Supported OS versions
Microsoft Windows® 10-64 - Fall Creators Update (1709)(RS3)
Microsoft Windows 10-64 - April 2018 Update (1803)(RS4)
Microsoft Windows 10-64 - October 2018 Update (1809)(RS5)
Microsoft Windows 10-64 – May 2019 Update (1903)(19H1)
Microsoft Windows 10-64 – November 2019 Update (1909)(19H2)
Microsoft Windows 10-64 – May 2020 Update (2004)(20H1)
Notes
Self-installing format (.exe) is the easiest installation method and our recommendation.
Manual installation format (.zip) is intended for developers and IT professionals.
See the ReleaseNotes for installation instructions, supported hardware, and more.
About Intel® software and drivers
The driver or software for your Intel® component might have been changed or replaced by the computer manufacturer. We recommend you work with your computer manufacturer before installing our driver so you don’t lose features or customizations.
Download Link
:: https://downloadmirror.intel.com/296...0_100.8336.exe
