SandForce2 Controller Issue on SSD vs SATA-3
  • ดีนะ SSD ครบแล้ว ไม่งั้นเสียอีกเยอะแหงมๆ
    • Marvell Controllers
      Marvel Da Vinci 88SS8014-BHP2 Controller ( Sata II - 3Gb/s ). Here is a BenchMarkReviews review on this controller.
      Marvell 88NV9145 ( Sata3 ? 6Gb/s ). This Marvell Controller is used in OCZ new range of Z5 PCIe ssd drives. This controller is also used in OCZ's Vertex 4 and Agility 4 as of info sourced july 4, 2012.
      Marvell's 88SS9032-BLN2 ( Sata 3 ? 6Gb/s ) enterprise grade SSD processor. - Released on the Toshiba MKx001GRZB Enterprise SSD designed around a SAS interface.
      Marvell 88SS9174-BJP2 ( Sata III - 6Gb/s ) This controller is used on the Crucial Real SSD. BenchMarkReviews.review. Overall, one of, if not the fastest desktop ssd controller released, especially when used with a 6GB/s controller, latest firmware, improvements to power consumption, better GC and Trim performance, Data integrity and reduced write latency, the drive activity has also been activated, have vastly improved the C300 drives. This controller as 8 pipelines.
      Marvell 88SS9174 ?BKK2 ( sata III ? 6Gb/s ).
      This updated controller is to be used in the RealSSDC400, it is huge update and as far better performance figures than it?s predecessor, the BJP2 on the C300. This controller is also used on the Intel 501, but due to using Intel firmware, it is optimized for movement of large compressed files rather than use with a OS. This controller is also used on Corsair P3 and the Plextor M2 ssd drives.
      Marvell 88SS9174-BLD2 ( sata III - 6Gb/s ).
      Has mentioned previously, this is a slight revision on the BKK2 silicone that was released on the Intel 501, Corsair P3 and the Plextor M2 ssd drives, as so far only been released on the Marvell C400 enterprise drive and the Crucial M4 client drive. There is a review on this particular silicone at BenchMarkReviews. This controller as the same 8 channels as the previous two versions of the 9174 controller.
      Marvell 88SS9175-BJM2 ( sata3 ? 6Gb/s ).
      Similar controller to the 9174 but consumes less power and as only 4 data channels ( pipelines ) compared to the 9174 with eight data channels (pipelines), this controller is used on the SanDisk Ultra Plus Client drive, the controller as similar sequential speeds but overall performance suffers due to the lower number of pipelines.
      Marvell 88SS9187 ( sata3 - 6Gb/s ).
      Marvell?s latest controller, so far aimed at the the Ultrabook/Enterprise/Mobile Market, boasts sequential write speeds of 500MB/s, even in dirty drive conditions, Adaptive read and write schemes, as in build raid capabilities and is capable of using up to 1gb ddr3 memory for the buffer. This controller could be used with forthcoming Crucial Client ssd update.
      • แต่ที่อึ้งคืออันนี้ พึ่งสั่ง M5P จาก JIB ไปด้วย เหอๆ นึกว่าเหมือนกันซะอีก
        Plextor M5 Pro series ( Sata III 6Gb/s ) ? Marvell 88SS9187-BLD2 Controller ? Read 540 write speeds vary depending on the size of the drive, the 512gb and 256gb drives have write speeds of 440, the 125gb/340, the 64gb/90, usual support for GC and Trim in Win7. The buffer size may vary similar to the M5S which varies with 256mb of ddr3 for the 128gb drive to 768mb for the larger 512gb drive. Capacities of 128gb, 256gb and 512gb of Toshiba TH58TE68D2JBA8C 19nm toggle nand flash memory. Website and reviews at Tweaktown.
