สงใสเรื่อง Ring Bus/Uncore clock Haswell
  • สงใสเรื่อง Ring Bus/Uncore clock Haswell
    ถ้า oc
    ดัน พวก Ring Bus/Uncore clock สูงๆ
    มันจะเพิ่มความแรงส่วนไหนหลอครับ
    แล้วมันจะแรงขึ้นมากไหม
    พลังอันยิ่งใหญ่ ย่อมมากับภาระอันใหญ่ยิ่ง
    http://www.overclockzone.com/forums/...1#post54005977
    ระบุรุ่น CPU และ GHz ที่ ใช้อยู่ด้วยนะครับ
    TOP 10
    1. Audigy = 784 = i7 4770k @ 4.90 GHz
    2. MajiNPic = 769 = i7 3930k @ 4.85 GHz
    3. endless12 = 768 = i7 3770k @ 5.00 GHz
    4. tonchai = 746 = i7 3820 @ 5.14 GHz
    5. 191 = 744 = i7 4770k @ 4.73 GHz
    6. jewsuper = 743 = i7 4770k @ 4.45 GHz
    7. AlphaZero = 733 = i7 3770k @ 4.70 GHz
    8. tues.tues = 726 = i7 4770k @ 4.50 GHz
    9. magickanok = 718 = i7 4770k @ 4.50 GHz
    10. Venom_I7 = 717 = i7 3930k @ 4.78 GHz
      TOP 50
    11. Botvinnik = 715 = i7 3770k @ 5.20 GHz
    12. theix = 711 = i7 3770k @ 4.60 GHz
    13. ammove = 710 = i7 4770k @ 4.50 GHz
    14. Yokboa = 697 = i7 2700k @ 5.00 GHz
    15. _iNdYbOy_ = 694 = i7 4770k @ 4.70 GHz
    16. Derp = 692 = i5 4670k @ 4.50 GHz
    17. LinX = 686 = i5 4670k @ 4.50 GHz
    18. franschan = 675 = i7 4770k @ 4.50 GHz
    19. acczanawa1 = 672 = i7 3770k @ 4.50 GHz
    20. Nan = 670 = i7 3820 @ 4.50 GHz
    21. Insight = 669 = i5 3570k @ 4.80 GHz
    22. icxnews555 = 669 = i7 4770k @ 4.20 GHz
    23. maxff007 = 665 = i5 4670k @ 4.50 GHz
    24. kakakla = 665 = i5 2500k @ 4.50 GHz
    25. champ24477 = 664 = i5 3570k @ 4.50 GHz
    26. birdynwa = 660 = i7 3770k @ 4.50 GHz
    27. Bevyma = 651 = i5 4670k @ 4.50 GHz
    28. bigtees = 649 = i5 4670k @ 4.50 GHz
    29. Futaba = 647 = i5 4670k @ 4.50 GHz
    30. eiei4 = 645 = i7 4770k @ 4.00 GHz
    31. adna = 643 = i5 3570k @ 4.00 GHz
    32. joe_osk125 = 639 = i5 3570k @ 4.50 GHz
    33. TWK. = 636 = i5 4670k @ 4.00 GHz
    34. Khomson = 631 = i7 2600k @ 4.60 GHz
    35. TonG_Zaa = 628 = i5 3570k @ 4.50 GHz
    36. Threx = 623 = i7 4770k @ 4.70 GHz
    37. tzpsycho = 619 = i5 3570k @ 4.40 GHz
    38. ksin = 617 = i5 3570k @ 4.40 GHz
    39. TA_Tae = 617 = i7 4770k @ 3.90 GHz
    40. tatamsss = 613 = i7 4770k @ 4.00 GHz
    41. ChainJaiL = 609 = i7 3770 @ 4.10 GHz
    42. RightRound = 591 = i5 3570 @ 4.20 GHz
