มันคือcpuรุ่นไหนอยากรู้
เจอแล้วOriginally posted by spcom.info View Postจัดไปที่ cpu-collection.de เลยครับท่าน
http://www.pcguide.com/ref/cpu/fam/g4I486DX4-c.html
Intel OverDrive DX4ODP75
Intel OverDrive DX4ODP75 Top Side
BOXDX4ODP75
Intel OverDrive DX4ODP75 Back Side
Upgrades 25 MHz Intel 486DX & 16/20/25 MHz 486SX based systems to 75 MHz.
The Processor is still sealed in its original box.
Core Frequency: 75 MHz
Board Frequency: 25 MHz
Clock Multiplier: 3.0
Data bus (ext.): 32 Bit
Address bus: 32 Bit
Voltage: 5 V
Introduced: 10/1994
L1 Cache: 16 KB
CPU Code: i486 ODP
Package Type: Ceramic
PGA-169
Socket: 1/2/3
Intel OverDrive DX4ODPR75 (V1.1)
Intel OverDrive DX4ODPR75 (V1.1) Top Side
DX4ODPR75
C5291151
SZ958 V1.1
INTEL(M)(C) '89'93
Intel OverDrive DX4ODPR75 (V1.1) Back Side
A5051163CB
A4
29
DX4 OverDrives typically have qualities different from standard 486s of the same speed. These include built-in voltage regulators, different pin-outs, write-back cache instead of write-through cache, built-in heatsinks, and fanless operation.
References: pcguide.com
Comment by Hugh Russell (hugtheslug[at]yahoo.co.uk):
Also will upgrade DX-66 systems to a stable 100 mhz.
This is probably an overclock of the overdrive itself.
Forgot to add, 486 fan was attached to heatsink for extra cooling and stability.
Comment by Johann (lord80james2003[at]yahoo.com):
The Intel DX4ODP75 was designed for changing 25 MHz 486 systems to run at 75 MHz.
BUT. The v1.1 allowed 33 MHz systems to run at 100 MHz. The first version (1.0) could only bring the speed of a 33 MHz system up to ~83 MHz.
Address bus: 32 Bit
Voltage: 5 V
Introduced: 10/1994
Manufactured: week 29/1995
L1 Cache: 16 KB
CPU Code: i486 DPR
P4T
Intel S-Spec: SZ958
PGA-168
Socket: 1/2/3