        Plextor M5Pro Extreme series ( Sata III 6Gb/s ) ? Marvell 88SS9187 ? BLD2 Controller ? Seq Read 540 Seq write varies depending on capacity, 128gb at 340, the two larger capacities at 450, the cache buffer consists of one x 256mb chip ( 128gb drive ), two x 256mb chips ( 256gb drive ) and 3 x 256mb chips ( 512gb drive ) of ddr3 ram. Supports for GC and Trim in w7. The memory used on this series of drives is the Toshiba TH58TEG7DDJTA20 19nm Toggle-Mode MLC NAND memory. Website and Review at TheSSDReview. Identical in build to the Pro, testing at the TheSSDReview shows slight improvement over the Pro.
        • เหมือนกันครับ M5P Xtreme คือ M5P ที่อัพ FW1.02 แล้ว
          แค่เปลี่ยนชื่ออวย 100K IOPS
          Plextor, a leading developer of high-performance digital storage equipment, announces the release of the 100K Xtreme firmware update for its multi-award winning M5 Pro SSD. This update transforms the current M5 Pro into the M5 Pro Xtreme - the first truly professional SSD capable of delivering rando...
          • Originally posted by aonestudio View Post
            เหมือนกันทุกอย่าง ยกเว้นโมเดลของชิพ toggle ที่เอามาจากโตชิบ้า
            และ ผลต่างกันเล็กน้อย
            จริงๆแล้ว อัพเฟิร์มแวร์เป็น 1.03 ก็ใกล้เคียงกัน
            • มีรีวิวแล้ว Vertex3.20
              Realignment of priorities with respect to solid state storage at OCZ came as no surprise considering the turbulence of the past two years resulting in Ralph Sch
                Access Time สูงน่ากลัวดีแฮะ
                Originally posted by sariora123 View Post
                ติดตามกระทู้นี้ มานาน แล้วครับ มีสาระมาก (ถึงจะมีไร๊สาระเป็นบางช่วง) แล้วผมก็ได้ชื้อ SSD มาลองใช้ 1 ตัว คือ คิงเต่า ssd v300 (kingStun) ในตอนแรกก็ลังเลใจว่าจะเอา OCZ ดีไหม แต่บอร์ดผมมันไม่มี SATA3 พอดีจะปลดระวาง HDD หลักเอามาเป็นตัวสำลองไว้เก็บข้อมูล ถอดเข้าๆ ออกๆ ผ่าน mobile rack เอา เลยได้ คิงเต่า 60GB มา จึงนำเอาประสปกาณ์ กับSSD ตัวแรกมาเล่า
                เมือได้มาแล้วก็เลยเอาไปเทส แต่ขออภัยที่ไม่ได้เซฟรูปมาโชว (เห็นแวปๆ มีคนเอาคิงเต่าSSDมาลงแล้วด้วย) ส่วนตัวขอบอกว่า กากสรัส (Achi modeไม่ได้ต่างกับ IDE mode เลย เทสไดว์เปล่านะครับ) แถมจอดีแบบที่ท่าน Zyxzenze (ใช่หรือเปล่านะ) เตือนไว้ในคู่มือเเนะนำการเลือก SSD เทสไป 2 รอบ SSD เปล่าๆ แต่ดูใน my com เห็นมีแถบขึ้นมาประมาน 6-7 GB ดีที่มัน Format ออก สุดท้ายเลย เอาไปลงวินโดว ผล การใช้งาน นั้นค่อนข้างประทับใจมาก(ถ้าไม่ดูผลเทสนะ) จิ้มสวิส ไม่กี่อึดใจก็เข้าวินโดว จากเดิมที่เคยเกือบจะกินข้าวรอได้ เรียกใช้งานโปรแกรมก็ไวดีครับ ไวกว่า HDD แบบรู้สึกได้ แต่ว่าในเมื่อมันเป็น kingstun มันก็เลยออกอาการ มึนสมชื่อของมันในบางเวลา เท่าที่ใช้ 2-3 วันเจอ สักที กดเข้าโปรแกรมบางที รอ 4-6วิ