    43. Gold3nfish = 581 = i7 4770 @ 3.40 GHz
    44. Partyz = 575 = i5 4670k @ 4.60 GHz
    45. sonny* = 573 = i5 2500k @ 5.00 GHz
    46. joka = 568 = i7 3770k @ 3.50 GHz
    47. Dizz461597 = 565 = i5 4670 @ 3.40 GHz
    48. jojoe79 = 562 = i7 920 @ 4.22 GHz
    49. winijchai = 561 = i5 3570k @ 4.20 GHz
    50. WorEG = 558 = i7 4770k @ 3.50 GHz
      TOP 100
    51. nccatman = 555 = i5 4670k @ 4.20 GHz
    52. eddies89 = 548 = i7 930 @ 4.20 GHz
    53. Arietta = 541 = i7 3770 @ 3.40 GHz
    54. viewkings2 = 535 = i7 4770 @ 3.40 GHz
    55. Soepoe = 535 = i5 3450 @ 3.92 GHz
    56. ComArts = 528 = i7 4770 @ 3.40 GHz
    57. SOYOS = 527 = i7 3770k @ 3.50 GHz
    58. nccatman = 524 = i5 4670k @ 3.40 GHz
    59. KarnRedsun = 524 = i7 980X @ 3.33 GHz
    60. eddytheman = 517 = i7 4770k @ 3.50 GHz
    61. taechasit = 494 = i5 2500 @ 3.88 GHz
    62. Chiang~* = 493 = i5 3470 @ 3.70 GHz
    63. akee_99 = 486 = Xeon E5640 @ 4.02 GHz
    64. Razsab = 466 = i5 4570 @ 3.20 GHz
    65. perhapsles = 449 = i5 4430 @ 3.00 GHz
    66. m shifu = 376 = i3 3220 @ 3.30 GHz
    67. oadoad = 365 = i5 750 @ 2.66 GHz
    * ตกหล่น หรือ ข้อมูลผิด PM แจ้งมาได้นะครับ
      Originally posted by HeavenSaber View Post
      ถ้า oc
      แรงขึ้นนิดเดียวครับ
      เซ็ตที่ auto ไว้ก่อน แล้วลาก core clock ให้เต็มที่ก่อน เสดแล้วค่อยมาลาก uncore
      แม้ว่า uncore จะลากได้มากน้อยขนาดใหน อย่าลด core clock เพื่อเพิ่ม uncore เพราะยังไง core clock ก้กินขาด
        อยากรู้ด้วยคน
          uncore มันจะช่วยเรื่องการส่งข้อมูลของ L3 กับ memory รึป่าวหว่า ????????? เรียนมายังไม่รู้เรื่องเลย555 ดูจากภาพใน google เอา
            พึ่งย้อนกลับมาดู ตอนเล่น 4670K ไม่รู้ว่ามันคืออะไร มีความสำคัญยังไง
              ถ้าปรับให้วิ่งเท่า CPU แบบ 1:1 ได้ก็จัดไปเลยครับ หรืออย่างน้อยเขาแนะนำให้ Cache วิ่งน้อยกว่า CPU Clock ราว 200-300Mhz
              มันส่งผลต่อเรื่องการจัดการ Memory โดยตรง (Latency) เพราะ Ring Bus หรือ Cache/Uncore (แล้วแต่จะเรียก) นั้นมันเป็นจุดเชื่อมต่อระหว่าง memory เข้ากับ Cache L3 ครับ
              แต่ถ้าปรับเยอะเกินความเร็ว CPU ก็ไม่มีประโยชน์แล้ว เพราะยังไงก็ต้องรอ Clock CPU อยู่ดี อิอิ...
                เซงเบย ivy ไม่มีให้ปรับ T_T
                  Ivy โครงสร้างของมันรู้สึกจะทำงานเท่ากันกับ CPU เลยครับ 1:1 ถาวร แรงอยู่แล้ว อิอิ....
