Firmware AirOS 5 ใช้ลงสำหรับอุปกรณ์ทุกรุ่นที่ลงท้ายด้วย M Series
ล่าสุด Firmware Version 5.6 เบต้า 6 (The third v5.6 Beta is now released for your testing enjoyment.)
AirOS เวอร์ชั่น 5.6 BETA 6 Release Notes:
Fix:
Fix: SNMP daemon is leaking memory
Fix: LAN speed negotiation improvement after failure (NBE-M5-400 and RM5-Ti (XW))
Fix: New Zealand should have HT40 mode on 5GHz.
Fix: STA Device Name is truncated in SNMP reporting
Fix: SNMP string sizes
Fix: Station can't connect to AP with Hidden SSID (XW)
Fix: Discovery response leak across VLANs
Fix: Station shows wrong "TX Signal" in AP details window
Fix: The same channel numbering for 4920-5000MHz and 5920-6000MHz (Compliance Test).
Fix: Default rate algorithm rate selection regression in v5.6-Beta4 release
Fix: Disable UPnP SSDP messages in Syslog
Fix: Main tab is empty if device name contains <tab> symbol
Fix: Scan results buffer size limit issue (at ~200 APs found)
Fix: Possible fix for wireless lockup (XM/TI)
Fix: Reduce TX power to the EIRP Limit when radio is operating in Station mode or Auto frequency selection is chosen for AP
Fix: Speedup DHCP and PPPoE clients to update IP settings after successful WPA authentication
Fix: IPv6 prefix size
Fix: Send RA with management flag when stateful DHCPv6 enabled
Fix: DHCP client destroys IPv6 configuration
Fix: SSL v3 POODLE vulnerability
Fix: Add 5GHz frequencies for Kazakhstan
>> Firmware Version 5.6 เบต้า 6 (M series เท่านั้น!)
>> Another Firmware Version เวอร์ชั่นอื่นๆโปรดเลือกดูที่เว็บไซด์หลัก
Fix:
