...64-bit Workstation featuring One Intel i7-975 Quad Core 3.33GHz LGA 1366 CPU with Hypertheading shows 8 CPUs in device and performance monitor
...Nvidia Geforce 9800 GT 1GB HDCP Ready Dual Monitor Card
...6GB RAM {Expandable to 24MB}
...IEEE DV 1394A Port on the MBD
...Dual Gigabit Ethernet
...C: 750GB System Drive
...D: 3TB Internal = Populated with 2X 1500GB SATA II Hard Raid 0
...E: 3TB Internal = Populated with 2X 1500GB SATA II Hard Raid 0
...Drives RAID 0 for A/V {These are Seagate Drives with 3 Year Warranty direct to Seagate}
...Dividing the Drives up in to two separate Raids gives you the ability to live capture and pin up graphics at the same time, or let me know if you want only one big Raid instead.
...F: Blu-Ray 10X SATA Burner
...Genuine Microsoft Windows 7 Professional 64bit OEM
...Wireless Keyboard & Optical Mouse
...3 Month Computer System Warranty with Tech Support
...Cooler Master Mid Tower with Whisper Quiet 1000W Power Supply
มาพร้อมซอฟแวร์ ราคาก็ $5,995.00
Intel i7-975 Quad Core 3.33GHz LGA 1366 ค่าตัวมันเท่าไรหว่า พอๆกับ 980x,990x มั้ยหว่า
credit : http://www.hdnle.com/
