This article introduces how to rip a dvd disk and how to burn videos to dvd disk.
With DVD Ripper you can rip your dvd to popular video such as AVI/WMV/MP4/MPG/FLV/MOV/DIVX/XVID/MP3/AAC/AC3/WMA/WAV
With DVD Creator you can burn your popular video to your dvd disk to save it.
Part 1: How to Rip DVD to AVI/WMV/MP4/MPG/FLV/MOV/DIVX/XVID/MP3/AAC/AC3/WMA/WAV...
Step 0: Free download Aiseesoft DVD Ripper, install and run it.
Step 1:Click "Load DVD" button to load your DVD.
This professional DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
Step 2: Select the output video format you want from the “Profile” drop-down list.
Step 3: Click the "Start" button to start your conversion and In a short while it will be finished.
Tips:
1: Capture your favorite picture.
If you like the current image of the video you can use the “Snapshot” opinion.
2: Merge videos into one file.
Just check the "merge into one file" option if you want to merge the selected contents into one file As default the merged file is named after the first selected file (either a title or a chapter)
3: Video Effecting
Click the "Effect" button and a dialog pops up, you can set your video effect here.
4: Trim video
Click the "Trim" button and a dialog pops up. You can set the time of the clip here. You can rip any your DVD to YouTube and Myspace supported FLV formats easily. You can also upload only a clip of your DVD movie
5: Crop video
There are two methods available to crop your video: You can crop your video by selec your video mode or set crop values.
Part 2: How to Burn AVI,WMV,3GP,MPEG,MP4,DAT,VOB,ASF,MPG to DVD.
Step 1: Download Joboshare DVD Creator,install and run it.
Step 2: Insert a DVD+R or DVD-R, or DVD+RW or DVD-RW disc in the DVD RW drive.
Step 3: Add Video files
Run the Joboshare DVD Creator and add the video files that want to convert by clicking "Add Video Files" or "Add Video Folder" option under the "File" menu. Or you can click the "Add Video Files" or "Add Video Folder" button in the main interface.
After the video files have been added, it can be displayed in the list box in the main interface and you can set the relevant parameters according to your needs.
You can customize the output aspect resize method by selecting the file's title and clicking the "Resize Method" combobox, and then there are three choices for you to set:
Letterbox: add black stripes to fit the output aspect ratio
Pan and Scan: crop frame to fit the output aspect ratio.
Full Screen: stretch and compress frame to fit the output aspect ratio.
Step 4: Select background music,DVD menu, and background picture.
You can edit the DVD menu that you are interested in using the picture and music in your local computer. Click the "Edit" button and set the related information in the pop-up window, such as selecting the check box before "Background Music" or "Background Picture", and adding related picture or music file from your local computer etc.
Step 5: Choose Destination.
Click the "Destination" combobox to choose the form of the output file. You can choose to make DVD disc directly, or you can choose to save DVD folder or ISO files in your local computer for backup.
Step 6: Start burning DVD.
You can start to burn the video file by clicking "Start Burn" button in the main interface.
Set the modes of the output file as "NTSC" or "PAL" by click the "Preferences" item under the "Tools" Menu before burning.
Hot Searches:
Best DVD Cloner | DRM Media Converter | Free HD Video Converter | iskysoft dvd creator for mac | avcware dvd audio extractor
Tips:
3: Video Effecting
4: Trim video
5: Crop video
Hot Searches:
