 00 00 00 00 00 00 00 00 00
D0 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Ethernet Controller
bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3065
Revision ID 0x74
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000D800
Address 1 (memory) 0xDFFEFE00
Subvendor ID 0x1849
Subsystem ID 0x3065
Int. Line 0x17
Int. Pin 0x01
Capabilities
Version 1.1
Dump
01 00 02 FE 00 00 00 00
Dump
00 06 11 65 30 17 00 10 02 74 00 00 02 08 20 00 00
10 01 D8 00 00 00 FE FE DF 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 65 30
30 00 00 00 00 40 00 00 00 00 00 00 00 17 01 03 08
40 01 00 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 80 04 00 00 00 00 00 00 00 00 00 00 00 02
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0322
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0xF8
Header 0x00
PCI header
Address 0 (memory) 0xDE000000
Address 1 (memory) 0xD0000000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x10
Int. Pin 0x01
Capabilities
Version 1.1
Dump
01 44 02 00 00 00 00 00
AGP Capability
Version 3.0
Status enabled
Queue lenght 1 (max 32)
Dump
02 00 30 00 17 02 00 1F 04 03 00 1F
Dump
00 DE 10 22 03 07 00 B0 02 A1 00 00 03 00 F8 00 00
10 00 00 00 DE 08 00 00 D0 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 05 01
40 00 00 00 00 02 00 30 00 17 02 00 1F 04 03 00 1F
50 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00
60 01 44 02 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version P2.40
date 09/07/2004
DMI System Information
manufacturer unknown
product M266A.
version 3.0X
serial 00000000
UUID 00000000-00000000-00000000-00000000
DMI Baseboard
vendor unknown
model M266A.
revision 3.0X
serial 00000000
DMI System Enclosure
chassis type Desktop
chassis serial 00000000
DMI Processor
manufacturer Intel
model Intel(R) Pentium(R) 4 Processor
clock speed 2400.0MHz
FSB speed 133.0MHz
multiplier 18.0x
DMI Memory Controller
correction 32-bit ECC
Max module size 1024MBytes
DMI Memory Module
designation DIMM1
size 256MBytes (single bank)
DMI Memory Module
designation DIMM2
size 512MBytes (single bank)
DMI Memory Module
designation DIMM3
DMI Memory Module
designation DIMM4
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Port Connector
designation PS2 KEYBOARD (internal)
designation PS2 Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS2 MOUSE (internal)
designation PS2 Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation VGA (internal)
designation VGA Port (external)
port type Video Port
connector DB-15 female
DMI Port Connector
designation LPT (internal)
designation LPT Port (external)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation USB (internal)
designation Rear USB 0 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation Rear USB 1 (external)
port type USB
DMI Port Connector
designation Front USB 2 (external)
port type USB
DMI Port Connector
designation Front USB 3 (external)
port type USB
DMI Port Connector
designation ETHERNET (internal)
designation ETHERNET (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation LINE-OUT (internal)
designation LINE-OUT (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation LINE-IN (internal)
designation LINE-IN (external)
DMI Port Connector
designation MICROPHONE (internal)
designation MICROPHONE (external)
DMI Port Connector
designation GAME (internal)
designation Game Port (external)
port type MIDI Port
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Resources
Port I/O Space, BA=0xCF8, size=0x8
Port I/O Space, BA=0xEC00
Port I/O Space, BA=0xE000
Port I/O Space, BA=0xE400
Port I/O Space, BA=0xE800
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0xDC00
Port I/O Space, BA=0xD800
Port I/O Space, BA=0x808, size=0x4
Port I/O Space, BA=0x400
Memory I/O Space, BA=0xE0000000
Memory I/O Space, BA=0xDFFF0000
Memory I/O Space, BA=0xDFFEFF00
Memory I/O Space, BA=0xDFFEFE00
Memory I/O Space, BA=0xDE000000
Memory I/O Space, BA=0xD0000000
Memory I/O Space, BA=0xFEE00000, size=0x1000
SMBus I/O Space, BA=0x400
PCI I/O space, BA=0xCF8, size=0x8
ปกติ CPU จะร้อนอยู่ ประมาณ 70 - 76 อ่ะค่ะ
เมนบอร์ด 50 - 60 องศา (เจอบ่อย 52)
HDD1 40
HDD2 40
ขอคำแนะนำในการ oc หน่อยนะค่ะ
CPU-Z version 1.38
Processors Map
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Number of cores 1
Codename Prescott
CPUID F.4.1
Extended CPUID F.4
Core Stepping E0
Technology 90 nm
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Type 01001006h
Chipset
AGP Revision 3.0
Memory Type DDR
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type DDR
Size 256 MBytes
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 166
CAS# 2.5
RAS# Precharge 3
TRAS 7
DIMM #2
General
Memory type DDR
Size 512 MBytes
Part number HEXON
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
CAS# 2.0 2.5 3.0
TRAS 6 7 8
Dump Module #1
Dump Module #2
Monitoring
PCI Device List
Host Bridge
Common header
Vendor ID 0x1106
Model ID 0x3148
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x08
Header 0x00
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3148
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Version 2.0
Status enabled
Dump
Version 1.1
Dump
Dump
PCI to PCI Bridge
Common header
Vendor ID 0x1106
Model ID 0xB091
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Capabilities
Version 1.1
Dump
Dump
Common header
Vendor ID 0x14F1
Model ID 0x2F00
Revision ID 0x01
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Subvendor ID 0x14F1
Subsystem ID 0x2005
Int. Line 0x12
Int. Pin 0x01
Capabilities
Version 1.1
Dump
Dump
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x01
Capabilities
Version 1.1
Dump
Dump
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x02
Capabilities
Version 1.1
Dump
Dump
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x03
Capabilities
Version 1.1
Dump
Dump
Common header
Vendor ID 0x1106
Model ID 0x3104
Revision ID 0x82
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3104
Int. Line 0x15
Int. Pin 0x04
Capabilities
Version 1.1
Dump
Dump
PCI to ISA Bridge
Common header
Vendor ID 0x1106
Model ID 0x3177
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3177
Int. Line 0x00
Int. Pin 0x00
Capabilities
Version 1.1
Dump
Dump
IDE Controller
Common header
Vendor ID 0x1106
Model ID 0x0571
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Subvendor ID 0x1849
Subsystem ID 0x0571
Int. Line 0xFF
Int. Pin 0x01
Capabilities
Version 1.1
Dump
Dump
Audio device
Common header
Vendor ID 0x1106
Model ID 0x3059
Revision ID 0x50
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3059
Int. Line 0x16
Int. Pin 0x03
Capabilities
Version 1.1
Dump
Dump
Ethernet Controller
Common header
Vendor ID 0x1106
Model ID 0x3065
Revision ID 0x74
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Subvendor ID 0x1849
Subsystem ID 0x3065
Int. Line 0x17
Int. Pin 0x01
Capabilities
Version 1.1
Dump
Dump
VGA Controller
Common header
Vendor ID 0x10DE
Model ID 0x0322
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0xF8
Header 0x00
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x10
Int. Pin 0x01
Capabilities
Version 1.1
Dump
AGP Capability
Version 3.0
Status enabled
Dump
Dump
DMI
DMI BIOS
version P2.40
date 09/07/2004
product M266A.
version 3.0X
serial 00000000
DMI Baseboard
vendor unknown
model M266A.
revision 3.0X
serial 00000000
DMI Processor
manufacturer Intel
FSB speed 133.0MHz
multiplier 18.0x
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Memory Module
designation DIMM4
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Port Connector
connector PS/2
DMI Port Connector
connector PS/2
DMI Port Connector
DMI Port Connector
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
connector RJ-45
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
port type MIDI Port
Software
Resources
HDD1 40
HDD2 40
