Salomon sports darling
  • Salomon sports darling
    The midsole has been designed and constructed with responsive cushioning in mind. Salomon have created the Speedcross Vario's midsole to provide supportive comfort whilst remaining lightweight. The midsole utilises a dual fusion of Salomon's proprietary LT Muscle and Injected EVA cushioning systems. LT Muscle provides lightweight, highly durable cushioning, whilst the Injected EVA provides soft cushioning throughout the full-length of the shoe. The two midsole compounds have differing densities, and consequently work together to provide both cushioning and support throughout the gait cycle, whilst also providing responsiveness to enable you to feel the contours of the ground beneath you. Finally, an OrthoLite Sockliner provides plush underfoot cushioning within the shoe to give greater support and comfort. The sockliner has been fitted with anti-microbial properties to provide long-lasting freshness.
    The comprar zapatillas salomon baratas Trail Running Shoes Conquer any trail in the new Salomon Speedcross 4 Women's Trail Running Shoes. The latest iteration in the revered Speedcross series, the Speedcross 4 features an updated outsole pattern for even greater traction and higher durability, to keep you moving forwards no matter what the trail throws at you. Complete with a water-resistant and reinforced upper, you can rest assured that your feet will be protected throughout your run. Durable Upper The Speedcross 4 features a water-resistant, breathable upper, which keeps your feet comfortable throughout your run. The upper is also lightweight and abrasion resistant, with highly-durable materials deployed around high-wear areas to minimise damage to your shoes from rocks and branches.
    The salomon xa pro 3d baratas also engages the wearer with a injected and compression EVA midsole compound which actively works to absorb ground impact, reducing pressures upon the underfoot for a clean transition through to midstance. The EVA foam then propels you out with the advanced help from the integrated 3D chassis.The 3D Chassis, Merged between the midsole and the outsole is a low profile advanced chassis that maximize's security, motion control, energy management and push through protection for a high performance, stable and responsive ride.
    The salomon speedcross 3 baratas mujer combines a lightweight, anti-debris mesh upper. The bonded Sensifit construction overlaps the top part of the shoe with a water resistant fabric providing protection against the elements. Water shield protection across the tongue and toe sections provide additional water resistance without sacrificing breathability. The Speedcross 3 features a wider heel across the sole area than previous versions, creating a greater contact surface which is altogether more stable. In addition, the Quicklace slider has been reduced in size, as has the 'garage' pocket, meaning that weight is significantly reduced and stowage is more compact.
    Featuring the Sensifit system, which cradles the foot, yielding a precision fit and embodied support. The upper bears a quicklace system which allows accommodates for a quickly customisable fit, that can be easily tightened and loosened with ease. Once fastened the lace pocket woven into the tongue design provides a locked down space to stow the remainder loose lace. The moulded EVA midsole ensures a stable and comfortable ride, being both lightweight with formidable cushioning attributes and thanks to its design a degree of anatomical support.
