สัญญาณเน็ตผมปกติยังครับ ดูให้ที
  • สัญญาณเน็ตผมปกติยังครับ ดูให้ที
    หลังจาก เดินสายโทรศัพท์ ภายในบ้านใหม่ -*-
    noise margin upstream: 15 db
    output power downstream: 1 db
    attenuation upstream: 3 db
    tone 0- 31: 00 00 00 04 67 89 99 aa aa aa a9 99 88 76 55 42
    tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    noise margin downstream: 31 db
    output power upstream: 5 db
    attenuation downstream: 12 db
    tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    tone 32- 63: 00 00 00 00 00 00 00 12 22 22 24 24 55 55 55 56
    tone 64- 95: 66 65 66 66 66 66 66 26 66 66 66 66 66 66 66 66
    tone 96-127: 66 66 64 66 66 66 66 66 66 66 66 56 66 66 64 66
    tone 128-159: 46 66 66 66 66 46 66 46 66 56 66 66 35 64 56 66
    tone 160-191: 65 66 66 55 55 54 42 25 54 45 55 32 24 54 55 24
    tone 192-223: 52 02 24 54 42 42 22 10 22 22 22 22 25 52 25 22
    tone 224-255: 22 52 54 55 45 54 55 44 25 55 24 55 24 22 25 42
    tone 256-287: 21 22 42 52 21 22 42 24 42 40 54 42 44 44 44 22
    tone 288-319: 24 24 44 22 44 42 52 24 22 25 55 54 55 55 52 25
    tone 320-351: 25 55 55 55 55 54 22 25 55 54 24 55 34 22 44 55
    tone 352-383: 55 55 55 45 25 55 52 55 55 52 55 55 55 55 55 55
    tone 384-415: 55 55 55 55 55 55 55 45 55 55 55 55 55 55 55 55
    tone 416-447: 55 55 55 54 42 22 42 44 44 44 44 42 44 44 42 44
    tone 448-479: 42 44 22 24 22 22 22 22 22 22 22 22 22 22 22 22
    tone 480-511: 22 22 22 22 22 22 22 22 22 22 22 11 11 00 00 00
    LAN Information:
    IP Address: 192.168.1.1
    IP Subnet Mask: 255.255.255.0
    ค่าดูดีนะครับ ว่าแต่ กี่ เมกล่ะท่าน
      เน็ตทรู
      ในเร้าเตอร์ บอก 5895 kbps / 613 kbps อะครับ เช็ค ในเร้าเตอร์
      เช็คความเร็วได้ เท่านี้ อะครับ
      เว็บไทย
      เว็บนอก
        ปกติ แล้วใช่ปะ ครับ *0* อุส่า ให้ พ่อเดินสาย โทสับในบ้านใหม่
          ค่าสัญญาณสวยมากๆ ว่าแต่ใช้โมเด็มตัวไหนครับนี่
            ใช้เร้าเตอร์ TRUE_P-660HW-T1_v2 ที่ ทรู แถม มา ให้ อะ ครับ
              ใช้โหมดไหนอยู่ครับ ADSL2+ หรือว่า G.DMT ถ้ายังเป็น G.DMT ลองเปลี่ยนไปเป็น ADSL2+ ดูครับ
                หน้า สเตตัส ผม มันเขียน ว่า DSL Mode: ADSL2 DELT
                อะ ครับ ใช้ โหมด ADSL2 ปะ ครับ
                แล้วโหมด ADSL2 มันดี ยังไงหรอครับ
                  น่าจะใช่ละครับงั้น คือ ผมสงสัยน่ะครับเห็นอัพโหลดมันเหมือนจะได้เพิ่มแต่มันยังกั๊กๆ เหมือนมาน้อยไปนิด เลยคิดว่าเป็นเพราะโหมดเหมือนตอนที่ผมลองสลับโหมดเพื่อดูความแตกต่างของขาอัพโหลดน่ะครับ
                  ถ้าเอาแบบเข้าใจง่ายๆ โหมด g.dmt จะทำงานได้ดีในความเร็วต่ำๆ (ไม่เกิน 8M) พวกค่าสัญญาณรบกวนหรือความแรงอะไรนี่จะดูดีกว่าแบบ adsl2+ เล็กน้อย แต่ถ้าใครที่ใช้ความเร็วสูงๆ 8M ขึ้นไปก็จะใช้โหมด adsl2+ กัน ประมาณนี้น่ะครับ จริงๆ รายละเอียดยิบย่อยมันยังมีอีกลองหาอ่านที่บอร์ด adslthailand ดูนะครับ
