ช่วยวิจารณ์ หรือให้ขัอมูลรายละเอียดเกี่ยวกับ CPU ตัวนี้ด้วยนะครับ
KOHJINSHA (First 7" UMPC with integrated DVD Super Multi Drive)
Microsoft® Windows Vista® Home Premium
Intel® processor A110(800MHz)
Memory 1GB
Hard Disk 60GB
Bluetooth Ver,2.0+EDR
CD/DVD Drive
Wireless LAN: IEEE802.11 b/g
7" Wide TFT Color LCD (LED Back light) with Touch Screen Resolution (standard display) WSVGA (1024×600)
Camera: 1.3 Million Pixels
3 in 1 Media Slot: SD Card (SDHC/SDIO) / Memory Stick / MMC Card compatible, CF Card Slot (Type-II) x 1
Approx 1.1kg (with Standard Battery)
SR8KPO6S/SR8WPO6S (for Singapore)
Main Features
Small Size(A5 File Size) Light Weight (Approx 1.1 Kg with Battery), Slim Type
(Approx 33mm) DVD-R/+R Double Layer Support [DVD Super Multi Drive]
Durable (100kg Pressure); Quiet (Silent Mode Embedded)
Touch Screen, Swivel LCD with Long Life LED Backlight
Various Kinds of Media Slots and Wireless LAN
Easy Recovery from HDD to Factory Shipment Status
OS
Windows Vista * Home Premium
Processor
Intel processor A110(800MHz)
Chipset
Mobile Intel 945GU Express Chipset + ICH7-U
Main Memory
PC2-3200(DDR2-400 SO-DIMM)
Memory Slot
Standard
Maximum
1 slot ( already in use by standard memory)
1GB
1GB
Display
Mobile Intel S45GU Express Chipset Embedded
CD/DVD Drive
[DVD+-R Double Layer Writing Support]
DVD+RW, -RW Max reading speed x 8 / Max Writing Speed x6
DVD+R,-R Max writing speed x8 /Max Reading speed x 8
DVD+R DL , DVD – R DL : MAX writing speed x 4 / Max reading speed x 4
DVD-RAM, Max Writing Speed x5 /Max Reading speed x 5
DVD-ROM, Max reading speed x8
CD-RW: Max writing speed x 24 / Max reading speed x 16
CD-R Max writing speed x 24 / Max reading speed x 24
CD-ROM: Max reading speed x 24
(buffer under error protection function)
LAN
100 BASE-TX /10BASE –T
Wireless Function
Wireless LAN IEEE802.11b/g, Bluetooth Version 2.0 +EDR(on/off switch)
Sound
Realtek High Definition Audio
Speakers
Internal Stereo Speaker(1.0W + 1.0W)
Camera
1.3 million pixels
External Interface
Functional Buttons
Front Side
Right Side
Left Side
Brightness Button , Direction Button , Rotation Button , Enter Key, Scroll Button
Mouse key
Sound Volume (with mute switch function), Headphone Jack x 1 ,Microphone Jack x 1 , 3 in 1 Media Card Slot : SD Memory Card (Support SDHC,SDIO)/Memory Stick /MMC Card , CF card Slot (Type- II) x 1
Power Switch , CD/DVD Drive Power Switch
USB 2.0 port x 2 , Analog CRT Port (Analog RGB Mini D-Sub 15 pin ) x 1 , LAN Port x 1
Power
AC Adapter (input 100~240V+10%, 50~60Hz)
Standard battery
Lithium Ion Battery (11.1v, 2600mAh)
Battery life
Approx 3.6 Hours
Charging Time
Approx 2.5 Hours (Approx 85% charged with x hours)
Large Battery
Lithium ion Battery (11.1v ,5200mAh)
Battery life
Approx 7.2 Hours
Charging time
Approx 3.0 Hours (Approx 85% charged within x hours)
Power Consumption
Maximum 50 W, Normal 9 W
Environment
Ambient Temperature 5~35 C / Ambient Humidity 20~80% (Without Condensation)
Dimension
Approx 233mm (W) x 177 mm (D) x 33mm (H) (Measurements without protrusions)
Weight
Approx 1.1 Kg (with standard battery )
Main Accessories
Stylus Pen (Stored in top right of display ), Strap,
Cushion PC Case, Standard Battery, AC Adapter, AC cable, User’s Guide, Warranty Card etc.
Main Application Software
DVD /CD Writing Software
Cyberlink DVD Suite
DVD Video Player Software
Inter Video WinDVD for KOHJINSHA
Anti Virus Software
McAfee Internet Security Suite Basic Edition (90 day free trial)
