***มีport ใช้งานไม่ได้2-3 port (เสียบแล้วไม่ติด)
ราคา มือ 1 Router Board MikroTik (CCR1016-12G) 16 Core - A0095307
ราคาหน้าร้าน 22,990.-
***ขายเพียง 9500 บาท (รวมส่งครับ)
คุณสมบัติ Router Board MikroTik (CCR1016-12G) 16 Core
| Processor Specs | Tilera Tile-Gx16 CPU (16-cores, 1.2Ghz per core) |
| CPU CORE COUNT | 16 |
| CPU nominal frequency | 1.2 GHz |
| Size of RAM | 2 x SODIMM DDR slots, 2 x 1GB installed (no hw or software max limit) |
| Interface | 12 x 10/100/1000 Mbit/s Gigabit Ethernet with Auto-MDI/X |
| Serial Interface | 1 x DB9 RS232C asynchronous serial port |
| USB Interface | MicroUSB port, host and device mode |
| OS compatibility | MikroTik RouterOS v6 (64bit), Level 6 license |
| Power Supply | IEC C14 standard connector 110/220V, Power jack (BU model only). PSU included in both models. |
| Power Consumption | 48W |
| Environment | Max ambient temperature 50° @ 1.2GHz; 70° @ 1GHz CPU core frequency |
| Package Contents | CCR1016-12G : router in a 1U case with LCD, PSU, power cable, usb cable |
