This video offers an in-depth look at different viewing angles and usage demonstrations, and we put a lot of effort into creating it.
Please support us by subscribing and watching here:
As technology continues to advance, portable devices are becoming more diverse.
What used to be stationary computer monitors are now available in portable versions from various brands, meeting the modern demands for mobility.
With extensive experience in the computer monitor market, ViewSonic caters to diverse user needs with series designed for office use, gaming, and professional creativity.
They offer multiple options for portable monitors and have also been introducing new products in the projector market in recent years.
This article focuses on the VP16-OLED model.
Renowned within the professional creative sphere for its quality, the VP series features ColorPro OLED technology, ensuring users enjoy a high-quality color experience.
The VP16-OLED monitor features a narrow bezel design on three sides and uses an OLED panel.
It has a 15.6-inch visible area, a hard, glare coating, and a resolution of 1920 x 1080.
The OLED panel employs self-emissive technology, providing exceptional black levels and color accuracy, making blacks darker and deeper.
It supports 1.07 billion colors with a 10-bit (8-bit + FRC) color depth, delivering the precise picture quality that creators expect.
The panel specifications include a 100,000:1 contrast ratio, a 1ms response time, a 400 cd/m², brightness, and a 170-degree viewing angle.
Additionally, it features blue light reduction and flicker-free technology.
The monitor also covers 100% of the DCI-P3 and sRGB color gamuts, and is Pantone Validated with a Delta E < 2, ensuring high color accuracy.
In recent years, most flagship TVs and computer monitors, typically positioned in the high-end market, have been equipped with OLED panels.
The accessories include a quick start guide, a magnetic multifunctional hood, a 15-60W adjustable power adapter, a Type-C to Type-C cable, a Type-C to Type-A cable, and a Micro HDMI to HDMI cable.
Every ColorPro monitor is pre-calibrated for color accuracy before leaving the factory, with reports provided for DCI-P3, sRGB, and Rec.709.
Users can download these calibration reports online, ensuring precise color accuracy right out of the box.
The VP16-OLED has a net weight of 0.98 kg. When tested with the stand, it weighs approximately 961 grams.
The dimensions of the monitor without the stand are 359 x 227 x 6 mm.
When the stand is extended, the dimensions and adjustable range are approximately 359 x 227-314 x 19 mm.
The back casing and the sides of the stand feature ColorPro nameplates to enhance recognition and add prestige.
The warranty includes five years of free labor and parts, as well as complimentary pick-up and delivery service throughout Taiwan.
During this period, customers are eligible for a replacement service with the same model or an equivalent one.
If the monitor needs repair within the warranty period, a loaner of the same model or specifications will be provided.
Additionally, there is a one-year warranty against bright pixel defects.
The control panel at the bottom of the stand has four buttons for OSD (On-Screen Display) settings.
Next to the control panel is the power switch.
The right side I/O connections include two USB 3.2 Type C ports (supporting data transfer, DisplayPort video input, and 40W power delivery), a 3.5mm audio output, and a Micro HDMI 1.4 input.
The left side is equipped with 1-watt speaker openings on both ends.
The stand features an integrated bracket design with three tilt options, enabling easy angle and height adjustments for more versatile screen positioning.
The stand is constructed with a dual-hinge bracket.
The first tilt option is a standing support that meets ergonomic standards, allowing the screen to tilt forward/backward up to -60º / 20º.
The second tilt option allows the stand to be adjusted into a triangular foldable bracket.
