Darksiders III : Test GPU / CPU
How to Unlock the Frame Rate Cap i
Darksiders 3
However, if Darksiders 3 is stuck at 60 frames per second on PC then there is a fix. All you need to do is follow the instructions below and you can set your own custom frame rate limits in Darksiders 3, or unlock the FPS cap entirely.
How to Unlock the Frame Rate in Darksiders 3
# In Windows, navigate to C:\Users\[username]\AppData\Local\Darksiders3
#Open 'Saved' and then open the 'Config' folder
#Open up the 'WindowsNoEditor' folder
#Open the file 'GameUserSettings' with a text editor such as Notepad or Wordpad
Ensure VSync=0
# Find the line that says 'FrameRateLimit=0'
Change the number to your desired frame rate limit or, if you want it totally uncapped, just set it to "FrameRateLimit=999".
#Save the document and then boot up Darksiders III
Voila, your frame rate should now be unlockedLast edited by aotshooter; 29 Nov 2018, 00:53:26.
