การใส่แรม
  • การใส่แรม
    asrock 990fx extreme3 ใส่แรมบัสสูงสุดแบบไม่ลากได้เท่าไหร่คับ
    หน้าเว็บบอกมาอย่างนี้ครับ
    Up to 32GB DDR3-2100MHz in four DIMMS
      Note1: 4PCS= Dual channel, supports 4 modules.
      Note2: 2PCS = Tested successfully with 2 modules.
      Note3: The O.C. mode is not guaranteed. It depends on whole system configuration and other parameters.
      Note4: For system stability, use more efficient memory cooling system to support a full memory load (4 DIMMs) when overclocking.
      Note5: The mainboard supports DDR3-2000 MHz DIMMs only when you install a 6-core cpu to the mainboard.
      Note6: DDR3 2250/2200/2133 MHz will operate at DDR3 2000 MHz when OC.
      Note7: AMD FX series CPU on this motherboard support up to DDR3 1866 MHz as its standard memory frequency.
      Note8: When overclocking, some AMD CPU models may not support DDR3 1600 MHz or higher frequency DIMMs.
      Note9: Due to CPU spec, AMD 100 and 200 series CPUs support up to DDR3 1066 MHz. With ASRock design, this motherboard can support DDR3 1333 MHz.
