Radeon Software Crimson ReLive Edition 17.8.2 Highlights
Support For
F1? 2017
Up to 4% performance improvement measured on Radeon RX Vega 64 graphics when compared to Radeon Software Crimson ReLive edition 17.8.1(1)
PLAYERUNKNOWN'S BATTLEGROUNDS? Early Access
Up to 18% performance improvement measured on Radeon RX Vega 64 graphics when compared to Radeon Software Crimson ReLive edition 17.8.1(2)
Destiny? 2 Beta
Fixed Issues
Display may blank or go black after install upgrade with Radeon RX Vega Series graphics products.
Random corruption may appear in Microsoft desktop productivity applications on Radeon RX Vega series graphics products.
The "Reset" option in Radeon Settings Gaming tab may enable the "HBCC Memory Segment" feature instead of setting it to the default disabled state.
Radeon WattMan may not reach applied overclock states on Radeon RX Vega series graphics.
Unable to create Eyefinity configurations through the Eyefinity Advanced Setup option.
Known Issues
Mouse stuttering may be observed on some Radeon RX graphics products when Radeon WattMan is open and running in the background or other third party GPU information polling apps are running in the background.
GPU Scaling may fail to work on some DirectX?11 applications.
Windows Media Player may experience an application hang during video playback if Radeon ReLive is actively recording desktop.
Secondary displays may show corruption or green screen when the display/system enters sleep or hibernate with content playing.
After resuming from sleep and playing back video content the system may become unresponsive on Radeon RX Vega series graphics products.
Bezel compensation in mixed mode Eyefinity cannot be applied.
Footnotes
(1) Testing done by AMD Performance Labs as of July 27, 2017, using an Intel Core i7 7700K (@4.2GHz), 2x8GB DDR4-3000 MHz memory, and Windows? 10 (64bit). PC manufacturers may vary configurations yielding different results. At 4K running the game F1 2017, the Radeon? RX Vega 64 (8GB) system with Radeon Software 17.8.1 scored 54.0 frames per second and the system with Radeon Software 17.8.2 scored 56.0 frames per second. This results in a 4% increase in performance with Radeon Software 17.8.2. All times an average of 3 test runs. Results are estimates and may vary. Performance may vary based on use of latest drivers. RS-175
(2) Testing done by AMD Performance Labs as of July 27, 2017, using an Intel Core i7 7700K (@4.2GHz), 2x8GB DDR4-3000 MHz memory, and Windows? 10 (64bit). PC manufacturers may vary configurations yielding different results. At 4K running the game Player Unknown's Battlegrounds, the Radeon? RX Vega 64 (8GB) system with Radeon Software 17.8.1 scored 28.5 frames per second and the system with Radeon Software 17.8.2 scored 33.6 frames per second. This results in an 18% increase in performance with Radeon Software 17.8.2. All times an average of 3 test runs. Results are estimates and may vary. Performance may vary based on use of latest drivers. RS-173
แต่วันนี้สังเกตเห็นอะไรบางอย่าง เมาส์มันสะดุดตอนที่เปิดโปรแกรม OpenHardwareMonitor พอดีกำหนดไว้ให้ เปิดโปรแกรมตอนเข้าวินโดว์เสมอ เลยปิดมันซะ มันก็หายสะดุดทั้นที ซะงั้นกำ....
