Bluesky Frame Rate Converter
Top
Features
This program is a DirectShow Filter which can convert the frame rate using GPU, and it has the following features.
Support AMD Fluid Motion Video*1
Support Intel Haswell and newer iGPU*2
Convert 24p to 60p and 30p to 60p by interpolating frames*3
Support DXVA decoder
*1 Support Radeon HD 7000 Series or newer dGPU and Kaveri or newer APU (Support GCN GPUs)
*2 Not supported in display driver version 15.45.10.4542 or newer
*3 Support variable frame rate
System Requirements
Operating System
Windows 10/8.1/8
Windows 7 (Intel iGPU only)
Changes
Version 2.8.3 (10/29/2017)
Fixed could not use BlueskyFRC filter in the Stereoscopic Player
Version 2.8.2 (09/23/2017)
Fixed issue that Activation/Deactivation of rate conversion setting did not match GPU support status when changed AFM mode on BlueskyFRCUtility
Minor change
Version 2.8.1 (08/08/2017)
Fixed DXVA decoding was not activated on 10bit HEVC content playback under specific conditions
Minor changes and fixes
Version 2.8.0 (07/01/2017)
Improved rate detection and rate change processing
Improved behavior of video processor
Fixed app crash and stop response issues under specific conditions when running DXVA decode
Changed system requirements
Version 2.7.1 (03/25/2017)
Fixed incorrect frame issue when running Zero-Copy Mode
Fixed screen rotation issue when using PotPlayer
Version 2.7.0 (02/27/2017)
Improved rate detection processing
Fixed image corruption issue when enabling DXVA decode
