แหล่งข่าวจาก นอร์ดิค ฮาร์ดแวร์ กล่าวว่า
แปลโดย กูเกิ้ล
Ivy Bridge gets 95W TDP, worse overclocker than Sandy Bridge
CPU / Chipset - Published on Saturday, 14 April 2012 20:13 Written by Marcus Heinemo
Ivy_Bridge_Box_95W_front
The launch of Intel's next generation processores is getting closer, and now the first results with air cooling is coming in. The TDP is higher than expected though, and max frequencies when overclocking is lower than anticipated.
We have already seen what Ivy Bridge can do with liquid nitrogen, so it is with mixed feelings we read the first results with air cooling. A user that has managed to acquire an Ivy Bridge processor reports sky-high temperatures making it impossible to reach the same frequencies as with Sandy Bridge. When overclocking the processor hits over 90 degrees, despite expensive after-market cooling.
At 4.6 - 4.7 Ghz the temperature gets so high the processor throttles, meaning it clocks down to protect the processor from permanent damage. Comparing with Core i7-2600k that in many cases can do 4.8 - 5.0 GHz stable with a good after-market cooler, Ivy Bridge looks to be 200 - 300 Mhz worse than Sandy Bridge.
It is Intel's new 22 nanometer technology with Tri-gate transistors that has brought these limitations. The transistorsare extremely tightly packed and the die size is so small compared to earlier processors, that the heat cannot be removed fast enough with air and water cooling. Rumors has it Intel is not entirely on the mark with the new 22 nanometer technology and a box shot of a Core i7-3770k shows a higher TDP than earlier expected.
Ivy_Bridge_Box_95WA box shot for a Core i7-3770k showing 95W TDP, higher than the expected 77W
A European retail NordicHardware has been in contact with can confirm that all boxes are marked 95W, which was higher than expected. Even if performance is better at the same frequency it is a surprise for those with high clocked Sandy Bridge processors intending to switch for Ivy Bridge.
ทั้งนี้ ผมรอ ผลทดสอบ จากทั่วโลก ครับ ฟังหูไว้หู
แปลโดย กูเกิ้ล
