สรุปว่าช้าลง ถูกมั้ยแล้ว กี่ %
Intel ถูกฟ้องแล้ว Patch ที่ส่งผลให้ทำงานช้าลง กรณีช่องโหว่ใน CPU ใครไม่ชื้อไม่ได้เงิ
Originally posted by THEFOOL View Post
อัฟแค่แพท วินโดว์ นะ
ยังไม่ได้ อัฟ แพทไบออส CPU
?CPU?8700K@5.1GHz(delided)
?Cooler:Corsair H110i GT
?GPU?GTX 1080ti(ZOTAC AMP Extream)
?MOTHER?ASUS ROG MAXIMUS X CODE
?MEMORY CLOCK?3900Mhz
?CEMU VER:1.11.3 ?UPDATE VER?1.4.1 ?DLC VER?3.0
?resolution:1080p ?OS:Windows10
Originally posted by Zaokaze View PostWeb นอกสรุปมา AMD ก็โดนแต่ไม่ทุกตัวเหมือน INTEL
Sent from my HUAWEI RIO-L02 using Tapatalk
Smile if you have an AMD chip (for now).
Do Meltdown and Spectre affect AMD CPUs?
AMD claims that its CPU architecture is immune to the attacks, though this statement may have been made prematurely. Because exploits have different variants, current analyses only show that AMD CPUs are safe against the current version of Meltdown, which focuses primarily on Intel?s architecture. The Meltdown paper has the following statement:
"We also tried to reproduce the Meltdown bug on several ARM and AMD CPUs. However, we did not manage to successfully leak kernel memory with the attack described in Section 5, neither on ARM nor on AMD. The reasons for this can be manifold. First of all, our implementation might simply be too slow and a more optimized version might succeed. For instance, a more shallow out-of-order execution pipeline could tip the race condition towards against the data leakage. Similarly, if the processor lacks certain features, e.g., no re-order buffer, our current implementation might not be able to leak data. However, for both ARM and AMD, the toy example as described in Section 3 works reliably, indicating that out-of-order execution generally occurs and instructions past illegal memory accesses are also performed."
So far, then, AMD processors haven't been affected by Meltdown, but they're not immune against Spectre, which uses a wider range of speculative execution features. Spectre impacts CPUs from AMD, ARM, and Intel, and the cure may in some ways be worse than the disease, depending on how much it impairs performance.
เอเอ็มดีอ้างว่าสถาปัตยกรรมของซีพียูมีภูมิคุ้มกันต่อการโจมตี
ในปัจจุบันแสดงให้เห็นว่าซีพียู AMDรุ่นปัจจุบันของ มีความปลอดภัย กับ Meltdown
เรายังได้พยายามสร้างบัฟเฟอร์ Meltdown บนเครื่อง ARM และ AMD หลายตัวอย่างไรก็ตาม เราไม่สามารถไม่ประสบผลสำเร็จ จัดการหน่วยความจำเคอร์เนลได้ด้วยการโจมตี
จนถึงตอนนี้โปรเซสเซอร์ AMD ไม่ได้รับผลกระทบจาก Meltdown
สรุปอีกรอบ สบายใจได้
Smile if you have an AMD chip (for now).Originally posted by THEFOOL View Postสืบเนื่องจากปัญหาข่าวลือ BUG ในระบบคอมพิวเตอร์ที่ใช้ CPU AMD ประสิทธิภาพอาจลดลง 5-30%
ว่า AMD จะโดนด้วย ไม่ใช่เฉพาะ Intel ?
คิดอย่างไรกันครับ ^^
https://www.overclockzone.com/news/9717
ถ้าตามนี้ สรุปได้ว่า AMD รอดตัวไปครับ เพราะ ไม่เข้าข่ายเงื่อนไข ไม่ต้องวิตกจนต้องขาย AMD ทิ้ง ใดๆ ทั้งสิ้น ครับ
ผิดพลาด ขออภัยล่วงหน้า จ้า
รอติดตามข่าวอยู่เหมือนกัน
มีแต่ intel ที่ CPU ได้รับผลกระทบ จน CPU สมรรถภาพ ตกลง จากการอัฟเดทป้องกัน คับLast edited by THEFOOL; 10 Jan 2018, 13:54:06.
ที่อ่านๆเว็บนอกมา
เพราะ cpu AMD ไม่ได้เปิดให้มีการเข้าถึงข้อมูลภายใน เหมือนของ cpu intel คับ
Tom Lendacky จากเอเอ็มดีออกมายืนยันว่าสถาปัตยกรรมของเอเอ็มดีไม่ได้รับผลกระทบจากช่องโหว่นี้
https://lkml.org/lkml/2017/12/27/2
หน่วยประมวลผล AMD ไม่อยู่ภายใต้ประเภทของการโจมตีที่คุณลักษณะ
สถาปัตยกรรมของเอเอ็มดีไม่อนุญาตการอ้างถึงข้อมูลอ้างอิงของหน่วยความจำรวมทั้งข้อมูลอ้างอิงที่เก็งกำไร ไม่อนุญาตในโปรเซสเซอร์ AMDLast edited by THEFOOL; 10 Jan 2018, 14:40:58.
สรุปข่าว คอนเฟม แล้ว
ทาง Microsoft Corperation ออกมาพูดถึงปัญหา bug ที่ทำให้กระทบต่อความปลอดภัยของระบบนั้นอาจทำให้เซิฟเวอร์บางตัวนั้นช้าลงเป็นอย่างมากและอาจมีผลต่อ PC ด้วย
Intel ยืนยันว่าชิปของตนเองมีการรองรับมี feature ที่ CPU สามารถทำการโดนแฮคได้
ในการแก้ปัญหาในลักษณะนี้ลูกค้าต้องยอมรับกับการลดลงของประสิทธิภาพเครื่องเพื่อความปลอดภัย
โดยก่อนหน้านี้ทาง Intel บอกว่าลดลงเพียงเล็กน้อยหรือไม่มาก จนกระทั่งมีการทดสอบที่ตรงจุดซึ่งพบว่าทำให้ช้าลงถึง 30%
ปัญหาเรื่อง การลดลงของประสิทธิภาพเครื่องพื่อความปลอดภัย intel บอกว่า คุณต้องไปทำ ต้องเพิ่มจำนวนเซิฟเวอร์ เพื่อให้ทำงานได้เท่าเดิมเมื่อก่อนทำการติดตั้ง security update
สำหรับผู้ใช้ PC ทั่วๆไปนั้น Intel ก็ออกมาบอกว่า โดยอ้างจากการทดสอบเครื่อง PCต่างๆพบว่าช้าลง 6 % หรือต่ำกว่าช่วง 2 ? 14 %
และสุดท้าย ถ้าคุณต้องการ เลือกให้ทำงานเร็วขึ้น แทนที่จะเน้นเรื่อง ความปลอดภัย ก็แนะนำว่า ไม่ต้องอัฟเดทแพท security update อยู่ที่ตัวคุณจะเลือกเอง
จบข่าว
If existing systems slow, customers may need to purchase more servers just to get back to where they were before patches were applied
http://www.gcubez.com/?p=14563
https://www.bloomberg.com/technology
