Radeon Software Crimson ReLive 17.11.2 Star Wars Battlefront II
  • Radeon Software Crimson ReLive 17.11.2 Star Wars Battlefront II
    Support For
    Star Wars? Battlefront? II
    Fixed Issues
    Radeon ReLive recorded clips may experience green corruption or green screen backgrounds.
    Radeon ReLive may fail to record when switching a game between Fullscreen and Borderless Fullscreen.
    Radeon Settings may experience a crash or hang when enabling/disabling AMD CrossFire mode on some select Radeon HD 7000 series graphics products.
    Radeon WattMan user interface may not reflect overclocked or underclocked values for GPU memory.
    Radeon WattMan may not apply correct reduced voltage values for some Radeon RX 400 and Radeon RX 500 series graphics products.
    Secondary extended displays may experience green corruption when resuming from display off or sleep modes.
    INF comparison.
    17.11.1
    AMD Driver version 17.40.1031
    Windows driver version 23.20.788.0
    17.11.2
    Driver version 17.40.2511
    Windows driver version 23.20.793.0
    Notable changes?
    [ATI.Mfg.NTamd64.10.0]
    "%AMD6863.1%" = ati2mtag_R7500, PCI\VEN_1002&DEV_6863&REV_00
    [Strings]
    AMD6863.1 = "Radeon Vega Frontier Edition"
    So these look like they support the Vega Frontier directly now without needing the separate Frontier driver.
    EDIT: And as usual the atiapfxx.blb file comparison.
    (Which is converted to readable xml via command-line and running atiapfxx.exe -r -sys -s test.xml which is then compared against the dump of the previous driver.)
    Well the version number is already listed above, 17.11.1 is dated November 2nd and 17.11.2 is dated November 15th.
    Crossfire profiles:
    Star-Wars Battlefront 2
    Call of Duty World War 2
    These were updated.
    DXX profiles:
    DOTA2
    Destiny 2
    These were updated.
    "PXDynamic">HighPerfGPUAffinity
    This particular flag was applied to the following games:
    Battalion 1944 (Battalion.exe)
    From Other Suns (FoS-Win64-Shipping.exe)
    LA Noire (L.A. Noire_Release.exe and L.A. Noire_Release-dev.exe and yes it already had a profile, HD version on PC too then?)
    Shard (Shard_Release_Vive_Vulkan_x64.exe)
    Sparc (VRArena.exe)
    EDIT: Previous exe names for LA Noire was "LANoire_Release.exe" and "LANoire.exe"
    (So now there's four of them, guessing that means the new edition might possibly hit PC but we'll see.)
    Download: http://www.guru3d.com/files-details/amd-radeon-software-crimson-relive-17-11-2-driver-download.html Support For Star Wars™ Battlefront™ II Fixed Issues Radeon ReLive recorded clips may experience green corruption or green screen backgrounds. Radeon ReLive may fail to record when...
      17.11.1 เอา strix rx580 error directx เวลาเล่นเกมตลอดเลยครับ หวังว่า 17.11.2 จะไม่มีปัญหา
        ลงแล้วพัดลมหมุนมั๊ย?
          ยังเป็นครับลงเสร็จใหม่ๆไม่เป็นเปิดเล่นอีกทีเป็นอีก Powercoler RX580 ตกลงอาการนี้จะโฟกัสไปที่ใหนดี เวอร์ชั่นวินโดว์/ไดร์เวอร์การ์ด/ตัวการ์ดจอว์เอง ???
            driver ครับ เขียน name ของ device มาผิดหรือไม่ก็ device id ไปอยู่ผิดที่.. แก้ inf เอาเปิดของเก่าเทียบดู
              ขอบคุณที่แนะนำครับ มีตัวอย่างหรือวีธีทำใหมครับ ผมไม่รู้ว่าของเดิมมันเป็นแบบใหนครับ
                หา driver เก่ามาแกะ file แล้วไปส่องดูมาเทียบกันอ่ะครับ ตอนโม driver หลอก sound realtek ใช้ xfi ก็ทำแบบเดียวกัน
