Club i7-K 875 Unlock Multiple CPU Club
  • Originally posted by MIUKI View Post
    ประมาณนี้ครับ
    Ai Overclock Tuner [Manual]
    OC From CPU Level Up [AUTO]
    OC From Memory Level Up [AUTO]
    CPU Ratio Setting [21]
    > CPU configuration
    CPU Ratio Setting 21
    C1E Support Disabled
    Hardware Prefether Enabled ---> Disabled
    Adjacent Cache Line Prefetch Enabled ---> Disabled
    Max CPUID Value Limit [Disabled]
    Intel(R) Virtualization Tech Enabled ---> Disabled
    CpU TM Function Enabled ---> Disabled
    Execute-Disable Bit Capability Enabled ---> Disabled
    *Active Processor Cores [All]
    A20M [Disabled]
    *Intel(R) SpeedStep(TM) Tech [Disabled]
    Intel(R) C-STATE Tech [Disabled]
    BCLK Frequency [194] --->200
    PCIE Frequency [100] ---> 104
    DRAM Frequency [DDR3-19..]
    QPI Frequency [AUTO] --->4.270 GT/s
    Start auto tuning []
    OC Tuner []
    >DRAM Timing Control AUTO ---> Manual
    1st information
    DRAM CAS# Latency [] --->9
    DRAM RAS# to CAS# Delay []--->9
    DRAM RAS# PRE Time []--->9
    DRAM RAS# ACT Time []--->24
    DRAM RAS# to RAS# Delay [Auto]
    DRAM REF Cycle Time [Auto]
    DRAM WRITE Recovery Time [Auto]
    DRAM READ to PRE Time [Auto]
    DRAM FOUR ACT WIN Time [Auto]
    DRAM Back-To-Back CAS# Delay [Auto]
    2nd information
    DRAM Timing Mode [Auto]
    DRAM Round Trip Latency on CHA [Auto]
    DRAM Round Trip Latency on CHB [Auto]
    3rd information
    DRAM Write To Read Delay(DD) [Auto]
    DRAM Write To Read Delay(DR) [Auto]
    CPU Clock Amplitude []
    PCH Clock Amplitude []
    CPU Clock Skew []
    PCH Clock Skew []
    ******* Please key in numbers directly!*******
    Extreme OV [Disabled]
    LN2 Mode [Disabled]
    Full Phase Control [Full Phase]
    Load-Line Calibration [AUTO] ---> Manual or Level2
    CPU Voltage Mode [VID]
    CPU Voltage [1.43125] --->1.455
    CPU PLL Voltage [1.82850] --->1.850
    IMC Voltage [1.39125] --->1.4
    PCH Voltage [AUTO] --->1.100
    DRAM Voltage [168275] -->1.72
    DRAM DATA REF Voltage on CHA [Auto]
    DRAM CTRL REF Voltage on CHA [Auto]
    DRAM DATA REF Voltage on CHB [Auto]
    DRAM CTRL REF Voltage on CHB [Auto]
    Spread Spectrum Control
    CPU Spread Spectrum [Disabled]
    PCIE Spread Spectrum [Disabled]
    >ASUS O.C. Profile
    ปรับตามที่ผมแนะนำดูก่อนนะครับ ตามตัวสีแดง ดูว่าไปได้มั้ย น่าจะเสถียรนะ ดูอุณภูมิให้ดีนะครับ
      llll
      llll
      llll
      PCIE Frequency [100] ---> 104 เครื่องbootไม่ขึันครับพอลดเหลือ 101 bootเข้าวินโดว์ได้
      ไฟชุดนี้test Linx กดปั๊บดับปุ๋มยังกะฮิตาชิแนะครับ test prime95 1024k ได้แว๊บฯดับแต่ไม่ร้อนเหมือนกด Linxครับเกือบ 100องศา
      เด่วผมจะลองเพิ่มนิดลดหน่อยดูครับ แต่แปลกนะครับผม test Linx@4.053ผ่านแต่พอเล่น call of duty4 online เครื่องดับไม่แน่ใจเลยลอง
      อีกสองครั้งผลดับคือเก่าแต่ถ้า test prime95 ผ่านสองชั่วโมงเครื่องจะเสถียรไม่ดับไม่รี
        llll
        llll
        llll
        ถ้าเน้น Test Linx ก็จะเป็นแบบนั้นแหล่ะครับ เพราะไฟ CPU ป้อนไว้เยอะ แต่ถ้าเอาไปเทส Vantage จะได้คะแนน performance ได้ดี
        เอางี้ก็ได้ครับ ถ้าจะเทส Linx ให้ปรับลด ไฟ CPU ไปที่ 1.4 ถ้วน หรือ 1.375
        CPU PLL 1.80
        IMC 1.375
        PCH voltage 1.1 เหมือนเดิม
        Dram ก็ 1.70 ค่า CL เปลี่ยนเป็น 9 9 9 9 27
        linx น่าจะผ่านนะ
        แต่ความเสถียรไม่แน่ใจ ผมว่าไม่ค่อยเสถียรแหล่ะ เพราะไฟน้อยเกิน
        • ดันๆ
          • 22.55
            • มีครูแล้วตื่นมาจัด...
              5.01 นาฬิกา
              • อัพเดท spec หน่อยคับ อิอิ
                Core i7 875K L013A905
                Venomous X + Silverstone FM123 + GC-Ex
                Asus P7P55D-E bios 1201
                Super Talent Speed Series 2200 CL8
                EVGA GTX480 [Standard clock]
                SB Audigy
                Tt Toughpower 750w CM
                Tt Element T
                เย็นนี้หรือพรุ่งนี้จะมาอัดต่อ
                • ผมว่าช่วงเช้าตรู่นี้เป็นช่วงที่เหมาะสมแก่การลากจริงๆ อากาศเย็นโดยธรรมชาติ
                  แต่ปัญหาคือ ผมยังไม่ตื่น (ตื่นสายตลอด)
                  • ขออนุญาติสมาชิกคลับครับ
                    ผมมีweek นี้ครับ ใครสนบ้าง
                    • เห็นในห้องขายของอยู่ครับ ขายถูกดี.....
                      • Originally posted by theix View Post
                        SB Audigy
                        Tt Element T
                          รอชมด้วยครับ
                          • Originally posted by pro4687 View Post
                            โอ้ว รวมมิตร week เลยแฮ่ะ ปล่อยตัวล่ะเท่าไหร่ล่ะท่าน
                            Theix เค้าเทพเสมอแหล่ะ
                            จัดชุดน้ำได้แล้วครับ เดี๋ยวก็จะเข้าหน้าหนาวแล้ว อีกไม่กี่เดือน จะอัด Vantage ให้ผ่านที่ 4.5 ให้ได้ คอยดู
                              รอดูครับ
                              รอลอก config ด้วย ....กำ
                                +1 กากอย่างเราได้แต่มองตาปริบฯ ิอิ
