รบกวนสอบถามผู้รู้หน่อยครับ ว่าเกิดจากสาเหตุใดทำให้
เกิดการตัดสัญญาณ ของ router wireless dlink นะครับ
ขอบคุณมากครับใช้ modem เป็น asus dsl-n10 อัพเฟิร์มแวร์
ใหม่ล่าสุดแล้ว
sing nameserver 110.164.252.222#53
Nov 27 13
42 info using nameserver 110.164.252.223#53
Nov 27 13
42 info reading /etc/resolv.conf
Nov 27 13
42 info compile time options: IPv6 GNU-getopt no-MMU ISC-leasefile no-DOCTOR no-NOWILD no-DBus no-I18N TFTP
Nov 27 13
42 info started, version 2.45 cachesize 150
Nov 27 13
38 info [20826.740000] module arch cleanup GPL_NetUSB: OCM instruction memory free of 0 @00000000
Nov 27 13
38 info [20826.720000] module arch cleanup NetUSB: OCM instruction memory free of 0 @00000000
Nov 27 13
35 info [20823.710000] usbcore: deregistering interface driver USB General Driver
Nov 27 13
35 info exiting on receipt of SIGTERM
Nov 27 13
35 info [20823.340000] flags=0
Nov 27 13
35 info [20823.340000] ioctl eth0, 35312
Nov 27 13
34 notice received signal 15, good-bye
Nov 27 13
33 notice pppd sent restart signal to rc
Nov 27 13
33 notice pppd check for rc to be idle ?
Nov 27 13
33 notice ipcp_up: remote PPP IP address 171.5.56.1
Nov 27 13
33 notice ipcp_up: local PPP IP address 171.5.63.219
Nov 27 13
33 notice ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoE
Nov 27 13
33 debug rcvd [IPCP ConfAck id=0x2 'addr 171.5.63.219']
Nov 27 13
33 debug sent [IPCP ConfReq id=0x2 'addr 171.5.63.219']
Nov 27 13
33 debug rcvd [IPCP ConfNak id=0x1 'addr 171.5.63.219']
Nov 27 13
33 debug sent [IPCP ConfAck id=0x0 'addr 171.5.56.1']
Nov 27 13
33 debug rcvd [IPCP ConfReq id=0x0 'addr 171.5.56.1']
Nov 27 13
33 debug sent [IPCP ConfReq id=0x1 'addr 0.0.0.0']
Nov 27 13
33 notice peer from calling number 00
9E:5B:6D:AD authorized
Nov 27 13
33 notice PAP authentication succeeded
Nov 27 13
33 info Remote message: Authentication success,Welcome!
Nov 27 13
33 debug rcvd [PAP AuthAck id=0x1 Authentication success,Welcome! ]
Nov 27 13
33 debug rcvd [LCP EchoRep id=0x0 magic=0x5000ed0]
Nov 27 13
33 debug sent [PAP AuthReq id=0x1 user= mnr5jpwa@indy password='hidden']
Nov 27 13
33 debug sent [LCP EchoReq id=0x0 magic=0x139f528d]
Nov 27 13
33 debug sent [LCP ConfAck id=0x1 'mru 1492' 'auth pap' 'magic 0x5000ed0']
Nov 27 13
33 debug rcvd [LCP ConfReq id=0x1 'mru 1492' 'auth pap' 'magic 0x5000ed0']
Nov 27 13
30 debug rcvd [LCP ConfAck id=0x1 'mru 1492' 'magic 0x139f528d']
Nov 27 13
30 debug sent [LCP ConfReq id=0x1 'mru 1492' 'magic 0x139f528d']
Nov 27 13
30 notice Connect: ppp0 '--' eth0.1
Nov 27 13
30 info Using interface ppp0
Nov 27 13
30 debug using channel 22
Nov 27 13
30 info PPP session is 9780
Nov 27 13
30 debug PADS: Service-Name: '3bb'
Nov 27 13
30 info Sent PADT
Nov 27 13
30 info rp_pppoe =' Send PADT to terminate the session ID that sent last time
Nov 27 13
30 notice pppd 2.4.3 started by root, uid 0
Nov 27 13
30 info RP-PPPoE plugin inform wantimer to reset auth, discovery variable
Nov 27 13
30 info RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Nov 27 13
30 info Plugin /lib/pppd/2.4.3/rp-pppoe.so loaded.
