แกะกล่อง Tenda AC18 AC1900 Smart Dual-Band Gigabit WiFi Router
  • แกะกล่อง Tenda AC18 AC1900 Smart Dual-Band Gigabit WiFi Router
    ของเพิ่งมาถึงวันนี้เองครับเลยถ่ายรูปมาให้เพื่อน ๆ ได้ชมกัน
    Spec
    Tenda AC18 (AC18) specifications
    Brand : Tenda
    Type :AC18
    Launch :2016
    Body Dimensions : 261 x 168 x 65 mm
    Weight : 640 g
    System
    Chipset : Dual Broadcom ARM Cortex-A9 CPU
    RAM : 256 MB
    Flash : 128 MB
    OS : Tenda
    Power supply : 12 V / 2.5 A
    Interface
    1*10/100/1000Mbps WAN port
    4*10/100/1000Mbps LAN ports
    1* USB3.0 port
    Antenna
    3*3dBi external dual band antennas
    Button
    1* Power On/Off button, 1*WiFi on/off, 1* Reset button,1* WPS button
    LED
    1*power, 1*Internet, LAN, 1*2.4G, 1*5G, 1*WPS, 1*USB
    Wireless Standards
    IEEE 802.11ac/a/n 5GHz
    IEEE 802.11b/g/n 2.4GHz
    Data rate
    5GHz: Up to 1300Mbps
    2.4GHz: Up to 600Mbps, support Turbo-QAM
    Transmit Power
    CE: <20dBm(2.4G)
    <23dBm(5G)
    FCC:<30dBm
    Basic Features
    SSID Broadcast: Enable/Disable
    Transmission Power: high, medium, low
    Beamforming
    Wireless Security
    WPA-PSK/WPA2-PSK, WPA/WPA2
    ?Wireless Security: Enable/Disable
    ?WPS(WiFi Protected Set-up) fast encryption
    Internet Connection Type
    PPPoE, Dynamic IP, Static IP
    PPPoE(Russia), PPTP(Russia), L2TP(Russia)
    Operating Mode
    Wireless Router Mode
    Universal Repeater Mode
    WISP Mode
    DHCP
    DHCP Server
    DHCP Client List
    DHCP Reservation
    Virtual Server
    Port Forwarding?
    DMZ Host
    UPnP
    Security
    Client Filter?
    Parental Control(support black list and white list)
    Remote Web Management
    Firewall
    Forbid UDP flood attack
    Forbid TCP flood attack
    Forbid flood attack
    Forbid WAN PING from internet
    DDNS
    Support DynDNS, No-ip, 3322.org, Oray.com, 88ip
    USB Sharing
    Support Samba(Storage)/FTP Server/Printer Server/ DLNA/ Media Server
    VPN
    IPsec pass through
    PPTP pass through
    L2TP pass through
    PPTP server
    PPTP client
    L2TP client
    Features
    Smart WiFi Schedule
    Sleeping Mode
    Smart LED on/off
    Tenda App
    Other
    Bandwidth Control
    Guest Network?
    IPTV
    MAC Clone
    Static Routing
    System Log
    Backup & Restore configurations?
    Firmware upgrade online
    Firmware upgradeable via browser
    ค่าตัวประมาณสามพันปลายครับ ผมว่าค่อนข้างคุ้มค่ากับ Spec ที่ได้มาครับ
      ตัวที่ผมอยากได้ถัดไปจาก AC9 เลย ท่านได้จากที่ไหนมาจะได้สั่งมั่ง
        แค่แกะกล่องจริงๆ
          สามพันปลายๆ ของ ASUS ยังได้ AC1200 ง่อยๆ
            เวปไข่ใหม่ครับประกันนอก
            Originally posted by XsoeIIsJ View Post
            แค่แกะกล่องจริงๆ
            555+ ผมไม่ถนัด review เลยท่านแล้วก็แค่แกะกล่องจริง ๆ ยังไม่ได้ลองเลย พอดีวันเสาร์ช่าง 3BB จะมาติด FTTX 100/30 ที่บ้านที่เปลี่ยนจาก VDSL 70/20 ครับเลยยังไม่ได้ลองของเลยไม่รู้ว่าจะได้ ONU ตัวไหน
            ใช่ครับเห็นว่าตัวนี้คุ้มราคาก็เลยจัดมาลองซะเลย เท่าที่อ่าน Review ดูเห็นว่า Heard ware เหมือนกับ Asus RT-68U มากไม่แน่อาจจะลง Merlin ได้
              รีวิวสัญญาณwifiด้วยนะครับว่าไปไกลป่าว ทั้ง2.4gและ5g
                ชอบเหมือนกัน สั่งซื้อยังไงครับ รบกวนหลังไมค์หน่อย
                  ก็ไม่ยากคับ
                  1. ดูหน้าตาเมนูว่ามีลูกเล่นอะไรบ้าง มีอะไรเป็นพิเศษไม๊เช่น VPN
                  2. การไช้งานรู้สึกมีปัญหาอะไรบ้าง , มีอะไรที่ต้องการแล้วผิดหวังเพราะมันไม่มี
                  3. ไช้อุปกรณ์(มือถือ)รับสัญญาณจากจุดต่างๆของบ้าน ดีกว่าเราเตอร์เดิมใหม , เปิด - ปิด Beamforming แล้วมีอะไรดี-แย่ ลงบ้าง
                  4. ความร้อน , สปีดสูงสุดจาก wifi และสาย Lan
                  ฯลฯ เสริมใด้ตามชอบ
                    ก็ไม่ยากคับ
                    ฯลฯ เสริมใด้ตามชอบ
                    คงไม่ได้แล้วครับท่าน ONU ขึ้นไฟแดง LOS ซะแล้ว -*-
                      เหมือนจะลงAsuswrt-Merlin ได้ปะคับตัวนี้ เห็นบอร์ดนอกจีนทำกัน
