ข้องใจเกี่ยวกะM/B gigabyte GA-EP31-DS3L
1. 4 x 1.8V DDR2 DIMM sockets supporting up to 4 GB of system memory (Note 1)
2. Dual channel memory architecture
3. Support for DDR2 1066/800/667 MHz memory modules (Note 2)
* Because of chipset limitations, do not populate both DIMM sockets of the same channel (e.g. DDR and DDR2), or populate 4 DIMM sockets with double-sided memory modules to prevent system's failure to start or incorrect detection of memory modules. Please refer to the user manual for the memory configurations table.
* Because of chipset limitations, when using FSB 1333 MHz CPU with populating all DIMM sockets, memory frequency will be reduced from the original, and system instability or incorrect detection of memory module may be occur. Please refer "Memory Support List" for memory support information.
(Note 1)Based on standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. For example, 4 GB of memory size will instead be shown as 3.xx GB during system startup.
(Note 2)Some memory configurations will result in memory frequency being reduced from the original frequency.
