ของฝากสำหรับคนรักการโอเวอร์คล๊อกสำหรับโปรแกรมทั้งหลายทั้งปวง
This is a sticky topic.
  • #31
    ขอบคุณคับ นายท่าน..
    • #32
      ขอบคุณมากครับ ^^
      • #33
        ขอบคุณคับ
        • #34
          • #35
            ขอบคุณคับ
            • #36
              ขุดของมีประโยช
              • #37
                จัดไปอย่าให้เสีย
                อิอิ
                • #38
                  สุดยอดเลย
                  • #39
                    ขอบคุณมากๆครับ
                    • #40
                      ^_^แหล่มเลยครับ
                      • #41
                        ขอบคุณมากนะครับ
                        • #42
                          • #43
                            • #44
                              thx a lot ครับท่านซอล
                              • #45
                                Update Feb 17 2009
                                SetFSB 2.1.96.0
                                2/17/2009 - Updated SetFSB : Version 2.1.96.0 - Added ICS952703BF,CV125PAG.
                                Supported ABIT I45-CV(ICS9LPRS419DLF),Acer Aspire 5054WXMi(RTM870T-691), ASUS P5Q-E(ICS9LPRS918BKL).
                                Everest Ultimate Edition 5.00.1658
                                * Intel Processor Number detection for Core 2 Duo P8800, P9700, T9900
                                * motherboard specific sensor info for Asus V-M3A3200, VIA VB7001, VIA VB7002, VIA VB8001
                                * fixed: SPD information for A-Data modules with bad CRC
                                * fixed: NVAPI GPU handles ordering
                                * fixed: IPMI access via SSIF (sleep between SMBus retries)
                                CPU-Z 1.50
                                Core Temp 0.99.5.6 Beta
                                Download (32-bit)
                                Download (64-bit)
                                Version 0.99.5.6 - 7th February, 2009
                                - Add: Thermal protection mechanism. (Look at Options menu)
                                - Add: Mini mode for GUI. (Double click anywhere to switch between modes)
                                - Add: Per core temperature offset adjustment.
                                - Add: Screenshots are now taken in the lossless but very compact PNG format.
                                - Add: User defined text colors for main Window. (Options --> Settings)
                                - Fix: PROCHOT signal from Intel CPUs was not picked up correctly.
                                - Fix: Core Temp would start out of the desktop area, and the main Window couldn't be seen/accessed.
                                - Fix: AMD K8 series incorrectly reports temperature at over 200C (CPU bug, workaround applied).
                                - Fix: High/low temperatures would be reversed when "Show distance to TjMax" was enabled.
                                - Fix: Clicking "Defaults" button in settings would enable logging when it should be disabled by default.
                                - Fix: "Show highest temp of each CPU" systemtray icon configuration sometimes reports duplicate readings.
                                - Change: Completely dropped support for older Windows NT OS, Windows XP or up is required.
                                Prime95 v25.8,build 1
                                New version (32-bit) 23-11-2008
                                1) Bug fixed in smart affinity on hyperthreaded CPUs.
                                2) Bug fixed in setting a thread priority other than 1.
                                3) Off-by-one-bit bug fixed in the benchmarking of trial factoring.
                                New version(64-bit) 05-10-2008
                                p64v257
                                Memtest86+ v2.11
                                * New Features
                                o Added support for Intel Core i5 (Lynnfield) CPU
                                o Added support for Intel P55 Southbridge
                                o Added support for Intel PM45/GM45/GM47 Mobile chipset
                                o Added support for Intel GL40/GS45 Mobile chipset
                                * Bug Fixes
                                o Corrected DDR2/DDR3 detection on Intel x35/x45
                                o Corrected detection on some Core i7 CPU
                                o Fixed a bug with some AMI BIOS (freeze at startup)
                                o Various bug fixes
                                Home page
                                Unofficial Memtest86+ v2.11a here
                                Memtest86 Release 3.5
                                * Limited support for execution with multiple CPUs. CPUs are selected round-robin or sequential for each test.
                                * Support for detection of additional chipsets. (from Memtest86+ v2.11).
                                * Additions and corrections for CPU detection including reporting of L3 cache.
                                * Reworked information display for better readability and new information.
                                * Abbreviated iterations for first pass.
                                * Enhancements to memory sizing.
                                * Misc bug fixes.
                                Memtest86 3.5-iso
                                Another package here
                                OCCT PT 3.0.1.b01 OUT !
                                Changelog :
                                • OCCT now uses, when available, sensor names instead of their position when loading. Thus, when the sensor list changes (i.e. a sensor "disappears" as sometimes happens), the others are still correctly configured, and not completly messed up as before. This works with monitoring programs that provides sensor names (Built-in, Everest,...).
                                • OCCT now correctly loads the max CPU Temp (you could configure it to temps higher than 99°C, but it reverted to 80°C upon restart).
                                Enjoy !
                                Rivatuner 2.23 Released
                                The very powerful videocard tweaking utility Rivatuner has been updated towards version 2.23. The full list of this release' updates and fixes follows below. To download it, please click here.
                                Galaxy Xtreme Tuner
                                TechPowerUp Radeon Bios Editor v1.19 (536.2 KB)
