Dual socket 3647 for Intel Xeon Scalable processors with Xeon overclock tuning
12 ram slots DDR4 up to 2666MHz 768GB max ECC in Hexa Channel
7 PCIe x16 slots, with 3 of them running at x16. 2 of them running at single x16 or dual x8, and 2 of them running at x8
10 SATA ports, 4 U.2 ports, and 1 M.2 port that will work with both SATA and PCIe M.2 SSD
Supports 4-way Nvidia SLI and AMD CrossFire X. This depends on the graphic card that you get cause not all of them will work a 4-way setup.
For power it needs a single 24 with dual 8. There is a EATX 6 pin 12v around the U.2, probably for extra power to the PCIe x16 slots. Note that, this is not the same 6 pin for your graphic card.
7+1 phase for CPU and 2 phase for DRAM
Other parts are the 9 fan headers including those for the CPUs, internal usb 3.0, TPM, COM port, Q-Code LED, Power and Reset LED switches, Intel VROC Hardware Key, and VGA header. Yes this board has a VGA internal header on the board, power by a Aspeed AST2500 with 64MB of VRAM.
On the back, you get your USB 3.1 Gen 1 and Gen 2, including Type C, PS/2 combo port, Audio jacks, dual gigabit lan, and a USB Bios Flash Back button
Uses the EEB form factor, that's 12 inch x 13 inch ( 305cm x 330cm )
One unique component on the board is located above the CMOS battery. That could be a MicroSD or SIM card slot. Asus did not provide any info on that.
ส่วนซีพียู Xeon ก็น่าจะตัวนี้ละสิ
บอร์ด
บอร์ด