                นึกเสียดายอยู่พอควรที่ไม่เลือก OCZ แต่ไม่เป็นไรมันก็ไม่ได้เน่านัก ใช้ดีพอควร ผมอยู่ต่างจังหวัด บางทีอุปกรณ์ IT หลายๆชิ้นมันต้องเข้ากทม. เวลาเลือกเลยต้องเน้นถูกๆ แต่คุ้มหรือค่อนข้างคุ้ม ถ้าซื้อแถวบ้านมันชาร์ตโหดมาก ส่วนต่างราคาเอาไปเป็นค่ารถล่ะกัน(แบบว่ายังเหลือด้วย)
                เอาน่าท่าน ซื้อมาแล้วก็ใช้ให้เต็มที่ จ่ายเงินไปแล้วก็ถลุงมันซะอย่าได้แคร์ ถึงเวลาเคลมแล้วค่อยว่ากัน เก็บไว้เป็นบทเรียนเวลาซื้อตัวใหม่จะได้ไม่ช้ำใจอีก
                ปล. Kingston ติดสตันท์เลยอ่ะดิ
                • ขอรบกวนช่วยตัดสินใจหน่อยครับว่าเลือกตัวไหนดี ระหว่าง
                  Plextor M5 Pro Xtreem 128GB 4400
                  OCZ Vector 128GB 4990
                  ลังเลใจมากๆ เลือกไม่ถูก ชอบทั้ง2ตัว ประกันก็ผ่านทั่้งคู่ ความยากง่ายในการเซ็ตอัพก็ไม่ต่างกันทั้งคู๋(เท่าที่หาข้อมูลมา ปัญหาก็น้อยทั้งคู่)
                  ที่เห้นต่างกันชัดๆตอนนี้ก็คือราคาอ่ะครับ 500อ่ะ
                  ใช้งานกับคอมธรรมดาทั่วไป เน้นการโหลดเรียกข้อมูลบ่อยๆครับ(จำพวกเกมที่มีการวาป ตัดฉาก อะไรทำนองนี้) MB GIG 970A-D3
                  • Originally posted by xsefiroth View Post
                    งั้นผมเชียร์ m5p ละกันเพราะใช้อยู่ด้วย และเนื่องจากมันมี true speed ที่พอใช้จนใกล้เต็มความเร็วก็ยังไม่ลดลงและผมชอบลบๆ ลงๆ อะไรบ่อยๆ ก็เลยเลือกเจ้าตัวนี้
                    • @xsefiroth
                      ใส่เกมไว้โหลด M5P โลดครับ 590 ที่เหลือสมทบทุนซื้อเกม เลือกไม่ถูกจริง ๆ เดินไปที่ร้านแล้วเป่ายิ้งฉุบครับ
                      มีไม่กี่กรณีที่ผมจะเชียร์ Vector น่ะนะ เพราะใช้จริงหาความต่างไม่ได้ แถม M5P ถูกกว่าอีก นอกจากจะซื้อ 256GB แล้วมันยังแถม FarCry 3 อยู่ หรือไม่ก็ซื้อไปใช้กับ Mac 2 กรณีนี้ผมจะเชียร์ Vector ครับ
                        ตอบง่ายๆสั้นๆ M5P
                        • เน้นการใช้งานมากกว่า เลือก M5P ครับ
                          มาบอกกันไว้ตรงนี้แล้วกันครับ
                          Plextor เอา F/W 1.03 ของ M5P กลับมาไว้หน้าเว็บเหมือนเดิมแล้วนะครับ
                          • Originally posted by Antonov 12 View Post
                            http://www.goplextor.com/asia/index....gory&catid=162
                            changelog มีอะไรเปลี่ยนแปลงจากตัวเดิมก่อนถูกถอดออกไหมอะครับ เพราะผมยังไม่ได้อัพเลย เหอๆ
                            • หลังจากมีตังก็ถอดเจ้า v300 ออก จับ m5m ยัดใส่ mstaที่ว่างอยู่ ได้เท่านี้แหละครับ Lenovo S405
                              • Originally posted by spiritfire View Post
                                อยากรู้ด้วยคน
