จากข้อมูลด้านล่าง ... ผมทำอะไรผิด ไม๊ครับนี่
CPU Properties:
CPU Type DualCore Intel Core 2 Duo E4600
CPU Alias Conroe-2M
CPU Stepping M0
Engineering Sample No
CPUID CPU Name Intel(R) Core(TM)2 Duo CPU E4600 @ 2.40GHz
CPUID Revision 000006FDh
CPU VID 1.1875 V
CPU Speed:
CPU Clock 1998.0 MHz (original: 2400 MHz)
CPU Multiplier 6x
CPU FSB 333.0 MHz (original: 200 MHz, overclock: 67%)
Memory Bus 333.0 MHz
DRAM:FSB Ratio 1:1
CPU Cache:
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2 MB (On-Die, ECC, ASC, Full-Speed)
Motherboard Properties:
Motherboard ID 07/30/2008-P31-ICH7-6A79OG0WC-00
Motherboard Name Gigabyte GA-P31-DS3L (3 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Chipset Properties:
Motherboard Chipset Intel Bearlake P31
Memory Timings 5-5-5-15 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
DIMM1: Kingston 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM2: Kingston 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Kingston 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM4: Kingston 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
BIOS Properties:
System BIOS Date 07/30/08
Video BIOS Date 10/21/08
Award BIOS Type Award Modular BIOS v6.00PG
Award BIOS Message Intel P31 BIOS for P31-DS3L F10A
DMI BIOS Version F10A
Graphics Processor Properties:
Video Adapter nVIDIA GeForce 9400 GT
GPU Code Name G96GT (PCI Express 1.0 x16 10DE / 0641, Rev C1)
GPU Clock (Geometric Domain) 594 MHz (original: 550 MHz, overclock: 8%)
GPU Clock (Shader Domain) 1512 MHz (original: 1375 MHz, overclock: 10%)
Memory Clock 399 MHz (original: 400 MHz)
CPU Properties:
CPU Alias Conroe-2M
CPU Stepping M0
CPU VID 1.1875 V
CPU Speed:
CPU Multiplier 6x
DRAM:FSB Ratio 1:1
CPU Cache:
Chipset Properties:
BIOS Properties:
