ทำช่องให้ใส่เลขไว้แล้ว ให้กดQuote ใส่เลยครับ ที่เหลือถ้าไม่ตรงก็ลงเอาครับ
ส่วนตัวผมก็อย่ารู้เลย เพระปรับไม่เป็น
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO.
CPU Ratio Control : Manual
- Ratio CMOS Setting : .
FSB Frequency :.
FSB Strap to North Bridge :.
PCI-E Frequency: .
DRAM Frequency: DDR2-.
DRAM Command Rate : .
DRAM Timing Control: Manual
CAS# Latency : .
RAS# to CAS# Delay : .
RAS# Precharge : .
RAS# ActivateTime : .
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
DRAM Static Read Control: Enabled
Ai Clock Twister : Strong
Transaction Booster : AUTO
CPU Voltage : .
CPU PLL Voltage : Auto
North Bridge Voltage : .
DRAM Voltage : .
FSB Termination Voltage : .
South Bridge Voltage : .
Loadline Calibration : ENABLED
CPU GTL Reference : AUTO
North Bridge GTL Reference : AUTO
DDR2 Channel A REF Voltage : AUTO
DDR2 Channel B REF Voltage : AUTO
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : 1.5v
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : ENABLED
CPU Spread Spectrum : Disabled
PCIE Spread Spectrum : Disabled
Extreme Tweaker
FSB Frequency :.
PCI-E Frequency: .
CAS# Latency : .
RAS# Precharge : .
CPU Voltage : .
DRAM Voltage : .