Nov 27 13
13 info [20742.240000] module arch cleanup nf_ubicom_streamengine_default_classifier: OCM instruction memory free of 0 @00000000
Nov 27 13
12 info [20741.200000] module arch cleanup sch_ubicom_streamengine: OCM instruction memory free of 0 @00000000
Nov 27 13
06 info Exit.
Nov 27 13
06 info Sent PADT
Nov 27 13
06 notice ppp auth: Connection terminated.
Nov 27 13
06 debug rcvd [LCP TermAck id=0x2]
Nov 27 13
06 debug sent [LCP TermReq id=0x2 User request ]
Nov 27 13
06 info Sent 695723 bytes, received 73740 bytes.
Nov 27 13
06 info Connect time 7.9 minutes.
Nov 27 13
06 info Terminating on signal 15
Nov 27 13
33 info [20281.450000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000
Nov 27 13
32 info [20281.280000] module arch cleanup nf_nat_ftp: OCM instruction memory free of 0 @00000000
Nov 27 13
26 info [20275.230000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000
Nov 27 13
26 info [20275.070000] module arch cleanup nf_nat_ftp: OCM instruction memory free of 0 @00000000
Nov 27 13
24 info [20272.810000] usbcore: registered new interface driver USB General Driver
Nov 27 13
22 info read /etc/hosts - 2 addresses
Nov 27 13
22 info using nameserver 110.164.252.222#53
Nov 27 13
22 info using nameserver 110.164.252.223#53
Nov 27 13
22 info reading /etc/resolv.conf
Nov 27 13
22 info compile time options: IPv6 GNU-getopt no-MMU ISC-leasefile no-DOCTOR no-NOWILD no-DBus no-I18N TFTP
Nov 27 13
22 info started, version 2.45 cachesize 150
Nov 27 13
22 notice HTTP listening on port 65535
Nov 27 13
18 info [20267.300000] module arch cleanup GPL_NetUSB: OCM instruction memory free of 0 @00000000
Nov 27 13
18 info [20267.280000] module arch cleanup NetUSB: OCM instruction memory free of 0 @00000000
Nov 27 13
15 info [20264.270000] usbcore: deregistering interface driver USB General Driver
Nov 27 13
15 info exiting on receipt of SIGTERM
Nov 27 13
15 info [20263.790000] flags=0
Nov 27 13
15 info [20263.790000] ioctl eth0, 35312
Nov 27 13
15 notice received signal 15, good-bye
Nov 27 13
14 notice pppd sent restart signal to rc
Nov 27 13
14 notice pppd check for rc to be idle ?
Nov 27 13
14 notice ipcp_up: remote PPP IP address 223.207.0.1
Nov 27 13
14 notice ipcp_up: local PPP IP address 223.207.2.30
Nov 27 13
14 notice ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoE
Nov 27 13
14 debug rcvd [IPCP ConfAck id=0x2 'addr 223.207.2.30']
Nov 27 13
14 debug sent [IPCP ConfReq id=0x2 'addr 223.207.2.30']
Nov 27 13
14 debug rcvd [IPCP ConfNak id=0x1 'addr 223.207.2.30']
Nov 27 13
14 debug sent [IPCP ConfAck id=0x0 'addr 223.207.0.1']
Nov 27 13
14 debug rcvd [IPCP ConfReq id=0x0 'addr 223.207.0.1']
Nov 27 13
14 debug sent [IPCP ConfReq id=0x1 'addr 0.0.0.0']
Nov 27 13
14 notice peer from calling number 00
Nov 27 13
14 notice PAP authentication succeeded
Nov 27 13
14 info Remote message: Authentication success,Welcome!
Nov 27 13
14 debug rcvd [PAP AuthAck id=0x1 Authentication success,Welcome! ]
Nov 27 13
14 debug rcvd [LCP EchoRep id=0x0 magic=0x5006425]
Nov 27 13
14 debug sent [PAP AuthReq id=0x1 user= mnr5jpwa@indy password='hidden']
Nov 27 13
14 debug sent [LCP EchoReq id=0x0 magic=0xb2ac5419]
Nov 27 13
14 debug sent [LCP ConfAck id=0x1 'mru 1492' 'auth pap' 'magic 0x5006425']
Nov 27 13
14 debug rcvd [LCP ConfReq id=0x1 'mru 1492' 'auth pap' 'magic 0x5006425']
Nov 27 13
11 debug rcvd [LCP ConfAck id=0x1 'mru 1492' 'magic 0xb2ac5419']
Nov 27 13
11 debug sent [LCP ConfReq id=0x1 'mru 1492' 'magic 0xb2ac5419']
Nov 27 13
11 notice Connect: ppp0 '--' eth0.1
Nov 27 13
11 info Using interface ppp0
Nov 27 13
11 debug using channel 21
Nov 27 13
11 info PPP session is 10369
Nov 27 13
11 debug PADS: Service-Name: '3bb'
Nov 27 13
11 info Sent PADT
Nov 27 13
11 info rp_pppoe =' Send PADT to terminate the session ID that sent last time
Nov 27 13
10 notice pppd 2.4.3 started by root, uid 0
Nov 27 13
10 info RP-PPPoE plugin inform wantimer to reset auth, discovery variable
Nov 27 13
10 info RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
Nov 27 13
10 info Plugin /lib/pppd/2.4.3/rp-pppoe.so loaded.
Nov 27 13
10 info [20079.080000] module arch cleanup nf_ubicom_streamengine_default_classifier: OCM instruction memory free of 0 @00000000
Nov 27 13
09 info [20078.010000] module arch cleanup sch_ubicom_streamengine: OCM instruction memory free of 0 @00000000
Nov 27 13
03 info Exit.
Nov 27 13
03 info Sent PADT
Nov 27 13
03 notice ppp auth: Connection terminated.
Nov 27 13
03 debug rcvd [LCP TermAck id=0x2]
Nov 27 13
03 debug sent [LCP TermReq id=0x2 User request ]
Nov 27 13
03 info Sent 691185 bytes, received 60957 bytes.
Nov 27 13
03 info Connect time 9.8 minutes.
Nov 27 13
03 info Terminating on signal 15
Nov 27 13
34 info [19503.210000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000
Nov 27 13
34 info [19503.030000] module arch cleanup nf_nat_ftp: OCM instruction memory free of 0 @00000000
Nov 27 13
29 info [19497.780000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000
Nov 27 13
29 info [19497.590000] module arch cleanup nf_nat_ftp: OCM instruction memory free of 0 @00000000
ใหม่ล่าสุดแล้ว
Nov 27 13
42 info using nameserver 110.164.252.223#53Nov 27 13
42 info reading /etc/resolv.confNov 27 13
42 info compile time options: IPv6 GNU-getopt no-MMU ISC-leasefile no-DOCTOR no-NOWILD no-DBus no-I18N TFTPNov 27 13
42 info started, version 2.45 cachesize 150Nov 27 13
38 info [20826.740000] module arch cleanup GPL_NetUSB: OCM instruction memory free of 0 @00000000Nov 27 13
38 info [20826.720000] module arch cleanup NetUSB: OCM instruction memory free of 0 @00000000Nov 27 13
35 info [20823.710000] usbcore: deregistering interface driver USB General DriverNov 27 13
35 info exiting on receipt of SIGTERMNov 27 13
35 info [20823.340000] flags=0Nov 27 13
35 info [20823.340000] ioctl eth0, 35312Nov 27 13
34 notice received signal 15, good-byeNov 27 13
33 notice pppd sent restart signal to rcNov 27 13
33 notice pppd check for rc to be idle ?Nov 27 13
33 notice ipcp_up: remote PPP IP address 171.5.56.1Nov 27 13
33 notice ipcp_up: local PPP IP address 171.5.63.219Nov 27 13
33 notice ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoENov 27 13