                    อิอิกระจ่างเลยครับ แต่ผมสงสัยถ้างั้นทำไม Haswell ไม่ทำ 1:1 ออกมาเหมือนเดิมครับ
                        ก็ไม่แน่ใจครับ ที่เห็นว่าเพิ่มมาก็เรื่องของ Haswell ที่สามารถปรับแต่งความเร็วของ Ringbus ได้อิสระ
                        คงเพราะ Haswell มีการเปลี่ยนแปลงระบบการทำงานของ Cache L1 และ L2 โดยที่ชุด Cache L1 นั้นเพิ่มความเร็วในการส่งข้อมูลในส่วนของ Load bandwidth และ Store bandwidth จากเดิมบน Sandy และ Ivy จะอยู่ที่ 32/16Byte ต่อหนึ่ง Cycle เป็น 64/32Byte ต่อ cycle รวมถึงระบบ Cache L2 ที่มีการปรับปรุงเช่นกัน โดยในส่วนของ L2 Bandwidth to L1 เพิ่มจากของเดิม 32Byte/cycle เป็น 64 Byte/cycle และชุด L2 Unfied TLB จากเดิมแบบ 4K:512, 4- Way เป็น 4K+2M shared:1024, 8-way
                        ดังนั้นผมมองว่าการอนุญาติในการปรับแต่งของความเร็ว Ringbus น่าจะเหมาะสำหรับนัก Overclock มากกว่าครับ ที่จะสามารถ Custom ค่าพวกนี้ได้ ในกรณีที่ Ghz ของ CPU ไม่ตันแต่ Cache/Ringbus ตันก่อนก็ปรับลดลงได้ อะไรประมาณนั้น แต่โดยรวมแล้วคิดว่า Haswell มีความเร็วของ CPU Clock (L1) และ L3 นั้นเท่ากันกับ Sandy และ Ivy ที่อัตราทด 1:1 อยู่แล้ว ดังนั้นเมื่อระบบการทำงานของ L1 และ L2 ที่ทำได้ดีกว่า จึงไม่จำเป็นต้องใช้ Clock สูงมาก ก็สามารถประมวลผลได้ดีกว่า Sandy และ Ivy โดยที่ Ivy (3770K) จะต้องมีสัญญาณนาฬิกาสูงกว่า Haswell (4770K) อยู่ราว 200-250Mhz ถึงจะเทียบเท่าหรือแรงกว่าได้ครับ ลองกลับไปดูกระทู้ Render Encode Multitasking ??? ตามลิงค์ของลุง TWK. ด้านบนดูครับ แล้วจะกระจ่างเรื่องประสิทธิภาพ Mhz : Mhz ของ CPU แต่ละ Gen >>> http://www.overclockzone.com/forums/...1#post54005977
                          กระจ่างแล้วครับ ขอบคุณครับท่าน
                            ย้ำนะครับ ยังไงก็ "Core Clock is King"
                            เปรียบเทียบกันแล้ว core clock 0.05Ghz มีค่าเท่ากับ uncore ประมาน 0.70Ghz ครับ
                            ที่ว่า uncore ให้ต่ำก่วา core 0.3-0.5Ghz ถึงจะดีที่สุด นี่เป็นการเข้าใจผิดกันส่วนนึงมาตั้งแต่แรกๆครับ
                            หลังจากหลายๆคนในเวบนอกเค้าทดสอบกันดู มันไม่จริงครับ
                            uncore ยิ่งต่ำเท่าไหร่ (ต่ำถึง 3.5Ghz) ยิ่งมีสิทธิ์ทำให้ core สูงๆเสถียนได้ครับ (แต่ก็ขึ้นอยู่กับ cpu แต่ละตัว)
                            ยังไงก็ลาก core clock ให้เต็มที่ก่อน แล้วค่อยๆเพิ่ม uncore เพราะถ้าต้องลด core แม้แต่นิดเดียวเพื่อเพิ่ม uncore ยังไงก็ไม่คุ้มครับ
                              จดไว้ก่อน เผื่อมีโอกาสได้จับ
