Question: What is VOB and what we can do with it?
Answer: VOB stands for DVD Video Object. The VOB file is one of the core files found on DVD-Video discs and contains multiplexed Dolby Digital audio (normally AC3 format) and MPEG-2 video. So the VOB files can be used in DVD Compiler and Disc Burner.And VOB converter which can be used as a sub-method for DVD Creation is more and more popular among the digital world with its main function of converting video files to VOB format.
Now I’d like to introduce a professional VOB Converter, which can not only convert almost any video format to VOB, but also can convert VOB files to MP3, AAC, WAV with powerful editing functions.
It is very easy to use. Just take the following steps, you can finish the conversion with high output quality.
Preparaiton:Download and install VOB Converter
Step 1:Click “Add File” button to import your video files.
Step 2:Select the output format.
You can choose the ourput format from the profile drop-down list.
Click the “setting” button, you can set the Encoder, Resolution, Bitrate, etc.
Step 3:Choose the output fold.
You can click “Browse” to choose the output destination, or the default destination is D:\My Documents\4Easysoft Studio\Output
Step 4:Click “Start” button to begin the conversion.
This converter also has powerful editing functions, such as:
1.Trim video
Click “Trim” button, you can trim videos by dragging the slide bar; clicking the scissors button; or setting the end time and start time.
2.Crop video
Click “Crop” button, you can crop videos by choosing the crop mode; setting the crop values; adjusting the crop frame.
3.Select preference
Click the “Preference” button you can select the output destination, the Snapshot foler, the format of the snapshot image,etc.
4.Take snapshot
You can save the images you like when you are previewing the videos by clicking snapshot.
5.Merge files
You can select “Merge into one file” to merge your files into one.
Some related tools:
4Easysoft ASF Video Converter provides an easy and completed way to convert mainstream videos to ASF including MP4, M4V, AVI, FLV, 3GP, 3G2, MPG and extract audio from ASF files to MP3, WMA with rich video editing functions such as video cropping, movie trimming and video joining.
4Easysoft Total Video Converter which supports mutual conversion betwwen almost all the video/audio formats is worth having a try as well.
MP4 Converter
1.Trim video
2.Crop video
3.Select preference
4.Take snapshot
5.Merge files
Some related tools:
MP4 Converter