33 debug rcvd [IPCP ConfAck id=0x2 'addr 171.5.63.219']Nov 27 13
33 debug sent [IPCP ConfReq id=0x2 'addr 171.5.63.219']Nov 27 13
33 debug rcvd [IPCP ConfNak id=0x1 'addr 171.5.63.219']Nov 27 13
33 debug sent [IPCP ConfAck id=0x0 'addr 171.5.56.1']Nov 27 13
33 debug rcvd [IPCP ConfReq id=0x0 'addr 171.5.56.1']Nov 27 13
33 debug sent [IPCP ConfReq id=0x1 'addr 0.0.0.0']Nov 27 13
9E:5B:6D:AD authorizedNov 27 13
33 notice PAP authentication succeededNov 27 13
33 info Remote message: Authentication success,Welcome!Nov 27 13
33 debug rcvd [PAP AuthAck id=0x1 Authentication success,Welcome! ]Nov 27 13
33 debug rcvd [LCP EchoRep id=0x0 magic=0x5000ed0]Nov 27 13
33 debug sent [PAP AuthReq id=0x1 user= mnr5jpwa@indy password='hidden']Nov 27 13
33 debug sent [LCP EchoReq id=0x0 magic=0x139f528d]Nov 27 13
33 debug sent [LCP ConfAck id=0x1 'mru 1492' 'auth pap' 'magic 0x5000ed0']Nov 27 13
33 debug rcvd [LCP ConfReq id=0x1 'mru 1492' 'auth pap' 'magic 0x5000ed0']Nov 27 13
30 debug rcvd [LCP ConfAck id=0x1 'mru 1492' 'magic 0x139f528d']Nov 27 13
30 debug sent [LCP ConfReq id=0x1 'mru 1492' 'magic 0x139f528d']Nov 27 13
30 notice Connect: ppp0 '--' eth0.1Nov 27 13
30 info Using interface ppp0Nov 27 13
30 debug using channel 22Nov 27 13
30 info PPP session is 9780Nov 27 13
30 debug PADS: Service-Name: '3bb'Nov 27 13
30 info Sent PADTNov 27 13
30 info rp_pppoe =' Send PADT to terminate the session ID that sent last timeNov 27 13
30 notice pppd 2.4.3 started by root, uid 0Nov 27 13
30 info RP-PPPoE plugin inform wantimer to reset auth, discovery variableNov 27 13
30 info RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3Nov 27 13
30 info Plugin /lib/pppd/2.4.3/rp-pppoe.so loaded.Nov 27 13
13 info [20742.240000] module arch cleanup nf_ubicom_streamengine_default_classifier: OCM instruction memory free of 0 @00000000Nov 27 13
12 info [20741.200000] module arch cleanup sch_ubicom_streamengine: OCM instruction memory free of 0 @00000000Nov 27 13
06 info Exit.Nov 27 13
06 info Sent PADTNov 27 13
06 notice ppp auth: Connection terminated.Nov 27 13
06 debug rcvd [LCP TermAck id=0x2]Nov 27 13
06 debug sent [LCP TermReq id=0x2 User request ]Nov 27 13
06 info Sent 695723 bytes, received 73740 bytes.Nov 27 13
06 info Connect time 7.9 minutes.Nov 27 13
06 info Terminating on signal 15Nov 27 13
33 info [20281.450000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000Nov 27 13
32 info [20281.280000] module arch cleanup nf_nat_ftp: OCM instruction memory free of 0 @00000000Nov 27 13
26 info [20275.230000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000Nov 27 13
26 info [20275.070000] module arch cleanup nf_nat_ftp: OCM instruction memory free of 0 @00000000Nov 27 13
24 info [20272.810000] usbcore: registered new interface driver USB General DriverNov 27 13
22 info read /etc/hosts - 2 addressesNov 27 13
22 info using nameserver 110.164.252.222#53Nov 27 13
22 info using nameserver 110.164.252.223#53Nov 27 13
22 info reading /etc/resolv.confNov 27 13
22 info compile time options: IPv6 GNU-getopt no-MMU ISC-leasefile no-DOCTOR no-NOWILD no-DBus no-I18N TFTPNov 27 13
22 info started, version 2.45 cachesize 150Nov 27 13
22 notice HTTP listening on port 65535Nov 27 13
18 info [20267.300000] module arch cleanup GPL_NetUSB: OCM instruction memory free of 0 @00000000Nov 27 13
