IX38 QuadGT มาแล้วจ้ะ
  • IX38 QuadGT มาแล้วจ้ะ
    ยินดีด้วยครับๆ
      ท่าทางจะแพง
        สวยงามครับ โทน น้ำเงิน-ดำ ดูโหดดี
        # CPU Supports Intel® Core™ 2 Duo / Quad processors with 1600/1333/1066/800MHz FSB
        # Supports Intel® Core™ 2 Extreme/Quad/Duo & Pentium® Extreme Edition, Pentium® D, Pentium® 4 Processors, Pentium® Dual Core
        # Digital PWM Designation provide high quality and efficient power
        # Chipset Intel® X38 Express / ICH9R Chipset
        # Memory 4 X 240-pin DIMM sockets support max. memory capacity 8GB
        # Supports Dual channel DDR2 1066/800/667/533 Un-buffered Non-ECC memory
        # LAN On board PCI Gigabit LAN controller supports 10/100/1000M Ethernet
        # Audio On board 7.1 CH HD Audio CODEC
        # Supports auto jack sensing and optical S/PDIF In/Out
        # HDMI audio ready header (S/P DIF header)
        # Expansion Slots 2 x PCI-E X16, 1 x PCI-E X16 (x4 bandwidth), 1 x PCI-E X1, 2 x PCI
        # Internal I/O 1 x Floppy Port supports up to 2.88 MB
        # 1 x ATA 133/100/66 IDE connector
        # 6 x SATA 3Gb/s connectors
        # 1 x IEEE1394, 4 x USB header (support 8 ports)
        # 1 x FP-Audio
        # Back Panel I/O 1 x PS/2 Keyboard, 1 x PS/2 Mouse
        # abit Silent OTES™
        # 1 x S/P DIF In, 1 x S/P DIF Out
        # 2 x eSATA
        # 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
        # 1 x 1394, 4 x USB 2.0, 1 x RJ-45 LAN connector,
        # Clear CMOS Button
        # Serial ATA 6 x SATA 3Gb/s offer by Intel® ICH9R support Intel® Matrix Storage Tech(AHCI & RAID0/1/5/10)
        # 2 x eSATA 3Gb/s through JMicron® JMB363 support 0,1JBOD RAID
        # IEEE 1394 Supports 2 Ports IEEE 1394 at 400Mb/s transfer rate.
        # Form Factor ATX form factor 305 x 245mm
        # PCB Color: Blue
        # RoHS 100% lead-free process and RoHS compliant
        # abit Engineered abit µGuru™ Technology
        # abit Silent OTES™ Technology
        # 100% Low ESR and high ripple conductive polymer aluminum solid state capacitors
        # New Generation digital PWM
        # EZ for CCMOS
        # On board LED Lighting
        # Quick Power On/Off & Reset buttons
        # right angle SATA connectors
