อันนี้ปรับแบบไม่รู้เรื่องลอกเค้ามา
AI Overclock tuner: MANUAL
CPU Ratio Setting: 8
FSB Frequency: 500
FSB Strap to North Bridge: AUTO
PCI-E Frequency: 100
DRAM Frequency: DDR2-1000Mhz
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 9
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: MANUAL
Common Performance Level [11]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.23
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: AUTO
FSB Termination Voltage: AUTO
DRAM Voltage: AUTO
NB Voltage: AUTO
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Enable
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
CPU Margin Enhancement : Optimized
Advance CPU Settings
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
อุณหภูมิประมาณ 53-54
แล้วมันดับ เลยเปลี่ยนไปเปลี่ยนมาสุดท้าย
มาที่ 9*440 ไฟ 1.312(ปรับมาถึง 1.28 ก็ยังไม่ได้) DDR2-833(อันนี้ไม่แน่ใจ) ที่เหลือยังเหมือนเดิม อุณหภูมิ ประมาณ 43
เริ่มจะคงที่ แต่ยังไม่ชัวร์ กำลังสงสัยว่าเพราะตอนแรกไฟไม่พอ หรือ เพราะปรับแรม(ตรงแรมนี้ไม่รู้เรื่องเลย ปรับๆตามเค้ามา)
FSB Frequency: 500
1st Information :
CAS# Latency: 5
2nd Information :
3rd Information :
CPU Voltage: 1.23
DRAM Voltage: AUTO
NB Voltage: AUTO
CPU VID: Default