18 info [20267.280000] module arch cleanup NetUSB: OCM instruction memory free of 0 @00000000Nov 27 13
15 info [20264.270000] usbcore: deregistering interface driver USB General DriverNov 27 13
15 info exiting on receipt of SIGTERMNov 27 13
15 info [20263.790000] flags=0Nov 27 13
15 info [20263.790000] ioctl eth0, 35312Nov 27 13
15 notice received signal 15, good-byeNov 27 13
14 notice pppd sent restart signal to rcNov 27 13
14 notice pppd check for rc to be idle ?Nov 27 13
14 notice ipcp_up: remote PPP IP address 223.207.0.1Nov 27 13
14 notice ipcp_up: local PPP IP address 223.207.2.30Nov 27 13
14 notice ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoENov 27 13
14 debug rcvd [IPCP ConfAck id=0x2 'addr 223.207.2.30']Nov 27 13
14 debug sent [IPCP ConfReq id=0x2 'addr 223.207.2.30']Nov 27 13
14 debug rcvd [IPCP ConfNak id=0x1 'addr 223.207.2.30']Nov 27 13
14 debug sent [IPCP ConfAck id=0x0 'addr 223.207.0.1']Nov 27 13
14 debug rcvd [IPCP ConfReq id=0x0 'addr 223.207.0.1']Nov 27 13
14 debug sent [IPCP ConfReq id=0x1 'addr 0.0.0.0']Nov 27 13
14 notice PAP authentication succeededNov 27 13
14 info Remote message: Authentication success,Welcome!Nov 27 13
14 debug rcvd [PAP AuthAck id=0x1 Authentication success,Welcome! ]Nov 27 13
14 debug rcvd [LCP EchoRep id=0x0 magic=0x5006425]Nov 27 13
14 debug sent [PAP AuthReq id=0x1 user= mnr5jpwa@indy password='hidden']Nov 27 13
14 debug sent [LCP EchoReq id=0x0 magic=0xb2ac5419]Nov 27 13
14 debug sent [LCP ConfAck id=0x1 'mru 1492' 'auth pap' 'magic 0x5006425']Nov 27 13
14 debug rcvd [LCP ConfReq id=0x1 'mru 1492' 'auth pap' 'magic 0x5006425']Nov 27 13
11 debug rcvd [LCP ConfAck id=0x1 'mru 1492' 'magic 0xb2ac5419']Nov 27 13
11 debug sent [LCP ConfReq id=0x1 'mru 1492' 'magic 0xb2ac5419']Nov 27 13
11 notice Connect: ppp0 '--' eth0.1Nov 27 13
11 info Using interface ppp0Nov 27 13
11 debug using channel 21Nov 27 13
11 info PPP session is 10369Nov 27 13
11 debug PADS: Service-Name: '3bb'Nov 27 13
11 info Sent PADTNov 27 13
11 info rp_pppoe =' Send PADT to terminate the session ID that sent last timeNov 27 13
10 notice pppd 2.4.3 started by root, uid 0Nov 27 13
10 info RP-PPPoE plugin inform wantimer to reset auth, discovery variableNov 27 13
10 info RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3Nov 27 13
10 info Plugin /lib/pppd/2.4.3/rp-pppoe.so loaded.Nov 27 13
10 info [20079.080000] module arch cleanup nf_ubicom_streamengine_default_classifier: OCM instruction memory free of 0 @00000000Nov 27 13
09 info [20078.010000] module arch cleanup sch_ubicom_streamengine: OCM instruction memory free of 0 @00000000Nov 27 13
03 info Exit.Nov 27 13
03 info Sent PADTNov 27 13
03 notice ppp auth: Connection terminated.Nov 27 13
03 debug rcvd [LCP TermAck id=0x2]Nov 27 13
03 debug sent [LCP TermReq id=0x2 User request ]Nov 27 13
03 info Sent 691185 bytes, received 60957 bytes.Nov 27 13
03 info Connect time 9.8 minutes.Nov 27 13
03 info Terminating on signal 15Nov 27 13
34 info [19503.210000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000Nov 27 13
34 info [19503.030000] module arch cleanup nf_nat_ftp: OCM instruction memory free of 0 @00000000Nov 27 13
29 info [19497.780000] module arch cleanup nf_conntrack_ftp: OCM instruction memory free of 0 @00000000Nov 27 13
