เงินไม่พอ ทำข้างเดียวก่อนได้มั้ย
AI Overclock tuner: MANUAL CPU Ratio Setting: 9.0 FSB Frequency: 500 FSB Strap to North Bridge: 400 PCI-E Frequency: 100 DRAM Frequency: DDR2-1000Mhz DRAM CLK Skew on Channel A1: AUTO DRAM CLK Skew on Channel A2: AUTO DRAM CLK Skew on Channel B1: AUTO DRAM CLK Skew on Channel B2: AUTO DRAM Timing Control: MANUAL 1st Information : CAS# Latency: 4 DRAM RAS# to CAS# Delay: 4 DRAM RAS# Precharge: 4 DRAM RAS# Activate to Precharge: 12 RAS# to RAS# Delay : AUTO Row Refresh Cycle Time: AUTO Write Recovery Time: AUTO Read to Precharge Time: AUTO 2nd Information : READ to WRITE Delay (S/D): AUTO Write to Read Delay (S): AUTO WRITE to READ Delay (D): AUTO READ to READ Delay (S): AUTO READ to READ Delay (D): AUTO WRITE to WRITE Delay (S): AUTO WRITE to WRITE Delay (D): AUTO 3rd Information : WRITE to PRE Delay: AUTO READ to PRE Delay: AUTO PRE to PRE Delay: AUTO ALL PRE to ACT Delay: AUTO ALL PRE to REF Delay: AUTO DRAM Static Read Control: Enable DRAM Read Training: Enable MEM. OC Charger: Enable AI Clock Twister: Moderate AI Transaction Booster: MANUAL Common Performance Level [9] Pull-In of CHA PH1: DISABLED Pull-In of CHA PH2: DISABLED Pull-In of CHA PH3: DISABLED Pull-In of CHA PH4: DISABLED Pull-In of CHB PH1: DISABLED Pull-In of CHB PH2: DISABLED Pull-In of CHB PH3: DISABLED Pull-In of CHB PH4: DISABLED CPU Voltage: 1.45 CPU GTL Voltage Reference (0/2): 0.640 CPU GTL Voltage Reference (1/3): 0.680 CPU PLL Voltage: 1.56 FSB Termination Voltage: 1.28 DRAM Voltage: 2.40 NB Voltage: 1.32 NB GTL Reference: 0.605 SBridge Voltage: 1.10 PCIE SATA Voltage: 1.50 Load Line Calibration: Enable CPU Spread Spectrum: Disabled PCIE Spread Spectrum: Disabled CPU Clock Skew : NORMAL NB Clock Skew : NORMAL CPU Margin Enhancement : Optimized Advance CPU Settings CPU Ratio Setting: 9.0 C1E Suppport: Disabled Max CPUID Value Limit: Disabled Intel Virtualization Tech: Disabled Vanderpool Technology: Disabled CPU TM Function: Disabled Execute Disable Bit: Disabled
