2 x DIMM, max. 16GB, DDR3 1866(O.C.) / 1600(O.C.) / 1333 /
1066 MHz, ECC and non-ECC, un-buffered memory
Dual-channel memory architecture
AMD
FX? Series CPU on this motherboard supports up to
DDR3 1866MHz as its standard memory frequency.
Due to CPU spec., AMD
100 and 200 series CPUs support
up to DDR3 1066MHz. With ASUS design, this motherboard
can support up to DDR3 1333MHz.
When overclocking, some AMD CPU models may not support
DDR3 1600 MHz or higher frequency DIMMs.
Refer to www.asus.com for the latest Memory QVL
(Qualified Vendors List).
When you install a total memory of 4GB or more, Windows
32-bit operating system may only recognize less than 3GB.
We recommend a maximum of 3GB system memory if you
are using a Windows
AMD
are using a Windows
