If some have the AIP-W515H router and by mistake he install the wrong firmware in it is router. Now the router SYS LED ON then you have to do the following setups to make the router again work.
The setups are:
1. PC-----Ethernet cable------LAN port of the AIP-W515H
(PC set to 192.168.1.X)
2. Hold on the RESET Button before power on.
3. power on then Power and SYS LED on
4. Please set the folder on your PC(like C:\AIP-W515H) file in the
folder(boot.bin and fw.bin).
5. used MS-DOS.
C:\AIP-W525H
Command
C:\AIP-W525H\ tftp -i 192.168.1.6 put boot.bin
you will see the Power and SYS LED on
Then C:\AIP-W515H\ tftp -I 192.168.1.6 put fw.bin
6. The device will reboot after upload firmware OK.(SYS LED will off)
7. Then you can login the AIP-W515H by Ethernet cable.
8. Please use the browser key in 192.168.2.1 login in the AIP-W515H then upgrade the setting of the ?config-gw-96.dat?
Note: This is work for Win XP system OS.
Here is the LINK for Firmware:http://www.4shared.com/zip/2ipBNBpe/AIPW515H.html
Second LINK: http://www.mediafire.com/?vwjcurgo69o2q82
The setups are:
5. used MS-DOS.
C:\AIP-W525H
Command
เครคิต https://forum.raymond.cc/threads/fir...ricking.35240/
