NVIDIA issued a number of knowledgebase updates, and a number of things are going end of life. Nvidia is working on the 390 series drivers, and from the looks of it will be halting 32-bit support drivers. Whether this is just the professional series or also the consumer end-user drivers is a little unclear. But I assume both.
After Release 390, NVIDIA will no longer release drivers for 32-bit operating systems for any GPU architecture. Later driver release versions will not operate, nor install, on 32-bit operating systems. Driver enhancements, driver optimizations, and operating system features in driver versions after Release 390 will not be incorporated back into Release 390 or earlier versions. This impacts the following operating systems:
Microsoft Windows 7
Microsoft Windows 8/8.1
Microsoft Windows 10
Linux
FreeBSD
NVIDIA intends to support critical driver security fixes until January 2019. The latest build version is 388, so 390 is coming up rather sooner than later. Now might be a good time (if you are still on a 32-bit OS) to update/upgrade to 64-bit.
