Bluesky Frame Rate Converter 2.8.4 (11/12/2017) มาใหม่ สำหรับดูอนิเม สมูท ลื่นๆ จ้า
Changes
Version 2.8.4 (11/12/2017)
Fixed rate conversion malfunction issue when changing the AFM Mode
Version 2.8.3 (10/29/2017)
Fixed could not use BlueskyFRC filter in the Stereoscopic Player
Version 2.8.2 (09/23/2017)
Fixed issue that Activation/Deactivation of rate conversion setting did not match GPU support status when changed AFM mode on BlueskyFRCUtility
Minor change
Version 2.8.1 (08/08/2017)
Fixed DXVA decoding was not activated on 10bit HEVC content playback under specific conditions
Minor changes and fixes
Version 2.8.0 (07/01/2017)
Improved rate detection and rate change processing
Improved behavior of video processor
Fixed app crash and stop response issues under specific conditions when running DXVA decode
Changed system requirements
Version 2.7.1 (03/25/2017)
Fixed incorrect frame issue when running Zero-Copy Mode
Fixed screen rotation issue when using PotPlayer
Version 2.7.0 (02/27/2017)
Improved rate detection processing
Fixed image corruption issue when enabling DXVA decode
