ส่วนอื่นเหมือนกันหมด ทำไมรุ่นแรมไม่ตรงกัน ต่างกันที่ XL
ใช้โปรแกรมอื่น เช่น CPU Z 1.59 ดูก็gป็นเหมือนกัน
Device Description
DIMM2: G Skill F3-12800CL9-4GBXL
DIMM4: G Skill F3-12800CL9-4GB
Field Value
Memory Module Properties
Module Name G Skill F3-12800CL9-4GB
Serial Number None
Module Size 4 GB (2 ranks, 8 banks)
Module Type Unbuffered DIMM
Memory Type DDR3 SDRAM
Memory Speed DDR3-1600 (800 MHz)
Module Width 64 bit
Module Voltage 1.5 V
Error Detection Method None
DRAM Manufacturer G Skill
Memory Timings
@ 761 MHz 10-10-10-3 (CL-RCD-RP-RAS) / 37-122-5-12-6-6 (RC-RFC-RRD-WR-WTR-RTP)
@ 685 MHz 9-9-9-3 (CL-RCD-RP-RAS) / 33-110-5-11-6-6 (RC-RFC-RRD-WR-WTR-RTP)
@ 609 MHz 8-8-8-2 (CL-RCD-RP-RAS) / 30-98-4-10-5-5 (RC-RFC-RRD-WR-WTR-RTP)
@ 533 MHz 7-7-7-2 (CL-RCD-RP-RAS) / 26-86-4-8-4-4 (RC-RFC-RRD-WR-WTR-RTP)
@ 457 MHz 6-6-6-2 (CL-RCD-RP-RAS) / 22-74-3-7-4-4 (RC-RFC-RRD-WR-WTR-RTP)
Extreme Memory Profile v1.2
Profile Name Enthusiast (Certified)
Voltage 1.50 V
Memory Module Features
Auto Self Refresh Supported
Extended Temperature Range Supported
Extended Temperature Refresh Rate Not Supported
On-Die Thermal Sensor Readout Not Supported
Field Value
Module Name G Skill F3-12800CL9-4GBXL
Serial Number None
Module Width 64 bit
Memory Timings
@ 761 MHz 10-10-10-27 (CL-RCD-RP-RAS) / 37-122-5-12-6-6 (RC-RFC-RRD-WR-WTR-RTP)
@ 685 MHz 9-9-9-24 (CL-RCD-RP-RAS) / 33-110-5-11-6-6 (RC-RFC-RRD-WR-WTR-RTP)
@ 609 MHz 8-8-8-22 (CL-RCD-RP-RAS) / 30-98-4-10-5-5 (RC-RFC-RRD-WR-WTR-RTP)
@ 533 MHz 7-7-7-19 (CL-RCD-RP-RAS) / 26-86-4-8-4-4 (RC-RFC-RRD-WR-WTR-RTP)
@ 457 MHz 6-6-6-16 (CL-RCD-RP-RAS) / 22-74-3-7-4-4 (RC-RFC-RRD-WR-WTR-RTP)
Voltage 1.50 V
Device Description
Field Value
Serial Number None
Module Width 64 bit
Memory Timings
Voltage 1.50 V
Field Value
Serial Number None
Module Width 64 bit
Memory Timings
Voltage 1.50 V
