ตกลง Ivy Bridge 1155 หรือ 2011 กันแน่ๆ
  • ตกลง Ivy Bridge 1155 หรือ 2011 กันแน่ๆ
    มาแปลกๆ
    หวด Maximus IV Extreme promotion jedi มาเก็บแท้ๆจะได้ใช้ไหมหว่ากับIvy
      http://www.techpowerup.com/155826/In...ls-Tabled.html
        "Ivy Bridge-E" (22 nm)
        Basic features of Ivy Bridge-based Core i7 microprocessors will not change. The i7 CPUs will still have 4 CPU cores with Hyper-Threading support, 8 MB level 3 cache, and incorporate Turbo Boost technology. The fastest processor from the family, Core i7-3770K, is clocked at 3.5 GHz, which is on a par with the top Sandy Bridge i7-2700K chip.
        Ivy Bridge Core i7 family will be utilize 77, 65 and 45 Watt power envelopes, which will correspond to suffix/"K", "S" and "T" processor numbers respectively.
        Core i7 family, currently represented by i7-2600 and i7-2700 series of chips, will have i7-37xx processor numbers.
        Core i5 family will also replace 2xxx numbers with 3xxx, that is i5-23xx, i5-24xx and i5-25xx will become i5-33xx, i5-34xx and i5-35xx.
        Similarly, Core i3 family will use i3-31xx processor numbers.
        Pentium and Celeron CPUs will be available with G2xxx numbers
        Currently, second generation Core processors use such suffixes as "K" for unlocked processors, "S" to indicate performance-optimized mid-power chips, and "T" for low-power microprocessors. Ivy Bridge processor numbers will also use these suffixes, and will add a new one, "X" for extreme edition
        Added features on Core i3 chips will be Hyper-Threading technology, AVX instructions, Quick Sync video, Clear Video HD, and InTru 3D. According to leaked slides, Core i3-31xx CPUs will have 55 Watt Thermal Design Power
        Core i5 models will "loose" Hyper-Threading, although they will add two extra cores.
        The processors will feature 6 MB L3 cache, Turbo Boost, Vpro technology, AES instructions, and Digital Random Number Generator.
          ขอบคุณครับเฮีย...น่าร๊ากก
            1155 = Ivy เพราะ BIOS เค้าทำรองรับ 22 nm มาแย้ววว
              ตามนั้น....
                เยี่ยม แบบนี้ไม่ต้องกลัวว่าจะต้องเปลี่ยนบอร์ด
                  2011 = Ivy Bridge-E
                  มีโอกาสทำออกมา
                    2011 แพงเกิน รอ Ivy ดีกว่า
                      Ivy Bridge = i7 4C/8T | i5 4C/4T - LGA 1155 : Q1/Q2 2012
                      Ivy Bridge-E = i7 6C/12T - LGA 2011 : Q4 2012
                      ปล. แต่ปลาย Q2 หรือ Q3 ปีนี้ Sandy Bridge-E จะมีตัว Sandy Bridge-EP 8core/16thread บน LGA2011 ออกมาอีกตัว
                        เมพ ขิงๆ
                        8C/16T
                          มาเช็คเมื่อเช้าทาง wikipedia แก้ให้เป็น 1155 แล้วครับ
                            แยกตลาดกันครับ
                            ตลาด ไฮโซ SOCKET 2011
                            ตลาด ปกติ SOCKET 1155
                              มาเก็บความรู้ ด้วยคน อิอิ
