Dual Core E6300 กับ board GIGABYTE GA-EP45-UD3R Ram Corsair 2*2 Bus 800 ซิ้ง Tx 3 ครับผม
Overclock ไปเท่านี้จะพังมั้ยครับ 4.0 GHz อุณหภูมิ Core1 Temp 42 Core2 Temp 44
ถ้าต้องแก้ไขอะไรช่วยแนะนำหน่อยนะครับพอดีมือใหม่
CPU clock ratio: 9x
Fine CPU Clock Ratio [+0.5]
CPU Host Frequency (Mhz) [382]
PCI Express Frequency (Mhz) [100]
Performance Enhance [Standard]
System Memory Multiplier [2.00D]
MCH Frequency Latch [Auto]
Advance Clock Chip Control
CPU Clock Drive [800mV]
PCI Express Clock Drive [900mV]
CPU Clock Skew [0ps]
MCH Clock Skew [0ps]
Load Line Calibration [Enabled]
[Voltage]
CPU Vcore=1.3625 Volts [Manual]
CPU Termination=1.34 Volts [Manual]
CPU PLL=1.50 Volts [Auto]
CPU Reference=0.760 Volts [Auto]
[MCH/ICH]
MCH Core=1.260 Volts [Manual]
MCH Reference=0.760 Volts [Auto]
MCH/DRAM Reference=0.900000 Volts [Auto]
ICH I/O=1.500000 Volts [Auto]
ICH Core=1.100000 Volts [Auto]
[DRAM]
DRAM Voltage=2.000000 Volts [Manual]
DRAM Termination=0.900000 Volts [Auto]
Channel A Reference=0.900000 Volts [Auto]
Channel B Reference=0.900000 Volts [Auto]
DRAM Timing Control [Auto]
5 cas
5 trcd
5 trp
15 tras
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 x ]
Fine CPU Clock Ratio............................[ + .5 ]
CPU Frequency 4.00GHz............................[ 445x9.5 ]
************************************************************************************************Clock Chip Control************************************************************************************************
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 445 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
************************************************************************************************Advanced Clock Control************************************************************************************************
CPU Clock Drive..........................[800mV]
PCI Express Clock Drive................[900mV]
CPU Clock Skew..........................[0ps]
MCH Clock Skew..........................[0ps]
************************************************************************************************DRAM Performance Control************************************************************************************************
Performance Enhance.............................[ Standard ]
MCH Frequency Latch.........................[ 333 ]
System Memory Multipler.........................[ 2.00B ]
Memory Frequency 1066............................[ 890 ]
DRAM Timing Selectable..........................[Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
Leave all the advanced timings on auto for now.
************************************************************************************************Motherboard Voltage Control************************************************************************************************
Load-Line Calibration...........................[ Enable ]
CPU Vcore [ 1.1625 ]...................[ 1.375v ]
CPU Termination [ 1.20 ]...................[ 1.2v]
CPU PLL [ 1.50 ]...................[ 1.500v]
CPU Reference [ 0.760 ]...................[ 0.760v ]
MCH Core [ 1.100 ]...................[ 1.2v]
MCH Reference [ 0.760 ]...................[ 0.760v ]
MCH/DRAM Reference [ 0.900 ]...................[ 1.05v ]
ICH I/O [ 1.500 ]...................[ 1.5v ]
ICH Core [ 1.100 ]...................[ 1.1v ]
DRAM Voltage [ 1.800v]...................[2.100v]
DRAM Termination [0.900v]...................[ 1.05v ]
Channel A Reference [0.900v]................[ 1.05v ]
Channel B Reference [0.900v]................[ 1.05v ]
__________________
CPU clock ratio: 9x
[Voltage]
[MCH/ICH]
[DRAM]
5 cas
5 trcd
5 trp
15 tras
C.I.A 2 [Disabled]
__________________
