November 2008, Intel launched their next generation platform, Core i7.
Its been over 2.5 years after launching X58+ICH10R.
2009, all MB makers were busy to sell Intel P55/H55. Some users misunderstood the P55 is the latest platform.
I used to emphasize my view that P55 is for mid-high range and X58 is still the most hi-end product of Intel.
Its approved by the market, however, X58 has been quiet for a long time.
2010, many MB makers start to push USB3 and SATA3. Also, Intel announced 32nm 6Cores CPU to support X58.
Most MB makers revised their X58 models and make it be more popular in the market.
GIGABYTE launched new X58A series which add USB3 and SATA3 spec.
Year beginning, they launched X58A-UD7 for higher spec and performance users.
I used to think UD7 is the most hi-end X58 product from GIGABYTE.
Last month, GIGABYTE announced a more hi-end model, X58A-UD9.
X58A-UD9 packing is much bigger than normal MB.
UD9 looks like a very powerful X58 MB. The components using is also the most luxury in the market.
Its XL-ATX, 34.5cm x 26.2cm. I recommend to find the suitable chassis before purchasing.
All slots are X8/X16 PCI-E
Accessories
SATA/eSATA cable, external USB Port
2~4WAY CrossFireX/SLI bridge
Product manual, software manual and driver CD
Lower-Left Corner
4 X PCI-E X16 support X16 for CrossFireX and 2~4WAY SLI.
3 X PCI-E X16 support X8.
Realtek 8111E dual LAN support Teaming and Smart Dual LAN.
Realtek ALC889 supports 7.1CH and High Definition Audio/Dolby Home Theater.
Design in Taipei
Lower-Right Corner
6 X blue SATAII, provide by ICH10R. Its SATA2 and support RAID 0, RAID 1, RAID 5 and RAID 10
2 X white SATAII, provide by GIGABYTE SATA2 chip. Its SATA2 and support RAID 0, RAID 1 and JBOD
1 X IDE, provided by GIGABYTE SATA2 chip.
2 X white SATAIII, provide by Marvell 9128. Its SATA3 and support RAID 0, RAID 1
Dual BIOS, dual protection, and built-in Debug LED
Upper-Right Corner
6 X DIMM DDR3 support 800/1066/1333/2200. The max capacity is 24GB.
The Cyan big button is Power switch. Blue small one is for reset.
DDR3 use 2-phase PWM, and next is 24-PIN power connector.
Upper-Left Corner
LGA 1366 CPU socket. The CPU metal cover is cladding for better look.
UD9 use 24-phase PWM which support dual 12-phase alternative mode. The maximum power is 1500W. Its the most hi-end X58 PWM design.
Back side has 2 8PIN design to enhance the system stability in high loading mode.
IO
4 X USB 2.0(Yellow)
2 X USB 3.0(Blue)
2 X RJ-45 LAN
2 X eSATA/USB 2.0 combo
1 X S/PDIF fiber/coaxial output
1 X 1394a
clr CMOS button
Accessories
Lower-Left Corner
Design in Taipei
Lower-Right Corner
Upper-Right Corner
Upper-Left Corner
IO
4 X USB 2.0(Yellow)
2 X USB 3.0(Blue)
2 X RJ-45 LAN
1 X 1394a
clr CMOS button
