อะทดสอบผี ใครใช้จอไหนก็ดูเอาเองละกัน 55
Originally posted by vasag View Postในรูปคงยังไม่ได้ปรับละมั้ง ตอนนี้ผมเปิดความสว่าง แค่ 5เอง
Light Boost หมายถึง เทคโนโลยี Zero Motion Blur (ผี = 0) ของจอ 120Hz+ นะครับ
UPDATE 2019: NVIDIA mentions this page in one of their scientific papers! These photos compare motion blur between 60Hz versus 120Hz versus LightBoost / ULMB. All images below are captured from the same computer monitor. These demonstrates differences in motion blur caused by high persistence (sample-and-hold). These UFO objects were moving horizontally at 960 pixels per second, at a frame rate matching refresh rate, on an ASUS 120Hz LCD. These close-up pictures were taken using a pursuit camera at 1/30sec exposure (exposing multiple refreshes into same photo). 60 Hz Refresh rate: Each refresh is displayed continuously for a full 1/60 second (16.7ms). This results in approximately 16 pixels of motion blur during 960 pixels/sec motion. 120 Hz Refresh rate: Each refresh is displayed continuously for a full 1/120 second (8.3ms) This creates 50% less motion blur. This includes regular and overclocked 120Hz. This results in approximately 8 pixels of motion blur during 960 pixels/sec motion. 120 Hz ULMB / LightBoost: CRT quality motion The backlight is strobed briefly, once per refresh, for low persistence. With LightBoost, 120fps @ 120Hz has 85% to 92% less motion blur than 60Hz. This results in just 1 to 2 pixels of motion blur during 960 pixels/sec motion. At 120fps@120Hz, a 1/30second camera exposure captures 4 refreshes. All 4 refreshes are stacked on each other, because the pursuit camera is moving in sync with the 120fps@120Hz moving object at a 1/30second camera exposure. The brief backlight flash prevents tracking-based motion blur. There is extremely little leftover ghosting caused by pixel transitions (virtually invisible to the human eye), since nearly all (>99%+) pixel transitions, including overdrive artifacts, are now kept unseen by the human eye, while the backlight is turned off between refreshes. See high speed video of strobe backlight, used by ULMB, LightBoost and other brands of strobe backlights. For older monitors with LightBooost, see the LightBoost HOWTO. For comparision between LightBoost settings, see LightBoost 10% vs 50% vs 100%. For more info, see Motion Blur Reduction FAQ and see Official List of Gaming Monitors to find which displays support Blur Reduction such as ULMB. Relationship of Motion Blur and Persistence (MPRT) Persistence (MPRT in ms) is not the same thing as pixel transitions (GtG response in ms). See Pixel Response FAQ: GtG versus MPRT. Moving Picture Response Time stands for MPRT, is also measured in milliseconds. Even a monitor advertised as 2ms GtG, can still have 16ms of persistence (MPRT). [gallery slick_active='true' size='full' link='file' ids='16170,16169'] Comparison Graph This graph illustrates the difference in motion blur between different refresh rates, including LightBoost and non-LightBoost. Even 100 Hz LightBoost has less motion blur than 144Hz non-LightBoost. In the best case scenario, 1.4ms is 92% less than 16.7ms -- and this also accurately corresponds to the amount of motion blur perceived by human vision, and pursuit camera photography. 1ms of motion blur = 1 pixel of motion blur during 1000 pixels/sec, from the sample-and-hold effect, as demonstrated & explained at TestUFO at www.testufo.com/eyetracking. For more information about LightBoost percentages, see LightBoost 10% vs 50% vs 100%. Newer NVIDIA ULMB (Ultra Low Motion Blur) use a setting called 'ULMB Pulse Width' that serves a similar function -- the motion can be even clearer with shorter pulse widths. How Were These Images Captured? Stationary Camera: Capture of Pixel Transitions A stationary camera is good for photographing pixel transitions statically. However, it is not a very accurate representation of perceived display motion blur and motion artifacts: Example: Stationary camera photo of a moving object on a display. Pursuit Camera: Accurate Capture of LCD Motion Artifacts Pursuit camera are used by display manufacturers for testing (e.g. MPRT pursuit cameras). This is simply a camera that follows on-screen motion. These expensive cameras are extremely accurate at measuring motion blur and other artifacts, since they simulate the eye tracking motion of moving eyes. However, Blur Busters has developed an inexpensive pursuit camera method which operates in conjunction with the Blur Busters UFO Motion Tests. It makes possible accurate photography of motion artifacts. The test at www.testufo.com/ghosting was used to take the pictures on this page. Blur Busters is the world's first blog to utilize a pursuit camera for accurate capture of motion artifacts, in WYSIWYG format, as seen by the human eye. The comparison graph was created from motion tests & oscilloscope measurements, including PixPerAn and Blur Busters Motion Tests, and cross-checked with TFTCentral oscilloscope tests (for 120Hz LightBoost = 100%). Accuracy +/- 0.1ms, assumes TN panel technology with optimized RTC, motion tests done with VSYNC ON with frame rate matching refresh rate. Other Useful Articles Pixel Reseponse FAQ: GtG versus MPRT Motion Blur Reduction FAQ Official List of Gaming Monitors LCD Motion Artifacts 101 Why Do Some OLED's Have Motion Blur?
