อยากทราบว่า Host ของ OVERCLOCK ZONE คือ
  • อยากทราบว่า Host ของ OVERCLOCK ZONE คือ
    อยากทรายอะครับ ของเค้าดีจริงๆเลยอยากใช้บ้าง
    NS records at parent.Your nameserver records fetched from the parent servers are:
    ns1.porar.com. (No Glue)
    ns2.porar.com. [209.213.105.12]
    These records come from: J.GTLD-SERVERS.NET. Glue records.Fail. The following nameservers are not sending glue.
    » ns1.porar.com.
    NS records at your nameserversYou have the following NS records listed at your nameservers :
    ns.porar.com. [203.150.224.244]
    Multiple NS recordsOK. You have 2 nameservers. UDP RespondOK. All your nameservers respond to (udp) dns requests. TCP RespondOK. All your nameservers respond to (tcp) dns requests. Registered NSOK. All your nameservers are registered. NS Public IPsOK. All your nameservers have public IPs. Identical NS recordsOK. All your nameserver have identical NS records. NS CNAMEOK. There should be no CNAMEs if an NS (or any other) record is present. Missing nameserversFail. The following nameservers are missing at the parent server.
    » ns.porar.com.
    ns2.porar.com. - (not available)
    ns.porar.com. - (not available)
    SOA MNAMEFail. Your primary nameserver (ns.porar.com) is not listed as a nameserver. SOA RNAMEFail. Your hostmaster adress (support@porar.com) isn't a valid email adress. SOA SerialOK. Your soa serial number (20045375) looks valid. SOA RefreshOK. Your soa refresh (3600) looks valid. SOA RetryOK. Your soa retry (600) looks valid. SOA ExpireFail. Your soa expire interval (86400) is not valid. SOA Minimum TTLOK. Your soa minimum TTL (3600) looks valid.
    There are 7 MX Records available. 10aspmx.l.google.com 20alt1.aspmx.l.google.com 30alt2.aspmx.l.google.com 40aspmx2.googlemail.com 50aspmx3.googlemail.com 60aspmx4.googlemail.com 70aspmx5.googlemail.com Multiple MX recordsOK. You have 7 mx records listed. MX Reverse DNSOK. You have reverse DNS records for all you IPs.
    209.85.219.31 - mail-ew0-f31.google.com
    72.14.221.27 - fg-in-f27.1e100.net
    209.85.216.101 - mail-px0-f101.google.com
    209.85.135.27 - mu-in-f27.1e100.net
    209.85.222.4 - mail-pz0-f4.google.com
    209.85.219.5 - mail-ew0-f5.google.com
    209.85.210.2 - mail-yx0-f2.google.com
    MX CNAME CheckOK. Your mx record resolves to an A record. MX IP CheckOK. All you mx records use a hostname. MX Public IPOK. All you mx records use a public IP adress.
    Mailserver checkOK. All mail servers are online. Postmaster checkOK. All your mailservers accept mail for postmaster@overclockzone.com.
    » aspmx.l.google.com - 250 2.1.5 OK 19si1714291ewy.41
    » alt1.aspmx.l.google.com - 250 2.1.5 OK 3si1427262fge.26
    » alt2.aspmx.l.google.com - 250 2.1.5 OK 2si2314682pwj.33
    » aspmx2.googlemail.com - 250 2.1.5 OK u26si2785591mug.45
    » aspmx3.googlemail.com - 250 2.1.5 OK 4si5238548pzk.32
    » aspmx4.googlemail.com - 250 2.1.5 OK 5si5100741ewy.14
    » aspmx5.googlemail.com - 250 2.1.5 OK 2si3320520yxe.110
    Abuse checkOK. All your mailservers accept mail for abuse@overclockzone.com.
    SPF checkFail. You have a non functional SPF record.
    » Openrelay CheckOK. Your mailservers deny relaying email for unknow domains.
    » aspmx.l.google.com - 550-5.1.1 double-checking the recipient's email address for typos or
    » alt1.aspmx.l.google.com - 550-5.1.1 double-checking the recipient's email address for typos or
    » alt2.aspmx.l.google.com - 550-5.1.1 double-checking the recipient's email address for typos or
    » aspmx2.googlemail.com - 550-5.1.1 double-checking the recipient's email address for typos or
    » aspmx3.googlemail.com - 550-5.1.1 double-checking the recipient's email address for typos or
    » aspmx4.googlemail.com - 550-5.1.1 double-checking the recipient's email address for typos or
    » aspmx5.googlemail.com - 550-5.1.1 double-checking the recipient's email address for typos or
    Literals checkFail. One of your mailservers is not accepting mail for postmaster@[0.0.0.0].
    » aspmx.l.google.com - 550-5.1.1 The email account that you tried to reach does not exist. Please try
    » alt1.aspmx.l.google.com - 550-5.1.1 The email account that you tried to reach does not exist. Please try
    » alt2.aspmx.l.google.com - 550-5.1.1 The email account that you tried to reach does not exist. Please try
    » aspmx2.googlemail.com - 550-5.1.1 The email account that you tried to reach does not exist. Please try
    » aspmx3.googlemail.com - 550-5.1.1 The email account that you tried to reach does not exist. Please try
    » aspmx4.googlemail.com - 550-5.1.1 The email account that you tried to reach does not exist. Please try
    » aspmx5.googlemail.com - 550-5.1.1 The email account that you tried to reach does not exist. Please try
    WWW Recordwww.overclockzone.com CNAME overclockzone.com CNAME CheckOK. Your WWW record is a CNAME Record. WWW Public IPOK. Your webserver has a public IP. Running Webserver : Apache/2Date/Time : Thu, 21 Jan 2010 0729 GMT Google Pagerank for "overclockzone.com" : 5
      short url
        เซอร์เวอร์เค้าแรงครับ
        อิอิ
        แต่ถ้า5000+ อาจมีเอ๋อบ้างงง
