ปรับ Overclock ใน ฺBios ครับ ของ i7 ครับ
  • ปรับ Overclock ใน ฺBios ครับ ของ i7 ครับ
    Advanced CPU Features:
    CPU Clock Ratio ................................19 (จะลดหรือเพิ่มก็แล้วแต่ครับ)
    Intel(R) Turbo Boost Tech .................Disabled
    CPU Cores Enabled ..........................All
    CPU Multi Threading ..........................Enabled
    CPU Enhanced Halt (C1E) ................. Disabled
    C3/C6/C7 State Support ................... Disabled
    CPU Thermal Monitor .......................Disabled
    CPU EIST Function ............................ Disabled
    Virtualization Technology
    Bi-Directional PROCHOT ....................Enabled
    Uncore & QPI Features:
    QPI Link Speed ................................x36 (7.59 ghz)
    Uncore Frequency ..........................x16 (3376 mhz)
    Isonchronous Frequency ............... Enabled
    Standard Clock Control:
    Base Clock (BCLK) Control .................. [Enable] Enabled
    BCLK Frequency (MHz) .........................211 (จะลดหรือเพิ่มก็แล้วแต่ครับ)
    PCI Express Frequency (MHz) ............. 101
    Advanced Clock Control:
    CPU Clock Drive ..............................700
    PCI Express Clock Drive ................ 700
    CPU Clock Skew ............................ 0
    IOH Clock Skew ............................. 0
    Advanced DRAM Features:
    Performance Enhance .......................... Standard
    Extreme Memory Profile (X.M.P) ........... Disabled
    System Memory Multiplier (SPD) ........... 8x
    DRAM Timing Selectable (SPD) ............. Quick
    Channel A + B + C
    Channel A Timing Settings:
    ##Channel A Standard Timing Control##
    CAS Latency Time ..................9
    tRCD ......................................9
    tRP ........................................9
    tRAS ......................................24
    CR..........................................1
    Advanced Voltage Control:
    Load Line Calibration .................... Level 1
    CPU Vcore 1.08750 ........................ Normal
    Dynamic Vcore Adjust (DVID)............[0.000] +0.200
    QPI/VTT Voltage 1.200v ................ 1.240v
    CPU PLL 1.800v ..............................[1.80] 1.84
    PCIE 1.500v ................................... Normal
    QPI PLL 1.100v .............................. Normal
    IOH Core 1.100v ............................ Normal
    ICH I/O 1.500v ............................... Normal
    ICH Core 1.1v ................................ Normal
    DRAM
    DRAM Voltage 1.500v ................ 1.60v
    DRAM Termination 0.750v........... 0.80
    Ch-A Data VRef. 0.750v ............... 0.80
    Ch-B Data VRef. 0.750v ............... 0.80
    Ch-C Data VRef. 0.750v ................ 0.80
    Ch-A Address VRef. 0.750v ........... 0.80
    Ch-B Address VRef. 0.750v ........... 0.80
    Ch-C Address VRef. 0.750v ........... 0.80
    พอจะใช้ได้หรือเปล่าครับ ปรับแต่งตรงไหนเพิ่มเติ่ม แนะนำเพิ่มเติ่มก็ได้ครับ เอามาฝากครับ ของเว็ปต่างประเทศครับ
    Gigabyte -..-?
      ลืม ของ Gigabyte ครับ
        ไม่เอาของ asus บ้างล่ะท่าน.....
        ขอบคุณล่วงหน้า.........อิอิ
